Old 02-09-2020, 12:58 AM   #1
doodoobrown
doodoobrown's Avatar
What Sway Bars Work Best For You?
Just curious what everyone’s been liking for the track?
I’m running Perrin 22mm front SBs and stock rears but I’m running into understeer (I’m sure there’s driver error too). Thinking of going back to the stock fronts.
doodoobrown is offline   Reply With Quote
Old 02-09-2020, 11:02 AM   #2
femaledog
Drives: 2017 BRZ Perf. Pkg.
This is a boring answer but I have the stock bars front and rear. Seems fine to me.
I'm using RCE SS1s.
femaledog is offline   Reply With Quote
Old 02-09-2020, 11:10 AM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
hotchkis adjustables.With lowering springs and sticky tires the stockers just didn't cut it for me
TommyW is offline   Reply With Quote
Old 02-10-2020, 07:10 AM   #4
steverife
Drives: 2016 Scion FRS
Driver inputs, tires, and alignment are going to play huge roles in mitigating understeer.
steverife is offline   Reply With Quote
Old 02-10-2020, 02:31 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Depends on your driving style, habits, and other car setup.
Generally speaking if you touch only the swaybar, you get a stiffer rear bar to address front understeer. Adding a stiffer front bar to an understeering car will make understeer worse
EndlessAzure is online now   Reply With Quote
Old 02-10-2020, 03:04 PM   #6
Racecomp Engineering
We've used OEM 18 front 14 rear, Whiteline 20 front 16 rear, Whiteline 22 front 16 rear, Whiteline 20 front stock rear, RCE 25.5 front and 18 rear (hollow, so really 22 front 16 rear).
All can work well depending on the rest of the suspension, the tires, and the application.
- Andrew
Racecomp Engineering is online now   Reply With Quote
Old 02-10-2020, 03:04 PM   #7
double post. this forum has some issues lately amirite?
Old 02-10-2020, 07:50 PM   #8
TommyW
TommyW's Avatar
- Andrew
THIS
Old 02-10-2020, 10:40 PM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Good alignment will do wonders for understeer, lots run 22mm sway up front with success but if the rest of the suspension is stock then I'd guess the 22mm bar is over kill and you'll benefit from going softer.
ineedyourdiddly
Old 02-11-2020, 08:03 AM   #10
M0nk3y
- Andrew
What Andrew said, it's all dependent on your setup.
I personally ran a Perrin 22mm before up front with Mann Engineering Rear bar. Now I have a Karcepts Front Bar. I like adjustability
Kyle H. - #89 STX
Old 02-12-2020, 04:37 PM   #11
prandelia
Drives: 2015 FRS
The more spring you have, the less bar you need. Auto-x'ers and casual track tend to be softly sprung and use more bar, race cars are a lot stiffer and need less bar.
I'm on 700/900# springs, and only need a 20mm front, 16mm rear bar setup. Works perfect, same size as TMG racing cars in Germany.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Old 02-12-2020, 04:56 PM   #12
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Because I have Coilovers 5k Fr, 5k R and my car is ~450 lighter I went with softer Sways from Cusco. Helps the suspension to act more independently.
If I were to go larger I would consider the Tanabe Sustec which are only a hair heavier than stock due to material and hollow
SuperTom is offline   Reply With Quote
Old 02-12-2020, 05:13 PM   #13
strat61caster
5k is softer than some lowering springs...
ineedyourdiddly
Old 02-12-2020, 06:18 PM   #14
SuperTom
SuperTom's Avatar
Stock is 2.3K Fr, 3.3K R. So stiffer but not too stiff.
WTB Sway Bars MrAsh2222 Canada Classifieds 4 03-24-2019 03:19 PM
FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars armyoffoo Brakes, Suspension, Chassis 10 08-08-2018 08:28 AM
WTB F&R sway bars blkmamba Canada Classifieds 1 06-04-2017 02:15 PM
FR-S stock sway bars compared to TRD bars babydriver Scion FR-S / Toyota 86 GT86 General Forum 3 12-01-2014 09:12 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
