Old 02-16-2020, 01:07 AM   #8891
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by jflogerzi View Post
Getting the car finally dynoed on Monday along with a fuel pump upgrade and port injectors. Current tune is pretty maxed on fuel system and I want safety when out on track. I am hoping I see around 100-125whp more than a stock car on their Dyno. Anyone want to take bets?
What kind of dyno?
What is the baseline?
With your setup 70% gain over stock should be achievable.
Old 02-16-2020, 01:20 AM   #8892
jflogerzi
jflogerzi's Avatar
Originally Posted by 86TOYO2k17 View Post
What kind of dyno?
It's not quite heart breaker but it's still lower than most. I believe a stock puts down 150-155whp on this Dyno.
2013 Series 10 FRS #553
Old 02-18-2020, 11:56 PM   #8893
jflogerzi
jflogerzi's Avatar
Here is the final numbers. Gained about 10-12 whp and wtq with extra fueling head room from bigger injectors and fuel pump plus I have a big safety net with capacity left. With stock I was left not much of a safety net. So this is a bit of a heart breaker Dyno as it measures direct at the hubs. Standard Dyno jet numbers put me right at 300whp and 250wtq. Super smooth curves.
The lower lines are a stock brz from another customer. Temps and other variables were really close.
Old 02-19-2020, 12:49 AM   #8894
86TOYO2k17
Attachment 184935
I said 70% over baseline, was right on the money 69.5% increase over baseline.
On a 168whp baseline would be 285whp. You’d need a really generous dyno to hit 300whp. But regardless it’s just a number. 70% increase is really the most i would expect from this kit without head work. So your definitely maxing her out.
Now for the important question. What is your peak ignition timing at WOT? Curious how close i am on 92+wmi vs your E85. Been debating of running E45-50 +wmi if i can get another 2.5-3 degrees of timing out of it could be another 10whp.
Did the pump/injectors enable more power somehow? or was it just the custom tune on the dyno being more dialed in then a safeish E-tune?
Old 02-19-2020, 02:36 AM   #8895
BlankHugs
Drives: '13 brz limited
just got my kit delivered today but all wasnt perfect. upon checkin' the kit, i found that the coolant reservoir bottle was cracked at the top and the bypass valve hose is kinked/torn. the reservoir im not too worry about for now since i believe can run the kit without intercooler and replace it later. but the hose is what im more worry about. since from the hour or so research ive done, i think i have to order a new valve just for hose or make my own.
BlankHugs is offline   Reply With Quote
Old 02-19-2020, 03:20 AM   #8896
kev0
Drives: '14
Well, the good news is that since the kit is not on the car yet, it is extremely easy to replace that hose. The bad news is that I don't know where you can get a replacement hose. Hardware stores might carry em around.
Please call 1-855-591-2778 and press the number for Technical support. The guy that picks up is very knowledgeable. Email is technical@sprintexusa.com if you prefer that, but they take a while to respond.
Btw, I purchased a direct replacement bypass valve from them and it did not come with a hose. I still have it new, never installed laying around in case anyone here is looking for one.
kev0 is offline   Reply With Quote
Old 02-19-2020, 09:28 AM   #8897
jflogerzi
jflogerzi's Avatar
Let me ask the tuner on timing. It was a bit of both I think for the extra HP. We did 13 revisions on the etune and basically maxed out fuel on stock injectors. So with bigger port injectors and larger fuel pump he gained some but also being able to fine tune things on the Dyno helped.
Old 02-19-2020, 09:31 AM   #8898
jflogerzi
jflogerzi's Avatar
I have a few spares. If you need 1 and can't get it by itself lmk.
Old 02-19-2020, 09:58 AM   #8899
86TOYO2k17
You can just do a 3rd gear pull to redline and datalog it. Can get timing off that. Unless it’s easier to ask tuner
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
jflogerzi (02-19-2020)
Old 02-21-2020, 02:44 AM   #8900
BlankHugs
so i noticed that my bypass valve isnt "connected" to the backin' plate like the others ive seen. i can put it back on it and its clicks into place but i think it will come off once in use. the nubs seem to have semi smoothed out somehow durin' shipment. please tell me i dnt have to buy a new one when its actually new anyways...
Old 02-21-2020, 02:52 AM   #8901
kev0
Drives: '14
You talking about the white 'connector' attached to the clear tube connecting to the TB? Mine slides too, I think that's by design.
Old 02-21-2020, 03:01 AM   #8902
BlankHugs
oh no not that. talkin' bout what the lever is connected to.
Old 02-21-2020, 03:23 AM   #8903
kev0
Drives: '14
wow, I completely missed that. That's crazy. This is a brand new kit right? This is totally unacceptable. Sprintex themselves should be able to replace it for free.
Old 02-21-2020, 03:36 AM   #8904
BlankHugs
yup brand new. i emailed them then called them to explain more in detail bout my problem. but since it was damaged durin' shipment i would have to pay for the new parts they said.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
