#8905 |
Drives: '14
Damn, sorry man. Bad luck.. just another setback. I assure you that you'll love the kit when you finally get to put it on.. tons of low end torque and whines like a Hellcat especially if you change out the intake.
#8906 |
Drives: 2014 BRZ Limited
Mine had this exact damage from shipping. Sprintex replaced the parts free of charge. Push them on it.
#8907 | |
Drives: 2017 toyota 86
If so then definitely press them on it more. If from a vendor then you may have to go through the vendor. But if its just the hose is an issue. Probably quicker/easier to replace yourself. @jflogerzi said he has a spare for you. |
#8908 | |
Drives: '13 brz limited
#8909 | |
2013 Series 10 FRS #553
#8910 |
Drives: '14
Anyone happen to be selling those Nameless aluminum intake pipes that they used to make specifically for our kits? I would really like to throw one in my car to make the whine louder, even though it heatsoaks more.
#8911 | |
https://datazap.me/u/jflogerzi/dyno-...10-16-17-33-58 @tomm.brz You mind doing a sanity check for me. EDIT** looks like the log only got to 6100RPM... Ops. If this good LMK if not I can get another one to redline.
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 02-22-2020 at 08:48 PM. |
#8912 | |
Possibly no way to have a one to one comparison. Either that or your timing is just crazy compared to mine. 1 degree is like 1.5% or around 3-4whp with our setups. Id imagine you should be about 15whp more but not 35whp. |
#8913 | |
@tomm.brz can you chime in on this. Sent from my GM1915 using Tapatalk
#8914 |
Drives: brz 2017 hksv2
a bit too rich maybe and airflow calculation is a bit off of 5% during the pulls making thing even more richer,
no afr adjustment for E% variations but not so important, he adds a lot of timing advance to compensate for that overall very well tuned e85 gives more timings headroom than WMI he has 10 degrees more advance than what he has when running pure e0 petrol there are other things than influence the ignition timing and not necessarily means that produces more power, if more advance.. like GDI angle and PI% and cam timings, and mostly the AFR.. you cannot usually compare IGN Timing of different tunes also the afr you can t really compare because it depends on the lambda scaling used by the tuner, basically every tuner uses a different scaling, so a 12 AFR could be a real 11.5 or a real 12.5 you would need a wideband near the front OEM lambda to know for sure but you don t usually care too much of it, as soon as you are in a safe spot you then make it up with ignition timings if you want make a full redline pull.. anyway it will be on check i guess, since the ethanol and the closed loop fuel control activated, I mean the Delicious tuning logs i saw were quite unpredictable lol but this look better |
The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | 86TOYO2k17 (02-23-2020), jflogerzi (02-23-2020) |
#8915 |
update on my situation
got the replacement parts a week ago, got the kit installed that same weekend, and tune by mike this week. and so far im lovin' that extra kick and power! goin' to get it dyno soon to see what the graph looks like since i swapped injectors, fuel pump, and on flex fuel but with stock pulley for now. |
#8916 | |
Would be cool to see another 75mm dyno and 69mm dyno same car/dyno/setup. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | BlankHugs (03-07-2020) |
#8917 | |
![]() Sent from my GM1915 using Tapatalk
The Following User Says Thank You to jflogerzi For This Useful Post: | BlankHugs (03-07-2020) |
#8918 | |
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
