Old 02-17-2020, 10:13 AM   #1
HaXx
Drives: jrsc_brz
TYC Colin jdm tails build thread
Ive come into possession of seemingly the hardest to obtain tail lights for the frs/brz. the TYC Colins. there are more expensive custom show lights out there, but you can buy those if you have the money. these, you cannot just buy even if you have the money. i feel like it is my responsibility to bring these back to life. when they are finally ready for use, i think it would be interesting to have a documented build thread for them.
The previous owner butchered these trying to take the lens off himself, and seemingly cut the lens off. they are mirror finish, and he opened one up and scratched the mirror finish off, leaving it trashed. I presume it will need 2 oem clear tail light lens's, and the housing to be heated and the residual glue be carefully removed
i have reached out to many companies specializing in lighting, as well as forum members here i know are retrofit guru's, inquiring about their interest in taking on a special project.
TYC is a company that makes OE replacement lights. if you search tyc frs tail lights, the oem tails will come up. but the colins are another story. their original quality is that of eom.
HaXx is offline   Reply With Quote
Old 02-17-2020, 10:45 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Good find! best of luck bringing these back. If you don't have it already, look for Dremel attachments that have the conical buffing pad; it works super well for plastic corners.
I've restored OEM headlights, but I don't think I'd ever bother with taillights, I don't care how rare they are. Excited to see how much you are able to do for them!
HaXx (02-17-2020)
Old 02-17-2020, 11:27 AM   #3
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Dang those are rough.
Maybe transfer the guts into an OEM and tint the inside to a mirror finish?
Clueless
YamahaR86 is offline   Reply With Quote
Old 02-17-2020, 11:47 AM   #4
HaXx
Drives: jrsc_brz
i didnt really mention this, but i am not going to be the one doing the work. this is way over my head. ill be sending it to the pros to do. ive already found out a little about them. apparently they are plactic welded lenses, so you do in fact have to cut the lens off, then plastic weld it back together.
The Following User Says Thank You to HaXx For This Useful Post:
DarkPira7e (02-17-2020)
Old 02-17-2020, 12:09 PM   #5
DarkPira7e
DarkPira7e's Avatar
Regardless, it's an impressive task to take on! All the OEM style taillight lenses are plasti welded; it's a really obnoxious affair to separate them. I'm sure they did it due to the amount of water and humidity the rear sees from the roof sipes.
Excited to see them all done!
Old 02-17-2020, 08:57 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
all oem tails are plastic welded. it has something to do with the lack of serviceable parts inside.
i highly recommend you discuss with the pro's you're talking with to update the led's to lumiled superflux where ever possible. the 5mm led design these use has inherently poor thermal dissipation, which leads to an untimely death of the led's...
Old 02-18-2020, 12:26 PM   #7
Chuckls
Moutain Runner
I have a pair of red TYCs that I may sell soon. Going back to OEM.
Chuckls is offline   Reply With Quote
Old 02-18-2020, 12:44 PM   #8
HaXx
Drives: jrsc_brz
no lie, put them up soon bc you can get a premium for them, it may take a long time to find someone who realizes what they actually are, but those people are out there.
Old 02-18-2020, 12:57 PM   #9
HaXx
Drives: jrsc_brz
absolutely brutalized. the internals are fine, thankfully, and the passenger is great, but the driver side is ugh. so far there is company that says no prob we can do it.
it seems the options are: open both up and put clear lenses on both, or option 2: leave the passenger side alone then mirror an oe lens and put that on the busted one
WTB Colin Tails 207sw20 Want-To-Buy Requests 0 05-29-2018 12:39 AM
FS: TYC Colin red LED tails. myusernameisrob Exterior Parts (Aero, Lighting, Etc.) 5 08-18-2014 07:26 PM
New Colin Tails! - MIRROR CHROME JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 29 06-20-2014 12:21 AM
TYC Colin Smoked Tail Lights | Stock FRS Tails | Stock FRS Reverse Bar BumpersFRS Exterior Parts (Aero, Lighting, Etc.) 1 01-11-2014 03:42 AM
colin smoked tails Area51 Exterior Parts (Aero, Lighting, Etc.) 5 07-30-2013 11:15 PM
