Old 02-04-2020, 09:27 PM   #8877
kev0
Drives: '14
Silly question but how do you guys know when you're in boost? There's really no way to know unless you have a boost gauge, right?
kev0 is offline   Reply With Quote
Old 02-04-2020, 09:29 PM   #8878
86TOYO2k17
Drives: 2017 toyota 86
Stock map can read to about 5.7psi. So if no boost gauge. You can at least tell if your in “boost” just not if your making 6psi or 12psi.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
haute (02-04-2020)
Old 02-04-2020, 11:08 PM   #8879
haute
Drives: 37J
Thanks. Do you happen to know which option it is in Ecutek to see boost from stock MAP sensor? This is all I see and it isn’t it.
haute is offline   Reply With Quote
The Following User Says Thank You to haute For This Useful Post:
kev0 (02-04-2020)
Old 02-04-2020, 11:30 PM   #8880
86TOYO2k17
Scroll down. Should be Manifold Absolute Pressure under “m” section.
haute (02-05-2020)
Old 02-04-2020, 11:33 PM   #8881
86TOYO2k17
Why’d you make two accounts? @kev0 @haute
Old 02-04-2020, 11:50 PM   #8882
tomm.brz
Drives: brz 2017 hksv2
ecutek doesn't have Boost
but you can create one with a custom map that subtract the atmosferic pressure from the manifold absolute pressure
haute (02-05-2020)
Old 02-04-2020, 11:52 PM   #8883
jflogerzi
jflogerzi's Avatar
Gets the popcorn rdy...
2013 Series 10 FRS #553
Old 02-05-2020, 12:14 AM   #8884
haute
Drives: 37J
One account is for my Tapatalk app. I forgot the password for kev0 when logging into this app so I just made a new one.
Ty for help btw
Old 02-05-2020, 12:14 AM   #8885
86TOYO2k17
Yes, correct.
Ecutek map will read max 19.9 and subtract 14.7 atmospheric pressure. But regardless he should be making way more then 5.2psi but will never know without boost gauge. But just to tell if/when your hitting boost map reading 19.9 is good enough to tell you that if thats all you want to know.
Old 02-05-2020, 12:22 AM   #8886
haute
Drives: 37J
Ah it seems like I have it already. Reads more than 5.1 psi though. It read up to 10 at one point when I was going 8 mph. Seems like the boost is high for how slow I was going.
Old 02-05-2020, 12:31 AM   #8887
86TOYO2k17
Reread my last post. Subtract 14.7 from that number. It should read 19.9 at WOT. Which is 19.9-14.7= 5.2. Reading 10 - 14.7 = -4.7lbs so under vacuum or negative pressure.
Old 02-05-2020, 12:39 AM   #8888
kev0
Drives: '14
Oh okay. My bad. I read it too quickly. I assumed that EcuTek automatically subtracts 14.7. Ty!!
Old 02-13-2020, 10:57 AM   #8889
brybot
Drives: 13 DGM BRZ 6MT
IC kit for the 210 still for sale: https://www.ft86club.com/forums/show...49#post3288849
If anyone has thoughts on why I still have this thing, feel free to weigh in. Thought they were somewhat desirable.
brybot is offline   Reply With Quote
Old 02-15-2020, 11:08 AM   #8890
jflogerzi
jflogerzi's Avatar
Getting the car finally dynoed on Monday along with a fuel pump upgrade and port injectors. Current tune is pretty maxed on fuel system and I want safety when out on track. I am hoping I see around 100-125whp more than a stock car on their Dyno. Anyone want to take bets?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
