Old 02-08-2020, 03:21 PM   #66291
My head hurts, I can't put 2 and 2 together.. I need to do a @humfrz or something..
Try this - then you just won't give a rip anymore -
humfrz is offline
Old 02-08-2020, 03:32 PM   #66292
JD001
JD001's Avatar
Drives: Subaru BRZ
Does it involve a doctor's appointment/prescription?
JD001 is offline
Old 02-08-2020, 03:36 PM   #66293
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Nah dude that is a common baseboard heater which outstrips heat pumps by a long shot. Just because your house hunting is in expensive areas doesn't make heat pumps more common. And who the hell uses "domicile" in normal conversation?
It's pretty common in many grades of homes around here, not just expensive ones.
I have a friend that uses "domicile" in normal conversation and thought it would be fun to try it out lol. He's a software engineer though, they be strange folk...
Wait, what?
The expanding gas from combustion is what is used to produce motion, heat is a byproduct of having to use combustion.
IE you can use compressed air to turn over an engine, you can't turn over an engine by just introducing more heat into the system.
I mean heat is what typically causes a mass of molecules to expand in volume except in a few specific cases.
And if you want to get molecular...
Heat is what raises the temperature (kinetic energy in random directions) of the gas molecules in chamber. Those molecules bounce off each other and the walls of chamber, imparting some of their energy to whatever they hit, thus increasing the block/cylinder temperature (yes, solid molecules vibrate against other molecules in the solid). The average force of molecules hitting against a surface area is what we call pressure. As the pressure in the chamber increases, due to the increase in temperature, the piston has enough total force to overcome any resistance to motion and achieves a unified kinetic energy vector, along with all the objects it is attached to (such as a vehicle drive train).
Spuds is offline
Tcoat (02-08-2020), Ultramaroon (02-08-2020)
Old 02-08-2020, 03:48 PM   #66294
Yes, unless you get it from the Indian medicine man, down on the reservation. -
humfrz is offline
JD001 (02-08-2020)
Old 02-08-2020, 03:49 PM   #66295
Electric heat (not heat pumps) is one of the big contributors to the circle of poverty that low income people battle all the time. It is relatively cheap and easy to install in low income housing so is used extensively by landlords and low end builders. It is however much more expensive to run since it is incredibly inefficient but they don't care about that part since that is not their problem. People end up paying so much more than other fuels that they get stuck in the same sort of place
Sooo.... in the end it is still the expanding gas not the heat that is creating the pressure.
Tcoat is offline
korhun (02-10-2020), NoHaveMSG (02-08-2020), soundman98 (02-08-2020), Spuds (02-08-2020), Ultramaroon (02-08-2020)
Old 02-08-2020, 05:04 PM   #66296
Wait, what?
Spuds was making the thermodynamic distinction between transducers and engines. You guys are both on point-ish. All heat engines are turned over by simply introducing heat into them. The difference is in how that heat is introduced. An electrically heated Stirling engine is still a heat engine because it converts heat to work. An electric motor is a transducer because, while the process does involve transfer of heat, it does not rely on it.
Ultramaroon is offline
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
humfrz (02-08-2020), korhun (02-10-2020), NoHaveMSG (02-08-2020), Spuds (02-08-2020)
Old 02-08-2020, 05:53 PM   #66297
Originally Posted by korhun View Post
As far as I know, where I live, this is the list of ways to heat our houses, sorted by most expensive to least:
* Electricity
* Fuel-oil (it's a kind of petrol, they call it like that here..)
* Natural gas
And this is the list of ways to move a car, sorted by the most expensive to least:
* Diesel and petrol
* Natural gas
* Electricity
Electricity is best in one, worst in the other. Why?
I hope this is not a very stupid question, and I'm not wrong about the sort orders.
Heating a house is direct heat transfer. Moving mass is work. Both are measured in the same units.
The cost per unit of chemical energy available from hydrocarbons is still way way cheaper than it is to buy the same quantity directly from the grid.
It's easy to get pretty decent efficiency out of a gas or oil furnace so it's cheaper than heating up wires.
Efficiency of the most amazingly modern internal combustion engines will always compare horribly to that of typical electric traction motors.
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
humfrz (02-08-2020), korhun (02-10-2020), NoHaveMSG (02-08-2020), spike021 (02-08-2020), Spuds (02-08-2020), Tcoat (02-08-2020)
Old 02-08-2020, 06:18 PM   #66298
Spuds
The Dictater
Spuds's Avatar
^^^ what he said.
Spuds is offline
The Following 3 Users Say Thank You to Spuds For This Useful Post:
korhun (02-10-2020), Tcoat (02-08-2020), Ultramaroon (02-08-2020)
Old 02-08-2020, 09:34 PM   #66299
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I like toasted tuna sandwiches.
Sapphireho is offline
The Following 6 Users Say Thank You to Sapphireho For This Useful Post:
Dadhawk (02-09-2020), korhun (02-10-2020), NoHaveMSG (02-08-2020), soundman98 (02-09-2020), Ultramaroon (02-08-2020), Will BRZ (02-08-2020)
Old 02-08-2020, 10:15 PM   #66300
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Honestly I didn't read his whole post. Just catching that part made "heat" look odd as an explanation and with more context makes sense. Believe it or not I do understand above 6th grade science
All sandwiches should be toasted
NoHaveMSG is offline
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (02-09-2020), korhun (02-10-2020), Sapphireho (02-09-2020), Ultramaroon (02-08-2020)
Old 02-08-2020, 10:27 PM   #66301
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Have all the BRZ owners gone away?
Lost most of us due to using bootlegged vape cartridges
The Following 6 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (02-09-2020), Sapphireho (02-09-2020), ScoobsMcGee (02-10-2020), spike021 (02-09-2020), Tcoat (02-08-2020), Ultramaroon (02-08-2020)
Old 02-08-2020, 10:33 PM   #66302
Of course! I immediately saw both of your points including your justified interpretation of his. It's also the first time I've tried to explain it without using maths.
I got you guys!
Old 02-08-2020, 10:34 PM   #66303
#metoo
Dadhawk (02-09-2020), korhun (02-10-2020), NoHaveMSG (02-08-2020), Sapphireho (02-09-2020)
Old 02-08-2020, 11:06 PM   #66304
Trade embargo on flat brimmed caps?
Tcoat is offline
Dadhawk (02-09-2020), NoHaveMSG (02-08-2020), p1l0t (02-08-2020), ScoobsMcGee (02-10-2020)
