Old 04-25-2019, 01:33 AM   #1
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Valve springs: GSC vs Supertech
I'm putting together the last pieces for my built FA20 but I'm stuck on two options for valve springs, GSC beehives (GSC-5056) or Supertech 74lb dual springs (SPRK-1002-BRZ). Im shooting for 18-25 psi with 10:1 pistons. Any help is appreciated.
glorydays is offline   Reply With Quote
Old 04-25-2019, 07:42 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I've been hearing about GSC in the tuning world longer than Supertech. I don't know that either will have a benefit over the other. Who wouldn't want a beehive?
glorydays (04-25-2019)
Old 04-25-2019, 11:01 AM   #3
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Supertech has been around for a while. I've mostly seen them used on Honda's, I don't think you have anything to worry about if you decide to use them. I would go with whatever fits your budget.
Trueweltall is offline   Reply With Quote
Old 12-22-2019, 04:49 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I'm doing the recall would it be worth it to put any of these higher performance springs
in? Im NA but may go FI later on. If I stay NA is there any benefit?
TommyW is offline   Reply With Quote
Old 12-22-2019, 05:05 PM   #5
DarkPira7e
DarkPira7e's Avatar
If you're not performing the recall personally, they will not use aftermarket springs. The recall work is to replace 1 part number with another, not to just change the spring arbitrarily
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Lantanafrs2 (12-22-2019), TommyW (12-22-2019)
Old 12-22-2019, 05:23 PM   #6
TommyW
TommyW's Avatar
Darn.....
Old 01-01-2020, 04:25 PM   #7
mrg666
pessimistic skeptic
mrg666's Avatar
I am getting the GSC 5756 springs installed in a week. I will let you know
My springs failed although my car was outside recall. I don't think it is FI but the service recommended something better than stock springs for FI. Since I have voided warranty long ago with installing FI, I decided not to get stock spring installed again. And, since my car is only boosted 9 psi (JRSC), GSC 5756 seemed most suitable.
The Following User Says Thank You to mrg666 For This Useful Post:
Lonewolf (01-01-2020)
Old 01-07-2020, 02:13 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
GSC 5756 is working ok for now.
tomm.brz (01-07-2020)
Old 01-07-2020, 02:44 PM   #9
tomm.brz
Drives: brz 2017 hksv2
good to know
i 'm installing them too
mrg666 (01-07-2020)
Old 01-11-2020, 04:44 PM   #10
DBW
Motorsports
Drives: 19BRZ PP, 16 M4
GSC all day, the beehive spring is a far superior design.
Douglas W.
DBW is offline   Reply With Quote
Old 01-27-2020, 01:58 PM   #11
mrg666
pessimistic skeptic
mrg666's Avatar
I was feeling uneasy with pushing the engine in the beginning. Since last week weather is warmer and I am feeling more confident about the engine. The GSC 5756 springs made a big difference in power. Engine is revving up much more eagerly. Idle sound also changed quite a bit which, I think, is normal with different springs.
tomm.brz (01-27-2020)
Old 01-27-2020, 02:06 PM   #12
tomm.brz
i'm noticing the same.. i still haven t revved over 5000 yet but it "feels" much solid how it revs , but i think the bit heavier forged rods i put, contribute too.. also the noise of valvetrain at idle is a bit different, I confirm
mrg666 (01-27-2020)
Old 01-27-2020, 02:25 PM   #13
mrg666
pessimistic skeptic
mrg666's Avatar
I thought about replacing the short block with a built one while having the springs installed but ... cost and and my decision to stay at this boost level, I didn't. How much was the additional cost to replace the rods, if you don't mind telling?
Old 01-27-2020, 03:02 PM   #14
tomm.brz
i threw a rod so for me was a mandatory thing
my mechanic doesn t count hours for this kind of job, i replaced oem short block, installed rods in it, new head gaskets, arp head studs and gsc springs and the whole rebuild costed me around 1500€ (1700$ more or less) of labor
I threw the rod while at 4000 rpm and less than 0.5bar of boost, but I guess the racing fuel and hugely high ignition timing were what destroyed it
mrg666 (01-27-2020)
Subaru SB19-001 NEW VALVE SPRINGS FOR FA/FB ENGINES Trap63 Issues | Warranty | Recalls / TSB 0 02-12-2019 02:08 AM
My engine blew up four years ago, now they recall the valve springs Obsidiank Issues | Warranty | Recalls / TSB 12 01-02-2019 01:47 PM
Valve springs Gunman Off-Topic Lounge [WARNING: NO POLITICS] 8 11-21-2018 02:49 PM
King Bearings (mains and rods) GSC Valve Springs Nick B-rz Engine, Exhaust, Bolt-Ons 2 07-23-2017 10:55 AM
Kelford Cams FA20 High Performance Valve Springs FT-86 SpeedFactory Engine, Exhaust, Transmission 26 09-26-2013 08:58 AM
