Old 01-29-2020, 01:33 PM   #1
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Subaru Outback Won't Drive
For a 2001 Subaru Outback Limited MT:
Though my dad has already moved on and bought a new car, the situation before it still bothers me a bit and makes me curious as to what the problem was.
A few weeks ago, my dad was driving home from work and started feeling like the cars front wheel (felt like it was front left) was wobbling, and pretty hard. He said he had to use quite a lot of force to keep the steering wheel straight. There was also loud clanking noises or something along the lines of what he described. He managed to take his time and make it home while on the phone with me. As we were driving it to the shop with me following him, I did not notice any wheel wobble or anything unusual from behind.
Moving forward, the shop calls him to tell him that his clutch is dead because the car wont move. So this is where I get curious. My dad replaced his clutch about a year or two prior to this incident, so I really have a hard time believing it has anything to do with the clutch at all. And regardless of that, the symptoms he described that his car was experiencing just don't seem to relate to the clutch.
What could have broken/disengaged/rusted off over night to where the car could no longer move the next day? I know the culprit of this is almost always a bad transmission or clutch, but could that really create the symptoms he was having? Or was it just such bad luck that at the same time as something in the suspension was going, the transmission went too?
Dzmitry is offline   Reply With Quote
Old 01-29-2020, 01:36 PM   #2
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
CV joints.
NoHaveMSG (01-29-2020)
Old 01-29-2020, 08:18 PM   #3
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Sounds like maybe a seized brake caliper piston.
Pulling to one side, wobbly (warped rotor), and then wouldn't "drive" because essentially the brakes were locked up.
During the drive, the overheated brake pad lost holding ability (brake fade) so he could continue driving.
That is a total guess based on the limited available information. Clutch could have been womped during the course of limping to the shop and having to use extra clutch scrub to get it going if the brakes were locking up.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following 3 Users Say Thank You to ActionMaxon For This Useful Post:
DarkPira7e (01-29-2020), Dzmitry (01-30-2020), Spuds (01-30-2020)
Old 01-29-2020, 08:29 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
As ActionMaxon said, clutch probably took a lot of abuse being slipped to move the car under brake load... I'm sure a caliper seized, the old Subarus are known for it
Old 01-29-2020, 08:31 PM   #5
These^
And the fact that it is a 19 year old car doesn't help.
Old 01-29-2020, 08:40 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sometimes clutches can die in a year. It's not common but it is possible
Back in the day ACT clutches where notorious for poor quality on brand new clutches lasting less than a year.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 01-30-2020, 08:30 AM   #7
Dzmitry
Dzmitry's Avatar
Interesting. Though I know that a caliper would cause these symptoms, I did not think of that being the issue at all. Thanks a lot guys! I'm gonna run back to that shop while it sits there and check it out. Fix it up and sell it for more than 250 which is what they're offering him to dump it lol. And The worst part is the engine in it was replaced about 90k ago due to a late oil change on regular oil, and quite a few other parts are fairly new. Thanks again for the info.
Old 01-30-2020, 10:53 AM   #8
What you have seen is just a small taste of how fixing a 20 year old car can just lead to a domino effect of failures. It isn't just a matter of replacing a couple of parts like repairing a newer car but can become a total restoration project that soon becomes a money and time pit. There is a whole different level of dedication when you start working on older vehicles like this and a quick, cheap, flip is a rarity no matter how easy is seems.
Proceed with caution.
Or better yet...
soundman98 (01-30-2020), Spuds (01-30-2020), why? (01-31-2020)
Old 01-30-2020, 01:38 PM   #9
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I'm not an expert on Subarus (or AWD vehicles), but I find it highly unlikely that a brake caliper would seize up and not cause complete brake failure via boiling brake fluid. I've had personal experience driving with a frozen brake caliper, and I can assure that after driving about 10 miles like that I had no brakes. Pedal went straight to the floor. I avoided crashing by downshifting and using the E-brake.
It's definitely worth looking at though, as would be super easy to diagnose.
Old 01-30-2020, 08:58 PM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
i probably wouldn't bother if the engine replacement is any indication.
the 2 main things that absolutely kill old cars are poor maintenance, and oddball parts like model-specific switches/trims.
poor maintenance will kill anything that can be replaced, and lack of a replacement of oddball parts like will doom whatever can't be replaced.
Old 01-30-2020, 10:52 PM   #11
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I've driven 30+ miles at 70+ mph with a seized brake caliper where that didn't happen. And yes, that is exactly as stupid as it sounds.
The Following User Says Thank You to Spuds For This Useful Post:
Old 01-31-2020, 08:20 AM   #12
WolfpackS2k
Talking
Holy crap man. Sounds like it was only "partially" seized. LOL, jk.
The Following User Says Thank You to WolfpackS2k For This Useful Post:
Spuds (01-31-2020)
Old 01-31-2020, 01:12 PM   #13
Dzmitry
Dzmitry's Avatar
[QUOTE=Tcoat;3295113]What you have seen is just a small taste of how fixing a 20 year old car can just lead to a domino effect of failures. It isn't just a matter of replacing a couple of parts like repairing a newer car but can become a total restoration project that soon becomes a money and time pit. There is a whole different level of dedication when you start working on older vehicles like this and a quick, cheap, flip is a rarity no matter how easy is seems.
Agreed. I have certainly had some taste of repairing old cars, but definitely not much yet. But of the two I owned (00 cavalier and 04 Mazda 6), both had issues that created plenty more. And yes, these aren't OLD haha, but I ain't either.... yet. The Mazda especially was a nightmare. I spent more time heading to the junkyard to pick up parts and changing them out than I did driving the thing. I remember taking it to the shop once because there was a particular code that was related to the throttle body going off, so I wanted the guy to see if I needed to replace it. He called me and told me there's too many codes on the car, he can't fix it, LOL.
As per the Subaru Outback business, I'll get a look at it this weekend real quick to check the brakes and maybe peak underneath the car. Just to satisfy my curiosity. Thanks guys.
The Following User Says Thank You to Dzmitry For This Useful Post:
Tcoat (01-31-2020)
Old 01-31-2020, 02:05 PM   #14
[quote=Dzmitry;3295589]
For much of my driving life I have had cars that were 15+ years old. Fixing them up/keeping them going can be fun but also a nightmare!
My year round DD from 2000 to 2004
Dzmitry (02-03-2020), soundman98 (01-31-2020)
SOLD: Dimple Magnetic Transmission Plug M18x1.5x12 Subaru 6MT / Outback CVT 2010-2013 xman11 Transmission and Driveline 5 12-11-2013 03:35 AM
FS: Subaru Legacy/Outback fog lamps abutterman Exterior Parts (Aero, Lighting, Etc.) 12 03-18-2013 12:47 PM
URGENT: Missing Subaru Outback Idaho Plates involved in Homicide - Hercules, CA Flipside909 Southern California 11 10-11-2012 02:36 AM
Subaru Outback In Homicide switchlanez Other Vehicles & General Automotive Discussions 0 10-08-2012 03:40 PM
