Old 01-22-2020, 05:56 PM   #337
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Stock Trunk with Wing
Stock Trunk with Wing 18lbs 8.8oz
SuperTom is offline   Reply With Quote
Old 01-22-2020, 05:58 PM   #338
SuperTom
SuperTom's Avatar
VAC Motorsports Seat Mounts
VAC Motorsports Seat Mounts 2lbs 8.3oz
Old 01-22-2020, 05:59 PM   #339
SuperTom
SuperTom's Avatar
Mishimoto SLim Fans & Shroud
Mishimoto 7lbs 4,7oz
Stock radiator Fans/Shroud 7lbs 5.4oz
Old 01-22-2020, 06:05 PM   #340
SuperTom
SuperTom's Avatar
Tunnel Mount For Stock Drive Shaft
Tunnel Mount For Stock Drive Shaft 1lb 11.8oz
Old 01-22-2020, 07:12 PM   #341
ML
ML's Avatar
Drives: 13 White MT FR-S
you had to drill out the tack welds?
Old 01-22-2020, 07:13 PM   #342
ML
ML's Avatar
Stock Door gutted 43lbs 1.1oz
how is it gutted?
Old 01-22-2020, 07:41 PM   #343
SuperTom
SuperTom's Avatar
Originally Posted by ML View Post
how is it gutted?
By gutted I mean no window or power window components. Not cut up or anything.
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
ML (01-22-2020), Takumi788 (01-24-2020)
Old 01-22-2020, 07:43 PM   #344
SuperTom
SuperTom's Avatar
Its been a while but I used one of those weld remover bits, Some areas was hard to fit so some welds were ground down then just pryed the damn thing off. A lot of work for a pound but its useless with a CF Driveshaft
ML (01-22-2020), why? (01-23-2020)
Old 01-23-2020, 06:59 PM   #345
new2subaru
Weight Weenie
Drives: 15 FR-S
8lb loss and on sale now. RacerX rear upper control arms. Good weight loss for the money.
https://racerxfabrication.com/frs-br...r-control-arms
The Following User Says Thank You to new2subaru For This Useful Post:
SuperTom (01-23-2020)
Old 01-23-2020, 09:57 PM   #346
SuperTom
SuperTom's Avatar
Yeah those are defineatly on my list. I don't need the extra adjustment points though. Im hoping I can accurately measure the stock dimensions and set the racerx ones to that. I just don't want to have to pay for another alignment
Old 01-23-2020, 11:21 PM   #347
new2subaru
Weight Weenie
Drives: 15 FR-S
I hear you and I also hear they're a bitch to do. Once done they're set. All for a good cause.
Old 01-24-2020, 06:40 AM   #348
SuperTom
SuperTom's Avatar
Bitch to do - U mean installing them or getting them aligned?
My fear is local hack mechanics aren't going to be able to figure out how to align it
Old 01-24-2020, 08:17 AM   #349
new2subaru
Weight Weenie
Drives: 15 FR-S
I think a bit of both leaning towards alignment being more of a pain. Once set you're done. Here's a good read. I still think they would be 100% worth it though. They're on my list too.
https://www.ft86club.com/forums/show....php?p=1494027
SuperTom (01-24-2020)
Old 01-24-2020, 08:51 AM   #350
Code Monkey
Drives: Subaru BRZ
The RacerX RUCA's are super easy to install. The initial alignment is a bit of a pain because to change camber you need to pop out the rod end to turn it and not many alignment shops want to do it. My shop checked the rear camber and I went back home to adjust one side, and then came back for a full alignment. They did not charge me for the initial check although I tipped the alignment tech extra afterwards.
Code Monkey is offline   Reply With Quote
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
Joesurf79 (01-27-2020), new2subaru (01-24-2020), Nick Dugdale (04-16-2023), SuperTom (01-24-2020)
diet, heavy, light, reduction, weight
So what is the official weight? brillo Scion FR-S / Toyota 86 GT86 General Forum 76 05-03-2020 05:11 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
2012 Geneva - Toyota GT86 in Black, Blue, White, Orange. Official weight & 0-60 Shown Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 124 05-28-2012 12:20 PM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) — General Topics 50 02-08-2012 02:04 AM
