Old 02-04-2020, 07:30 PM   #66151
Originally Posted by Stephen W. View Post
Now, who can tell what these are?
Ineffective.
Ultramaroon is offline
Old 02-04-2020, 07:35 PM   #66152
p1l0t
p1l0t's Avatar
Originally Posted by korhun View Post
I've found a cheap exhaust system that makes you sound like... mmm... different
p1l0t is online now
Old 02-04-2020, 07:36 PM   #66153
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’m going to grab one of my bicycle tubes and do that to our shop truck
NoHaveMSG is offline
Old 02-04-2020, 07:36 PM   #66154
Um...
Old 02-04-2020, 08:05 PM   #66155
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Lol.
Reminds me of when my college friend put a tractor cap on his Jetta's exhaust pipe...
Spuds is offline
Old 02-04-2020, 08:07 PM   #66156
Was more like the 70s
And there were like two places that made them.
Welp, according to the Interweb, more like:
"The original cast magnesium wheels were made beginning in the 1930s".
"Richter purchased Cragar Industries in 1955 and set a goal of producing a stylish wheel design that met hot rodders’ needs".
"The popularity of magnesium wheels peaked in 1950 -1960".
I have no first hand knowledge because this ol farm boy from Ohio had to settle with just painting the OEM steel rims different colors. Not like the wealthy Canadian hot rodders up north who could afford "Mag" wheels -
humfrz is offline
Old 02-04-2020, 08:11 PM   #66157
Ineffective.
Maybe so, but I'll betcha one could easily see the pad thickness -
humfrz is offline
Old 02-04-2020, 08:17 PM   #66158
Um...
Hey, I suggest you go argue with the old man. I asked him after his nap if he wanted to respond. He said "I don't know what the hell you're ah talken about".
humfrz is offline
Old 02-04-2020, 08:27 PM   #66159
Ahhh be see now we are back into the whole nomenclature thing. The real magnesium wheels were popular through the 60s but well into the 70s we called any non stock wheel a "mag". They were probably mostly chromed steel but they were still "mags".
Actual mag wheels were dangerous as hell because if they caught fire they were almost impossible to put out and water just made them burn hotter and harder.
Tcoat is offline
Old 02-04-2020, 08:29 PM   #66160
Um...
Which part?
Dudes nickname?
The pastime mentioned?
$39 wheels?
All of it?
Oh wait I see.
So you point that out but ignore the points where they clearly call them "mags"?
Tcoat is offline
Old 02-04-2020, 08:53 PM   #66161
p1l0t
p1l0t's Avatar
Actual mag wheels were dangerous as hell because if they caught fire they were almost impossible to put out and water just made them burn hotter and harder."
I knew a girl like that once...
p1l0t is online now
Old 02-04-2020, 09:17 PM   #66162
Oh wait I see.
I remember calling them mag wheels as well as mags. It was more a point for humfrz and his rims.
[ame]https://www.youtube.com/watch?v=oShTJ90fC34[/ame]
Old 02-04-2020, 09:18 PM   #66163
ls1ac
ls1ac's Avatar
In the realm of useless information; in the early 60s a mag wheel plant in south Chicago got on fire. Fire dept. came and sprayed water on it, bad idea. then they thought foam would work, bad idea. Too much water to make the foam. Just sat around and watched it burn, well not looking at it because white hot and blinding bright.
So you might ask how do you put out a magnesium fire?
It turned out that UL had some experience and told the insurance carriers to require the company to hang burlap under the ceiling then plastic sheet covered with several inches of graphite. Flames were hot enough to burn the burlap, melt the plastic, and dump the graphite on the flames smothering the magnesium fire.
How about that for useless information.
Second piece of Useless , In 1968 a set of knockoff mag wheel for a racing MGBGT cost as much as the car. Always has been: How fast do you want to spend?
ls1ac is offline
Old 02-04-2020, 09:24 PM   #66164
Aircraft wheels... and the most dangerous thing about brake fires.
