Old 01-27-2020, 07:23 PM   #435
Found Payload's car.
No. All he has is an upgraded fuel pump. That and 2 injectors per cylinder are all that are needed to unlock the hidden 300HP.
KR-S (01-27-2020), soundman98 (01-27-2020)
Old 01-27-2020, 07:50 PM   #436
soundman98
ProCrastinationConsultant
soundman98's Avatar
the term used to be "looks like a jc whitney catalog threw up all over it"
this car, the term is "looks like ebay threw up all over it"
the only thing that will save us is what that drivers side impact airbag is going to do to that universal fitment gauge pod...
KR-S (01-29-2020)
Old 01-27-2020, 09:15 PM   #437
Lantanafrs2
Drives: 2013 frs red
Put it through the driver?
Lantanafrs2 is offline   Reply With Quote
Old 01-28-2020, 06:39 AM   #438
1) There is no airbag since they are for pu55ies
2) If that car hits the streets at all then it doesn't go more than 5 mph so nothing will get dirty
3) The car can not go fast enough anyway since there is so much down force the wheels couldn't turn.
korhun (01-28-2020), p1l0t (02-13-2020), soundman98 (01-28-2020)
Old 02-13-2020, 09:37 AM   #439
Was very slushy on the highway today About half way to work my window washer fluid started to act weird. Was coming out in small spurts and then nothing even though I could hear the pump working. Tried pulling the stalk harder and that seemed to work a couple of times but then noting at all came out.
Anybody know what could be wrong?
NO REPLIES from California or Florida are required since you have no clue what I am talking about anyway.
Boomerang (02-14-2020), korhun (02-13-2020), NoHaveMSG (02-13-2020), p1l0t (02-13-2020), ROFL it's Waffle (02-13-2020), soundman98 (02-13-2020)
Old 02-13-2020, 10:25 AM   #440
p1l0t
p1l0t's Avatar
Do you REALLY need to change the oil filter EVERY oil change?
The Following 3 Users Say Thank You to p1l0t For This Useful Post:
korhun (02-13-2020), Tcoat (02-13-2020), Ultramaroon (02-13-2020)
Old 02-13-2020, 10:39 AM   #441
Don't think there is an oil filter on these. I have looked all under the car and not been able to find one if there is.
bcj (02-13-2020), Dadhawk (02-13-2020), p1l0t (02-13-2020), soundman98 (02-13-2020), Spuds (02-13-2020), Ultramaroon (02-13-2020)
Old 02-13-2020, 12:57 PM   #442
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
I think you're confusing the turn signal stalk. If you yank too hard on that piece, you will invert your signals. Try the other side.
Sent from my Pixel 2 using Tapatalk
ROFL it's Waffle is offline   Reply With Quote
Old 02-13-2020, 01:04 PM   #443
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have been reading about our car. They say it has a low cog. I googled "cog" and it looks like a gear. I want to lower my car, but after reading about the low cog, I am worried about scraping it.
Question: How much can I lower before I scrape the cog gears?
I LIKE TIRES!
The Following 4 Users Say Thank You to Leonardo For This Useful Post:
Dadhawk (02-13-2020), p1l0t (02-13-2020), soundman98 (02-13-2020), Will BRZ (02-13-2020)
Old 02-13-2020, 01:08 PM   #444
Well that isn't very helpful. I am not an idiot I know which side to use. If you can't ell my why none is coming out then just do say anything at all. It is people like you that ruin the forum for us guys that just want help.
Leonardo (02-13-2020), ROFL it's Waffle (02-14-2020), Will BRZ (02-13-2020)
Old 02-13-2020, 01:17 PM   #445
ROFL it's Waffle
Given the location of the cog, the mounts are actually at the center of the car, that's what makes it 50:50 weight distribution. The cog itself is located at the back. You run the risk of scraping it when you pop a wheelie. The so-called torque dip is caused by the cog scraping the ground.
The Following 3 Users Say Thank You to ROFL it's Waffle For This Useful Post:
korhun (02-13-2020), Leonardo (02-13-2020), soundman98 (02-13-2020)
Old 02-13-2020, 01:19 PM   #446
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks!!!!
We should ask the admin to make this a sticky. I couldn't find this info anywhere! And I looked for like 30 whole seconds.
I LIKE TIRES!
korhun (02-13-2020), soundman98 (02-13-2020), Spuds (02-13-2020), Will BRZ (02-13-2020)
Old 02-13-2020, 01:34 PM   #447
Thanks!!!!
Leonardo (02-13-2020), Spuds (02-13-2020)
Old 02-13-2020, 10:06 PM   #448
soundman98
soundman98's Avatar
no joke, when i switched from driving a '94 suburban(twist the turn signal), and a '96 ranger(push the end of turn signal) to a '01 eclipse(pull the right-side stalk), i actually took the fluid bottle out and tested the pump because i was convinced it was defective.
and then while putting it back in, figured out there was an entire other stalk that does all that...
2grandjunkheader, acab, fuckyourcsgbrakepads, icantseemybrakepads, tipcsgmikewithbitcoin
Trolling djdnz Site Announcements / Questions / Issues 85 03-31-2013 04:32 PM
Trolling Lonewolf Site Announcements / Questions / Issues 25 07-13-2012 08:25 AM
look what i found whilst trolling seek Calais AUSTRALIA 5 10-19-2010 07:53 AM
