Old 02-02-2020, 08:08 PM   #1
solidsnake11
Drives: brz
K24 swap pics, It runs off the BRZ brain!!! Video on page 4&7. VVT enabled now!
This thread has been Censored
solidsnake11 is offline   Reply With Quote
The Following 3 Users Say Thank You to solidsnake11 For This Useful Post:
DarkPira7e (02-02-2020), Irace86.2.0 (02-02-2020), PulsarBeeerz (02-02-2020)
Old 02-02-2020, 08:21 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'm super excited to see this!
solidsnake11 (02-23-2020)
Old 02-02-2020, 08:46 PM   #3
ML
ML's Avatar
Drives: 13 White MT FR-S
Finally got tired of the fa20 piling issues?
The Following User Says Thank You to ML For This Useful Post:
Old 02-04-2020, 09:29 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
So you didn't prepare the surfaces by removing paint? Did you remove the oil at least? Did you use a shielding gas on the inside of the pan? Considering the pan isn't structural and doesn't see high forces or pressures, you might be fine. Pics of the inside of the pan?
Old 02-05-2020, 12:16 AM   #5
Irace86.2.0
I would just be concerned with porosity on an oil container, but like I said, there is minimal risk of weld fracture from load, pressure, heat cycles, etc, so I’m sure your pressure test will work out.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 02-08-2020, 05:21 PM   #6
Grawlix
Drives: '14 fr-s \\ 6mt \\ white
Originally Posted by solidsnake11 View Post
Two intake cams. The BRZ computer needs both intake signals before it will fire and the exhaust signal can run from the crank since it pulses once every crank revolution.
What's your plan for the wiring/ecu(s)/CAN bus?
Grawlix is offline   Reply With Quote
The Following User Says Thank You to Grawlix For This Useful Post:
Old 02-08-2020, 10:13 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
Stock,stock and stock.
Going to use the brz computer, switch some coils, do some wiring, swap some sensors, 8 port injectors and my 76mm throttle body.
Look familiar?
Attachment 184657
Attachment 184658
Ok, that's fucking incredible. Are you doing the tuning yourself?
The Following User Says Thank You to Calum For This Useful Post:
solidsnake11 (02-19-2020)
Old 02-09-2020, 04:04 AM   #8
DIY
DIY's Avatar
Drives: BRZ, WRX
Great work!
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
The Following User Says Thank You to DIY For This Useful Post:
Old 02-09-2020, 01:01 PM   #9
Grawlix
...8 port injectors...
8 functional port injectors or 8 port injectors in the eyes of the BRZ computer?
Old 02-09-2020, 01:14 PM   #10
ML
ML's Avatar
So will you pass inspection if you get it working with the stock ecu? Or are you just track only these days? NC sucks for engine swaps on newer cars.
Old 02-11-2020, 12:02 PM   #11
fika84
fika84's Avatar
You're a mad man. Keep up the good work! FOR SCIENCE!
fika84 is offline   Reply With Quote
The Following 2 Users Say Thank You to fika84 For This Useful Post:
sato (04-14-2020), solidsnake11 (02-19-2020)
Old 02-11-2020, 01:15 PM   #12
Grawlix
4 port injectors ran by port injection drivers and 4 port injectors ran by the direct injection drivers.
Where will the 4 extras be installed?
Old 02-14-2020, 11:10 AM   #13
wparsons
wparsons's Avatar
Giving up VTEC? I can't imagine the stock BRZ ECU can handle swapping cam profiles.
flickr
Old 02-14-2020, 11:41 AM   #14
Ashikabi
Ashikabi's Avatar
Just use a vtec killer setup. Then you're always in vtec
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 06:31 PM
ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-21-2014 12:16 AM
Release Series 1.0 FR-S & FT-1 Pics from NYIAS (Warning: iPhone Pics) TM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 04-30-2014 04:31 PM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-12-2012 12:29 AM
