#43 |
It is very nice.
#44 |
Drives: brz 2017 hksv2
what I don t get it is, if something caused the values to drift from factory values... how could that be OKed by the Ecu in first place? and then not be OKed if they drift back to factory?
I would like to see those stored value in my ecu with techstream but I do not understand where to see them |
#45 |
Do I have to read the vvt initial value with techstream with IGN ON with engine off, or need to turn on the engine?
God I hope they are ok, i don t know where to find a used ecu and i'm afraid of my ecutek license I also don t understand how to be sure a new ecu will have the stored values that will be ok for it to work.. it amazes me there isn t a wait to fully reset them Last edited by tomm.brz; 02-03-2020 at 06:10 AM. |
#46 |
f*ck it.
I removed battery, i reflashed, performed a cold start.. vvt didnt enable i did the procedure that was posted in the previous page (10 sec idle, 20 sec 97km/h ecc ecc) vvt didn t enable i drove out of the highway, while in neutral I screamed super loud and jumped on the throttle on rage..... it activated. God I hate subaru but now it works |
| The Following 3 Users Say Thank You to tomm.brz For This Useful Post: |
#47 | |
![]() See also the very last step at the bottom of this page in the service manuals.
#48 |
So this morning started the vvt
then i turned off and now again it doesnt work )) I managed to check with techstream it gives me correct values around 90 in exhaust and 0.0/0.0 in intake, and that was after i shut down the engine when vvt was working i started again, vvt never activated, same initial values then i flashed again and checked immediatly and now it gives me 0.0 in every 4 values So i dont think they are irremediably stuck in those values as you say? a reflash should reset them I think toyota says to replace Ecu if the values are wrong because Techstream never allowed to reflash an ecu, only to upgrade, if an upgrade is available Anyway i'll try again tomorrow morning, somehow the cold oil makes my vvt activate I'll also check all the connectors of the cam sensors and OCV, maybe something is loose Do you think it s possible to perform the vvt active test even if vvt is disabled? Last edited by tomm.brz; 02-03-2020 at 04:33 PM. |
#49 |
Drives: Toyota 86
I forgot to mention this. Both intake cam gears were fixed before AVCS is working again.
Even with those small covers detached no DTC came in. It is most curious part indeed. One gear was replaced with new one, another was only hammered on the both sides of the cover.
| The Following User Says Thank You to makinen For This Useful Post: | Ultramaroon (02-04-2020) |
#50 | |
I would do the same thing, just peen the plate back in place.
#51 | |
My Vvt angle from logs keep staying at 0 when oil is warm and vvt doesnt activate . Checking with techstream, it gives me correct values for exhaust but intake sides gives me 0.0 Do you think i have a problem to the cam gears? I had bent the cam intake shaft #1 and changed both the chains, but mechanic said the cam gear looked good so didn t change it first 40km after rebuild, the vvt intake #1 showed a noticeable swing around the target value of like +5/-5 around target... since it fixed itself, we supposed it was just like an air bubble around the cam gear but now i start to think it s a broken cam gear |
#52 | |
Drives: FT86
Since ecu is very easy to change, well much easier than pulling engine out and checking cam phasors. Id probably source another ecu and try that. I dont thing the vvt initial learn parameters burn in, i think it that the input or output chanels on the ecu that control the cams go bad, hence the ecu sees incorrect cam initial positions and hence doesnt activate vvt. Hopefully you have a tactrix to flash a test tune to replacement ecu, so you dont need ecutek licience |
#53 |
But when i first checked the VVT initial value it gave me 0.0 on intake side
but then the morning after (yesterday) it activated anyway after a reflash? Can it go bad and then suddenly works and then bad again? Today no luck, the vvt angle goes to 0 when oil is warm but doesn t activate.. they seem to move a little bit if i blip the throttle, like 1-2 degrees of movement but stay off i have a tactrix, but i Don t know where to source an ecm here in Europe, they seem all so expensive |
#54 |
![]() i tried the active test, i can change both exhaust cam on the fly with techstream, cam intake of course it gives me error |
#55 | |
Drives: Toyota 86
are looking good at least. Below is the log when AVCS is activated. Not by just only that engine braking, but several tried.
#56 |
i replicated your engine braking in 5th and then blipped hard and activated
i did video and a log I will soon post cam intake#1 oscillates a looooot and it s not smooth to drive when activates so i ll rule out an ecu problem Can be oil that became shitty and need to be changed? Now i have to drive home and unfortunately i do not have techstream with me to check the vvt initial value before cranking again, i think it will not activate vvt again now as usual |
| Edge Insight CS Monitor (1996 & Newer OBDII Enabled Vehicle) | FBPARTS | Exterior Parts - The Rest | 3 | 12-02-2015 04:08 PM |
| Album art enabled but not displayed (bespoke)? | Mexibeetle | Electronics | Audio | NAV | Infotainment | 7 | 01-22-2013 09:39 PM |
