#65717 | |
Damn that's crazy...
Drives: 2015 BRZ
#65718 | ||
Instagram: @spike.grc
#65719 |
Drives: 2017 BRZ PP , 2005 Saab 97X
Dumb suggestion but could it be bad gas?
or maybe an injector fouled up? could also be a cam position sensor going bad or something. |
#65720 |
Famous Potatoes
Drives: '15 ultramarine
#65721 |
ProCrastinationConsultant
Maybe he shoulda bought a civic?
#65722 |
Drives: Crapcan
#65723 | ||||
I’ve even had another shop check things and they didn’t find an issue. At this point I’d rather just pay someone stupid money to get it resolved. Quote:
Well right now it’s not tuned. But if I ever go that route again I’ll either go with Mann or one of the remote tune shops. I just haven’t been a fan of the way Mann has communicated with me in the past. Quote:
Funnily enough I was originally considering Civics because I didn’t know I’d be able to afford a sports car .
| The Following User Says Thank You to spike021 For This Useful Post: | soundman98 (01-29-2020) |
#65724 | |
we had an issue like this with a ftriends 2015FRS with the vortech kit, one day it started misfiring really bad. he dumped some octane booster in it and reflashed the tune ( went back intoa semi learning mode too) and hasnt had an issue with it since. |
#65725 | ||
1. Bad relationship at this point with the shop/tuner 2. I’ve been trying to just run the car normally the past few months to make sure it was ok (obviously not).
#65726 | |
id bet an acorn to an apple its something simple, but easily missed or over looked. if it was a bigger problem there'd be other signs. |
| The Following User Says Thank You to Clutch Dog For This Useful Post: | spike021 (01-28-2020) |
#65727 | ||
#65728 | |
but if the car turns over and starts its not going to be the "engine" per se. crank bearings, oil pistons itll most likely be an auxiliary system. something spark related have you pulled a spark plug? another possible cause is a burned Node due to detonation. even if all the eletrodes are there the color of the plug can tell you alot of whats going on |
| The Following User Says Thank You to Clutch Dog For This Useful Post: | Ultramaroon (01-29-2020) |
#65729 | |
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
