Old 12-25-2019, 03:05 AM   #127
Dom2497
Drives: Full HKS GT86
Now running this kit myself on a stock engine with updated rods, injectors, 2.75 inch exhaust etc.
Sent from my SM-G950F using Tapatalk
Dom2497 is offline   Reply With Quote
Old 02-24-2020, 10:01 AM   #128
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by Outzou View Post
Hi,
For people who installed this turbo. How long to get your car tuned?
We installed it, with internal forged (HKS stoker kit low comp 2.1, valve train HKS, injector, fuel pump modified...).
And my problem is that my local tuner is working on tune since close two months in partnership with Delicious Tuning, but at this time, it's still not finished.
You could try CounterSpace Garage here in the US. They might be able to tune for you. Or FenSport in the UK might be able to do something?
MS, CSCS, TSAC-F, CPT
Old 02-24-2020, 10:09 AM   #129
Outzou
Drives: Toyota Gt86 -2015- Grey
Thank you, yes may be it will finished like that, because it starting to be very long :-)
Outzou is offline   Reply With Quote
Old 02-24-2020, 11:08 AM   #130
StraightOuttaCanadaEh
Wes
how many hours of labour did it take to install the stroker kit and the valve train?
Instagram: @gt86ws
Old 02-24-2020, 11:15 AM   #131
tomm.brz
Drives: brz 2017 hksv2
anyone knows how to lower minimum boost on this kit?
is there a spring available to put in the wastegate with lower pressure?
Old 02-24-2020, 05:13 PM   #132
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I am pretty sure internal wastegates aren't designed to be taken apart, so the only way to get a lower boost spring would be to do something sketchy and custom like in the below video, or to find a wastegate on a different used turbo that could work as a retrofit, or to reach out to HKS to see if they sell or would sell a differently springed wastegate/actuator that could be used with their turbo.
[ame]https://www.youtube.com/watch?v=mkoynZv-24o[/ame]
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
tomm.brz (02-24-2020)
Old 02-27-2020, 12:47 AM   #133
Esclaw
Hawaii
Esclaw's Avatar
Drives: HKS Turbo 2017 BRZ
Hi,
I did my tune with Delicious. I think recently they've changed the way they do their tuning. I schedule a Day in the week to do complete e tune.
Might want to see if that is possible since they're in partnership with delicious. Difficult thing may be the time zone differences.
Esclaw is offline   Reply With Quote
Old 03-28-2020, 07:00 PM   #134
Sam.Vera
Detective John Kimble
Sam.Vera's Avatar
Drives: 2016 FR-S
Does this kit have a blow off valve? I suppose if it did, the MAF sensor would be fucked for a few seconds after the boost pressure is released
Sam.Vera is offline   Reply With Quote
Old 06-02-2021, 05:52 PM   #135
joshbrz
Drives: 2015 Subaru BRZ Sport Tech
For those who are worried, this kit is capable of running 10psi. 12 is not the lowest. Out the box, the initial boost pressure actuator is set at 13psi but can be brought down by adjusting the actuator rod/plate positioning in conjunction with running HKS catted downpipe or using stock front pipe. This will keep boost pressure under 10psi.
joshbrz is offline   Reply With Quote
The Following 3 Users Say Thank You to joshbrz For This Useful Post:
CSG Mike (06-06-2021), Harlock (06-08-2021), tomm.brz (06-10-2021)
Old 06-09-2021, 11:25 PM   #136
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Originally Posted by pillbox View Post
Yeah, I usually run 10 psi max on our crappy pump fuel here. Our Chevron 94 here is equivalent to 89 just south of the border.
95 degF is usually the hottest it gets here, only for a week or two.
I have experience with turbo rotaries, there's just a lack of technical literature from HKS on this system.
Just curious where did you get your tune? I am from vancouver BC with crappy fuel too.
Thanks
botbs is offline   Reply With Quote
Old 05-26-2023, 11:00 AM   #137
Espi
Espi's Avatar
Drives: 17 BRZ
I know someone who is running stock injectors and pump, on E85 Flex with this kit pushing 7PSI using a Turbosmart Actuator PN (TS-0681-5072). Just need more power nothing crazy, this fits my needs. I'm going with this setup lol
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
Teseo (05-27-2023)
Old 08-04-2023, 07:29 AM   #138
Espi
Espi's Avatar
Drives: 17 BRZ
Reached out to JDL and they made me a better manifold than what comes with this kit. Just to follow up on my last post 7PSI WG installed:
Fun times ahead!
Old 08-29-2023, 01:48 PM   #139
Espi
Espi's Avatar
Drives: 17 BRZ
Little gem I came across yesterday. Looks like DK now also fitted the HKS kit. Notice 6:49 time stamp regarding the manifold "this item is not from HKS". As I suspected, but now confirmed by HKS!
If you want a better manifold hit up JDL The bronze coating on my existing JDL header is REALLY good at keeping temps down. So I went with the same (plus its slightly UEL), the DP is still the one the kit came with but also coated:
Just waiting on Koyo to restock the radiator I need to finally get everything installed. (5 week wait time FML) I have everything else I need to make this install right.
- JDL 10AN oil return line kit to replace the rubber HKS oil return line
- JDL 10AN tapped oil pan
- JDL Slim fan kit
- Greddy Oil Pan baffle and Killer B pickup tube (Ty CSG)
- Custom front crash bar
- Koyo rad radiator parts and just waiting now for the actual radiator.. ughh
Almost there! Cheers
Old 08-29-2023, 05:34 PM   #140
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
- JDL Slim fan kit
Very nice selection of parts you got there. I also got the HKS kit and have been enjoying it since 2018.
For those who want to know about my setup:
-HKS GT3-RS with catted downpipe
-JDL Super quiet catted/resonated front pipe
-JDL slim fan kit
-Custom crash bar
-Jackson Racing dual radiator/oil cooler
-R1 Titan cat-back exhaust
-Ptuning flex fuel kit
-1050x Injectors
-Ecutek tuned by CSG
-Boost ~10psi
-Ogura Racing Clutch w/lightweight flywheel 400LD-TT
-VLS gauges (boost/AF ratio/Oil pressure)
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
The Following 2 Users Say Thank You to Raven86Project For This Useful Post:
Espi (08-29-2023), villainous_frx (08-30-2023)
Never been so excited for an oil change... No Limit Motorsport Engine, Exhaust, Transmission 20 09-27-2012 11:59 PM
Beyond excited!! debs0712 Scion FR-S / Toyota 86 GT86 General Forum 12 06-27-2012 09:03 PM
Excited!!!!!! Filipino Royale BRZ First-Gen (2012+) — General Topics 2 06-13-2012 10:14 PM
So excited to be here!!!! staycrushing Scion FR-S / Toyota 86 GT86 General Forum 8 05-31-2012 07:05 PM
Brisbane get excited! spr1nter AUSTRALIA 29 05-14-2012 07:07 PM
