Tracking / Autocross / HPDE / Drifting What these cars were built for! |
01-30-2020, 10:18 PM | #1 |
Drives: 2013 FRS
Guidance on 6-point harness install
I have a full cage being installed. I am adding fixed bucket race seats with mounting brackets that include sliders. I have RaceQuip 6-point harnesses to install. The ends of the lap and crotch belts have the mounting plates with a hole. no clips.
Looking for some guidance on how anyone has dealt with the mounting, locations, and hardware used.
WIFE: "How can there be anything left to buy?"
01-31-2020, 10:54 PM | #2 |
Every Ounce Counts
Drives: 86
02-01-2020, 07:47 AM | #3 |
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Some seat mounts have a built in submarine belt attachment location otherwise you just have to drill into the floor sheet metal.
If mounting to the floor sheet metal a backing plate with nut should be used (this applies for the sub belts and inside lap belt). For the outside lap belt location use the factory seatbelt mounting hole to secure the belt as it’s already properly reinforced from the factory. You want the belts to rotate freely once secured, Schroth makes the proper hardware for this and the other items I mentioned. Honestly I prefer snap in type belts and using eye bolts to keep things moving freely but you’ve already purchased the belts so you can make it work just using regular bolts and special hardware. https://www.hmsmotorsport.com/products/hardware Note: follow the belt manufacturers recommended submarine belt mounting angle based on your seat location. |
02-01-2020, 08:40 AM | #4 |
Low-Buck Ramp Truck
Drives: 2016 Scion FR-S Release 2.0 #502
https://www.schrothracing.com/docs/C...structions.pdf
I mounted lap belts to the factory hole on one side and through the transmission tunnel on the other with a backing plate. Swivel hardware lets the belts move. Sub belts mounted to the seat bracket. I’m using PCI mounts which have holes designed to mount the sub belts too. Shoulders to a four point roll bar. It’s a test of patience for sure. |
02-01-2020, 11:33 PM | #5 |
Drives: 2015 Subaru BRZ Limited DGM
Which roll bar? Custom or off-the-shelf?
02-02-2020, 02:40 AM | #6 |
Low-Buck Ramp Truck
Similar Threads | ||||
Sold: 2x Cipher Racing Harness Set 4 Point 2 Inch and Harness Bar | siuhen | Interior Parts (Incl. Lighting) | 12 | 12-27-2014 09:38 AM |
6 point harness | Klaus Jia | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-11-2014 01:15 AM |
FS: Sabelt 6 point harness | Klaus Jia | Interior Parts (Incl. Lighting) | 0 | 10-09-2014 01:29 AM |
Seat sub mount bar for 6 point harness | philooo | Tracking / Autocross / HPDE / Drifting | 7 | 08-18-2014 11:20 PM |
4 point harness | BuhhDill | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-07-2014 12:12 PM |
