Old 01-29-2020, 12:07 PM   #15
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by j_ros94 View Post
I think i remember it was 10 but need a boost gauge soon
I like that whole house idea lol i just wanted boosted brz and that was it but i didnt expect to have so much heat issues lol
Sent from my SM-G960W using Tapatalk
I finished my tune at 10 but tuner said there is slight room to play with so I'm tuning for 11 psi right now. Everything still stock except clutch, running 93.
Wanted a boosted car as well and sold my motorcycle to fund it 4 months back.
Do you have a turbo blanket as well? I also agree that you should have your AC looked at/recharged, and take a look at your AC lines in the front. Early people who installed oil coolers didn't route the SS lines correctly and so it acted like a saw, cutting through the aluminum AC line when driving/vibrating.
Clueless
YamahaR86 is offline   Reply With Quote
Old 01-29-2020, 12:08 PM   #16
j_ros94
Drives: 2017 Subaru BRZ
Shoot ill definitely get that checked and yeah i got a blanket it helps
j_ros94 is offline   Reply With Quote
Old 01-29-2020, 12:10 PM   #17
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Ceramic coat the manifold, exhaust wrap too, get a turbo blanket. What is your AFR, IAT, oil temps and coolant temps? Is your thermostat opening?
Old 01-29-2020, 12:14 PM   #18
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Here's an example:
Clueless
Old 01-29-2020, 12:16 PM   #19
j_ros94
Afr is 14 im not sure what iat is and i gotta run a log to show my temps. As for the thermostat im not sure how to check if its opening
Old 01-29-2020, 12:24 PM   #20
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
IAT = Intake Air Temperature.
Clueless
Old 01-29-2020, 12:31 PM   #21
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Where is your oil cooler located? It will saturate your radiator with heat if it's right in front of it
Old 01-29-2020, 12:34 PM   #22
j_ros94
..shit i assumed the people who installed it for me would know that. Cuz the way its set up rn is my intercooler right in the front then its either my oil cooler or condenser then rad
Old 01-29-2020, 12:37 PM   #23
Irace86.2.0
Your AFR is 14? On boost? What’s your target?
Old 01-29-2020, 12:43 PM   #24
Irace86.2.0
I don’t think that is accurate. People run oil coolers, FMIC, trans coolers, etc in front of radiators all the time. I don’t believe the ambient air can extract enough heat to make a difference, meaning, if the ambient air is 20 degrees Celsius and the oil is 100 degrees Celsius then the air leaving the oil cooler isn’t even close to 100 degrees. Moreover, the oil cooler isn’t blocking much of the radiator.
Old 01-29-2020, 12:44 PM   #25
j_ros94
I havent checked my afr on boost still need gauges. Didnt have time to get them during the summer
Old 01-29-2020, 12:57 PM   #26
Irace86.2.0
If you are running 14:1 then your IATs will be fine, but your EGTs will likely be high, and the engine will run hotter. You will make more power, but you will also increase your chances of detonation. I doubt you are running 14:1. Most boosted cars have a goal of 12:1 on boost with some variation.
Old 01-29-2020, 01:11 PM   #27
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Get a bluetooth OBDII reader and the torque app on your phone. Should be able to see some numbers that way.
I also have my mishimoto oil cooler in front of my radiator, behind my turbo's cooler. About 2 inches of spacing between each.
Clueless
The Following User Says Thank You to YamahaR86 For This Useful Post:
j_ros94 (01-29-2020)
Old 01-29-2020, 01:16 PM   #28
j_ros94
Mine is 14:1 on idle i never got a chance to see it on boost definitely gonna get the bluetooth obdii
Wtb turbo / supercharger kit Sloyota Want-To-Buy Requests 0 02-28-2019 02:15 AM
HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit Ogremair Forced Induction 27 09-10-2015 04:39 AM
Looking for a turbo or supercharger kit!! Anthony7515 Want-To-Buy Requests 11 05-16-2014 08:25 AM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
Looking for a Frs for R&D on a turbo and supercharger Toxic Forced Induction 38 10-23-2012 03:13 PM
