Old 02-17-2020, 05:40 PM   #1
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Suspension change. Spring suggestions
I am removing my coilovers. I am contemplating getting Bilstein B6 shocks and lowering springs. Or B8, if the difference is negligible. If anyone has opinions, I want to hear them! Thanks!
What lowering springs will pair with the B6's? I had eibach Prokit springs in the past. I am not sure that I want a progressive spring again... Suggestions?
I think I want either the Pedders or Whiteline tophats for the front. I will be using camber bolts with these. Opinions on which?
like these...
https://www.rallysportdirect.com/par...YaAkMFEALw_wcB
Thanks in advance for any input.
I LIKE TIRES!
Old 02-17-2020, 06:49 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
B8 just has less droop travel than B6, zero advantage to the B8.
Racecomp engineering or Swift would be my pick for lowering springs.
Get as much camber as you can, there's a good overview of options posted here.
ineedyourdiddly
Leonardo (02-17-2020)
Old 02-17-2020, 08:53 PM   #3
Vital
Drives: 2015 BRZ
RCE Yellows. I cant recommend these springs enough!
The Following 3 Users Say Thank You to Vital For This Useful Post:
drm (02-18-2020), Leonardo (02-18-2020), RToyo86 (08-26-2020)
Old 02-18-2020, 10:21 AM   #4
Racecomp Engineering
Bilstein B6 with RCE Yellows is a great combo.
Skip the B8s.
Skip the Whiteline mounts and get the Pedders mounts.
- Andrew
The Following 7 Users Say Thank You to Racecomp Engineering For This Useful Post:
BlueWhelan (02-20-2020), Leonardo (02-18-2020), norcalpb (02-19-2020), RToyo86 (08-26-2020), Tanstin (08-27-2020), Tristor (02-20-2020), wparsons (02-18-2020)
Old 02-18-2020, 11:33 AM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Skip the B8s.
- Andrew
Thank you!
I LIKE TIRES!
Old 02-18-2020, 04:22 PM   #6
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Skip the B8s.
- Andrew
How long have the pedders mounts been around? Do we know if they have a better bearing and last longer than the whiteline ones?
My whitelines lasted barely 5k kms before the bearings got noisy... didn't do enough research and found all the posts about issues with them after the fact. Since they only make noise during low speeding turning I've just left it for now, but it's annoying enough I want to replace them with something in the spring.
Edit: Alternatively, if I wanted to go as far as getting a set of verus camber plates, how long should I expect those bearings to last compared to OEM/whiteline/pedders mounts? I'm lowered on the eibach prokit, stock struts and it's a daily driver with occasional canyon spirited drives.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Old 02-18-2020, 04:46 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by wolffbite View Post
I didn't do enough research and found all the posts about issues with them after the fact.
Exactly how I feel about my Fortune Auto (I mean BC racing) coils.
Thank you for adding to the conversation!
Out of the parts I installed, I am keeping my Blackworks rear LCA, whiteline bumpsteer kit, Perrin sway bars, and whiteline endlinks.
I have J2 trailing and toe arms. I am going to swap the toe to SPC and the trailing back to stock.
I LIKE TIRES!
Old 02-18-2020, 05:06 PM   #8
I'll be running the pedders mounts myself starting this spring, so I'll be able to give some long term feedback on them eventually. Others have run them for longer time periods.
Very few conventional camber plates will remain silent for a long time.
- Andrew
Leonardo (02-19-2020), wolffbite (02-19-2020), wparsons (02-20-2020)
Old 02-19-2020, 07:56 AM   #9
Fred E
Drives: WRB BRZ
- Andrew
What noise do camber plates eventually make during those low speed turns? I'm getting some popping-type noises now while turning the wheel when stationary (mostly when turning the wheel while transitioning between reverse and forward in a parking lot) and was wondering if it was coming from the camber plates or something else. Currently on Tarmac 2s.
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
Old 02-19-2020, 08:02 AM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
I ran Raceseng camber plates with stock PP Sachs struts and Swift springs that lowered the car 1.25". Not nearly enough bump travel as the camber plate bearing ate up another ~3/4" of travel, hit bump stops HARD over even small bumps. At the track it actually worked kind of OK, but because outside front was bottomed it would get mid-corner understeer which sucked at some tracks.
Anyway, I would caution against stock struts with lowering springs and camber plates unless there are some out there that don't reduce available bump travel.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Old 02-19-2020, 11:16 AM   #11
There are some but you'll raise the ride height.
- andrew
Old 02-19-2020, 11:26 AM   #12
Can be a variety of different things. We've seen plates that are too tight. Also seen this happen from contamination leading to binding. PM me and we can probably figure it out.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
Fred E (02-20-2020), Leonardo (02-19-2020), Tristor (02-20-2020), wparsons (02-20-2020)
Old 02-19-2020, 11:41 AM   #13
wolffbite
Just the tip
wolffbite's Avatar
Thanks for the info.
From my understanding a camber plate will also introduce some NVH, and I have reverted back to stock on a couple of my last mods due to too much added NVH in the cabin.
I might try out the pedders mounts. Since I drive ~20k kms a year I could pretty quickly provide some long term feedback. If they become noisy again, I may just have to live with it.
The Following 3 Users Say Thank You to wolffbite For This Useful Post:
Leonardo (02-19-2020), Racecomp Engineering (02-19-2020), wparsons (02-20-2020)
Old 02-19-2020, 01:33 PM   #14
norcalpb
norcalpb's Avatar
I’ve had my Pedders top hats for 15k miles and no issues/noises. I can’t recommend them enough.
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
Leonardo (02-19-2020), wolffbite (02-20-2020), wparsons (02-20-2020)
Suggestions on spring rates GrabTheWheel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-10-2019 02:51 PM
Suggestions on suspension upgrade over BC Lakitu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 86 09-06-2018 09:42 AM
Wheel Color Change... Suggestions? srizzors25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-25-2015 03:49 PM
DFW Spring cruise 2015 planning route! Open to suggestions! carbonBLUE Southwest 101 04-27-2015 09:47 PM
suspension suggestions please teamred Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-13-2013 09:00 AM
