Old 02-05-2020, 04:54 PM   #1
Inteze
Drives: Toyota GT86
Bad CV Joint or Bad Axle Nut ?
Hello guys, I am new to this forum and still kind of lost so bare with me, thanks
So I have this bad clicking while driving with my GT86, it comes from the back/driver side. From what I've been reading online this could be a bad CV Joint or a loose Axle nut... What do you think could this be ? (SEE VIDEO)
More details :
- It does not clunk while turning sharply as seen/heard on some youtube videos showcasing a Bad CV Joint.
- Clicks while decelerating from FOR EXAMPLE 4k RPM
- Disappears while accelerating
- Clicks louder while turning slightly to the right, doesn't click when turning left
- But also clicks while decelerating on a straight line (as you can see on the video)
THANK YOU
VIDEO :
Inteze is offline   Reply With Quote
Old 02-05-2020, 05:44 PM   #2
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Your car seems kinda new to be having problem with the CV axle. Have you tried torquing down the axle nut? While you are down there, check to see if any of the grease liquified and escaped the CV boot's seal.
Take it in for warranty. Your car is way to new to be having issues with the CV joint. Unless your car took some damage hitting something hard at the wheel.
Intent > Content
Old 02-05-2020, 06:02 PM   #3
Inteze
Drives: Toyota GT86
Yes I am going to check the Axle Nut... I hope it's that, not looking forward in buying a new axle...
Old 02-05-2020, 07:25 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
A bad cv joint is easy identified by looking at them underneath the car.
The axle nut is only one that needs to be replaced and torque down.
I would always start with the cheapest parts to replace. Thus buy yourself a new axle nut.
Also you don't need to buy a whole new axle if the cv joints are bad. You can just rebuild them. Just look for any tranny shop or axle shop. It's an odd find but they are there.
Old 02-05-2020, 10:12 PM   #5
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Do you have hub rings? I had a similar issue. It would only make random clicking noises on accel, decel or sharp turns at lower speeds. Never a constant click like a bad CV joint. I changed out the axle nuts and it still happened and there were no signs of failing CV joints. I installed a new set of hub rings last summer and the clicking stopped.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 02-06-2020, 02:00 AM   #6
Inteze
Drives: Toyota GT86
Hey, no I do not have Hub Rings :/ but thank you !
Old 02-06-2020, 02:01 AM   #7
Inteze
Drives: Toyota GT86
Alright, thank you
Old 02-06-2020, 09:31 AM   #8
Teseo
Drives: frs
Is the axle nut, re torque it
Old 02-06-2020, 02:45 PM   #9
Inteze
Drives: Toyota GT86
I really hope you’re right
What makes you think that it might only be the Axle Nut if I can ask?
Old 02-06-2020, 03:29 PM   #10
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
i had the same sound. I had to replace the axle... I would check the axle nut first... easy check to tighten it. if it's tight and still makes noise, you know to replace the axle. good luck.
pgranberg11 is offline   Reply With Quote
Old 02-06-2020, 03:50 PM   #11
Teseo
Drives: frs
Had almost identical sound, bough the nut brand new because i found it cheap and torque it on spec
Old 02-06-2020, 08:11 PM   #12
solidONE
solidONE's Avatar
According to my local Subaru parts counter guy, the axle nut on our car and many other subarus including the imprezza, tend to need to be replaced. Something about the metal being used being a lower grade, softer material. Breaking wheel studs and throwout bearings seems to be a common "subaru" thing as well apparently.
Having dealt with similar problems that was first remedied by torquing down the original nut, then replacing the nut and eventually replacing the driver side axle with a used one repacked with new grease. Repacking the grease is a good preventative measure if you're up to it. If you track the car, you'd better do it ASAP IMO. Axles going out isnt uncommon. Its just a matter of time. As for the axle nut, I suppose all we can do is check the torque periodically and replace when needed or retrofit a different brand.
If anything, take it to the dealer. Maybe you get a brand new axle for your troubles. Or just do it before your dirivetrain warranty runs out haha.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Inteze (02-07-2020)
Old 02-07-2020, 02:21 AM   #13
Inteze
Drives: Toyota GT86
Alright, I’ll be checking this asap
I don’t track the car, but will do the necessary to get it fixed!
Old 02-09-2020, 12:25 PM   #14
Inteze
Drives: Toyota GT86
UPDATE : Okay so the axles are fine, Axle Nut has been changed, Noise still occuring...
I have noticed one thing though, as you can here on the Video, the ticking comes from somewhere between the differential and the propshaft.
Little detail : The car does not seem to do the noise as soon as it rains....
VIDEO :
OEM U Joint Feel NoHaveMSG Engine, Exhaust, Transmission 11 02-13-2023 05:44 PM
exlpoded cv joint ben15r Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 09-01-2018 04:12 AM
bad CV joint? Atticus808 Off-Topic Lounge [WARNING: NO POLITICS] 26 08-26-2016 06:20 PM
CV joint problem? ButtonMasher Issues | Warranty | Recalls / TSB 13 05-22-2015 09:32 PM
JapanParts joint order? aznatama Mid-Atlantic 0 09-11-2014 04:35 PM
