Old 01-24-2020, 09:37 AM   #351
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by Code Monkey View Post
The RacerX RUCA's are super easy to install. The initial alignment is a bit of a pain because to change camber you need to pop out the rod end to turn it and not many alignment shops want to do it. My shop checked the rear camber and I went back home to adjust one side, and then came back for a full alignment. They did not charge me for the initial check although I tipped the alignment tech extra afterwards.
I may have to ask them. Im more or less hoping I could compare/measure up to the stock dimensions and just install them exactly as the stock ones measure up. Not messing with my current alignment settings which are just fine.
SuperTom is offline   Reply With Quote
Old 01-27-2020, 11:02 AM   #352
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Originally Posted by Takumi788 View Post
In the spirit of keeping this thread going:
Gutted headlights -2.3lbs./side = 4.6 lbs total.
Haha - I'm about to do the same thing
Joesurf79 is offline   Reply With Quote
The Following User Says Thank You to Joesurf79 For This Useful Post:
Takumi788 (01-27-2020)
Old 02-06-2020, 04:21 PM   #353
SuperTom
SuperTom's Avatar
Door Hinges .75lbs each
Wish I could find someone to make them out of aluminum for me since I have CF Doors
I did drill a big hole out of one of them. Only lost .2oz left the rest of them alone
Old 02-10-2020, 03:15 PM   #354
ML
ML's Avatar
Drives: 13 White MT FR-S
Just cut 3.5 lbs out of the dash support brace and 7lbs with taking the wipers out.
Old 02-11-2020, 11:46 AM   #355
Joesurf79
Joesurf79's Avatar
Shaving pounds
Gutted lights and fogged the inside of the lenses black, gutted the e-brake shoes, brackets, cables, etc. Ditched the hood latch stuff. Trimming down the splitter frame some for a lighter strategy. Pulled the calipers for a rebuild.
Up next - trim dash, new airdam and a fresh splitter. Then build a ballast box so I can add just enough weight back, but where I want it to be
The Following 2 Users Say Thank You to Joesurf79 For This Useful Post:
SuperTom (02-11-2020), Takumi788 (02-11-2020), why? (02-13-2020)
Old 02-11-2020, 12:27 PM   #356
SuperTom
SuperTom's Avatar
Any pics of your dash brace? I attempted this last year and ended up taking too much off the "pole" that runs across, making it too easy to bend.
Im guessing leave the pole alone and take some of the steel around the steering column attachment area?
Old 02-11-2020, 12:29 PM   #357
SuperTom
SuperTom's Avatar
Wish I could delete my ebrake, But I park on a steep hill. I guess I could keep a wheel chock with me
Old 02-11-2020, 12:31 PM   #358
Joesurf79
Joesurf79's Avatar
I forgot the first few times I backed out of the garage and wanted to leave the car running before pulling on the trailer. A size 11 Hoka running shoe placed just under the door sill stopped it from rolling away till I could grab a chunk of 2x 12 haha!
Borrowed some scales from a friend. will weight it tonight and get a feelz for how much ballast I'll need to run TT5. Then weld up a ballast box accordingly
why? (02-13-2020)
Old 02-11-2020, 12:37 PM   #359
SuperTom
SuperTom's Avatar
Posted this in my build thread but Ill add it here since its about weight.
Swiss cheesed all the steel up front (not connect to suspension)
-Fender rails, Headlight buckets, Radiator/Hood T
Only got out a 1lb though after a lot of drilling.
Before
After
Also took off the 2 black covers for the airbag sensors and just mounted the sensor. My airbags are gone so eventually I will take out the wiring.
Removed bracket for outside temp sensor and pushed it into radiator slot
And went down to one horn that saved 1.25lb
The Following User Says Thank You to SuperTom For This Useful Post:
why? (02-13-2020)
Old 02-11-2020, 12:44 PM   #360
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Your dedication is impressive! thanks for posting the pictures!
I LIKE TIRES!
Old 02-11-2020, 03:17 PM   #361
ML
ML's Avatar
I drilled 7 holes, and cut 4 of the brackets off that aren't holding anything anymore.
The Following 2 Users Say Thank You to ML For This Useful Post:
new2subaru (02-16-2020), SuperTom (02-11-2020)
Old 02-12-2020, 10:58 PM   #362
ML
ML's Avatar
replaced the third brake light with a led strip. probably good for a pound or so haha
hedtrip (02-18-2023), why? (02-13-2020)
Old 02-18-2020, 04:52 PM   #363
ML
ML's Avatar
1 lb
The Following User Says Thank You to ML For This Useful Post:
SuperTom (02-19-2020)
Old 02-18-2020, 05:11 PM   #364
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Are you guys sure that you don't sacrifice on chassis rigidity with all this drilling?
diet, heavy, light, reduction, weight
So what is the official weight? brillo Scion FR-S / Toyota 86 GT86 General Forum 76 05-03-2020 05:11 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
2012 Geneva - Toyota GT86 in Black, Blue, White, Orange. Official weight & 0-60 Shown Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 124 05-28-2012 12:20 PM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) — General Topics 50 02-08-2012 02:04 AM
