Old 01-29-2020, 01:10 AM   #141
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Car continues to chill most of the winter. Recently took it down for a wash at the shop and added some new track stickers. Im going to be hitting up SRP for a drift day soon though which will be fun.
Photos below:
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
Clutch Dog (01-29-2020)
Old 02-20-2020, 01:06 AM   #142
Elliotw
Elliotw's Avatar
Took the BRZ tS out to the Amazon Spheres or bezos balls as the locals call it Heres some photos:
I'm planning on heading out to do some drifting this Sunday weather permitting. Also recent picked up a new mod. Currently in route to Seattle
The Following 2 Users Say Thank You to Elliotw For This Useful Post:
beltax90 (02-21-2020), jflogerzi (02-21-2020)
Old 02-20-2020, 04:00 PM   #143
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Wow, is that a standard blue, or is it just color-graded in some way? That really pops!
ROFL it's Waffle is offline   Reply With Quote
Old 02-20-2020, 04:50 PM   #144
Elliotw
Elliotw's Avatar
Standard WRB. IPhone11 Pro with no filters.
Old 02-21-2020, 07:26 AM   #145
ROFL it's Waffle
Wow, that thing handles low-light very well. It's... blue-tiful
The Following User Says Thank You to ROFL it's Waffle For This Useful Post:
Elliotw (02-21-2020)
Old 02-21-2020, 08:32 PM   #146
Elliotw
Elliotw's Avatar
Got some goodies in the mail today!
Excited for install and adjustments. Will be a fun learning process.
jflogerzi (02-23-2020)
Old 03-03-2020, 11:12 PM   #147
Elliotw
Elliotw's Avatar
Last Sunday tackled two fun projects.
Ohlins road and track V2 install and new garage lighting.
1. Redo lighting in my garage with LEDs. Mad a huge difference. Could work in the garage with the door closed now.
Before and after:
Next up on list was install my Ohlins Road and Track V2 coilovers.
Step 1 was measure all ride height stock. I measured ground to fender height. Which was following:
FR: 26"
FL: 26"
RR: 26.5"
RL: 26.5"
After install and one round of adjustments I landed on 15 clicks soft for the street and the following ride hides:
FR: 25.25"
FL: 25.25"
RR: 25.875"
RL: 25.875"
My goal is after settling in to rise up front and rear to be a 0.5" less then stock height. Waiting to do more driving to do initial write up of the coilover system. I will say at 15 clicks soft no change in ride quality compared to OEM setup. Excited to try some adjustments on the track. Ive noticed I may need some spacers now as well for my winter wheels.
Installed photos:
Car showing new ride heights:
Code Monkey (03-04-2020), mistople (03-07-2020)
Old 03-03-2020, 11:22 PM   #148
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
By v2 do you mean the solfter Olhins that released last year or the mi20's?
Any issues pairing them with the versus/velox camber plates?
Old 03-04-2020, 12:07 AM   #149
Elliotw
Elliotw's Avatar
I believe these are the ones with the softer spring rate. any way to tell?
I decided to email Ohlins USA with my part number to see which version it is.
They work great with the Versus/Velox OEM tophat camber plates.
Edit from the future:
These Verus camber plates didn't end up being compatible with the top spring perch this resulted in additional noise and damage to the topmount and the top spring perch.
Old 03-04-2020, 02:31 AM   #150
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Your feedbacks are much awaited regarding the coilovers, at different settings. Cruising and spirited driving. I hear some like to leak too.
Hope yours fare well.
Thefalls is offline   Reply With Quote
Old 03-04-2020, 10:26 PM   #151
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
https://www.ft86club.com/forums/showthread.php?t=125517
Should clarify the changes.
Old 03-10-2020, 12:30 PM   #152
Elliotw
Elliotw's Avatar
OhlinsUSA still hasn't responded but looking at the part number on the springs and pictures online of the coilovers. I am 90% its the V2 setup. Did a final round of adjustment car is now:
FR: 25.75"
FL: 25.75"
RR: 26.25"
RL: 26.25"
which is 0.25" lower than stock all around.
Photo:
Impressions continue to be good. Rides well in the street environment. I do notice some new spring noises on certain articulations. Not sure if thats expected. I went ahead and greased up where the spring meets the tophat/bottom hat. Lets see if that helps out.
Kiske (03-11-2020), Thefalls (03-13-2020)
Old 06-09-2020, 02:11 PM   #153
Elliotw
Elliotw's Avatar
Update:
I was talking about this spring noise I was hearing with the coilover post install. Well turns out parts I thought compatible where not. During alignment the shop noticed damage to the top spring perch and top mount. Which was a real bummer as I had to cancel my two track days and find a new topmount.
damage:
The spring noise I was hearing was related to this damage. Now with the new topmount(vorshlag) I don't have any noises! Signed up to hit the ridge this Friday and got the car aligned its all ready to go!
Excited to try the Ohlins on the track still. They are riding better with a compatible topmount as well.
Old 06-09-2020, 02:33 PM   #154
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
All Verus plates hit like that. I haven't had an issue with it.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 09:41 AM
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions Corradooo Engine, Exhaust, Transmission 2 11-25-2017 07:16 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 10:14 PM
