Old 01-05-2020, 08:45 PM   #197
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
sneak preview of something ive been working on. A stout but lightweight battery cage to mount my Shorai in the trunk
I used thicker aluminum even though a step down thinner aluminum would have worked. Still came out to only a hair over a pound!
With the Shorai
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
new2subaru (01-05-2020), q335r49 (01-17-2020)
Old 01-07-2020, 12:58 PM   #198
SuperTom
SuperTom's Avatar
Got the battery installed in the trunk. Put it right in the center as that was the easiest to mount and drill holes ect. Also only added 2.25lbs of cabling
Had to figure out the new weights from each area of the car.
Front :
-Stock Battery/Trace/Holder -29.75, + .5lbs underhood connectors = -29.25lbs
Middle:
+ Cable 2.25lbs
Rear:
Shorai Battery/Mount/ Negative Cable +6.25lbs
New car weight 2342lbs
Stock battery/tray/Tie bar
Connection point I made out of and old Rubber Exhaust hanger
Connected those to the stock under battery bracket
Weight of the 4gauge cable I had leftover from stereo installs
- Minus what I didn't use
Weight of the Battery/Mount/Negative Cable
Installed in the trunk, used the spare tire mount for my ground point, Idled the car for 10 mins everything seems great!
In summary I was able to Take alot of weight off the front and only add a few total pounds, put some over the rear tires!!
jflogerzi (01-07-2020), new2subaru (01-07-2020)
Old 01-07-2020, 01:47 PM   #199
amcp1
Drives: frs
Only thing I'd say is you moved weight outside the wheelbase of the car. The more a mass is centered in the vehicle, the better it will handle. The Shorai in the stock spot should help F:R balance as your loosing weight towards the front.
My 2 cents.
amcp1 is offline   Reply With Quote
Old 01-07-2020, 07:03 PM   #200
SuperTom
SuperTom's Avatar
My 2 cents.
Well I already had it in the stock spot before. Back end of my car is really light if you are following my whole build. Main goal was to get the front even lighter and put a little weight in the rear.
Yes I wanted it more centered (in front of the spare tire area) but there wasn't enough flat surface anywhere else to mount it
Old 01-17-2020, 02:42 PM   #201
SuperTom
SuperTom's Avatar
Well it was cold as balls today but I managed to get the Cusco SOFT rear sway bar installed today. This was with Godspeed Endlinks and new Nolathane bushings.
Total Package was 1lb lighter!!
Current weight 2341lbs
Old 01-19-2020, 02:59 PM   #202
SuperTom
SuperTom's Avatar
Chase Bays Clutch line
Today installed the Chase Bays Clutch line. This removes the factory brackets with one clean line to the clutch slave. Also saves .25lbs off the front
CHase bays
Stock
Installed
Old 01-19-2020, 03:42 PM   #203
SuperTom
SuperTom's Avatar
Also installed some 86 Cam Solenoid covers today, and converted a majority of the bolts in the engine bay to titanium
Cam solenoid covers + Radiator cap cover added .5 lbs
Converting all the bolts to titanium -.5
I weight a batch of titanium bolts, then the stock bolts afterwards for a .25 pounds savings. I did this process 2x hence the -.5 lbs
Basically the titanium bolts are half the weight of stock
Titanium "Metal of the Gods!!"
Stock bolt
Titanium
Bag of stock afterwards
Bags of titanium
Rusted Cam solenoids
Nice!
Everything combined didn't gain or lose weight but the engine bay now looks great. The pics came out a bit blurry but those titanium bolts really shine in real life
new2subaru (01-19-2020), q335r49 (03-03-2020)
Old 01-22-2020, 05:53 AM   #204
scottman
scottman's Avatar
Drives: 13 mt fr-s
Dude.
Very inspiring work!
All your pics and documentation were very helpful.
You got me to pull the trigger on that smaller willwood 4pot too. Cant wait until spring.
Have you considered a brake booster delete?
Originally Posted by SuperTom View Post
scottman is offline   Reply With Quote
The Following User Says Thank You to scottman For This Useful Post:
SuperTom (01-22-2020)
Old 01-22-2020, 08:18 AM   #205
SuperTom
SuperTom's Avatar
Originally Posted by scottman View Post
Dude.
THanks!
You will love that loss of rotating mass upfront with the Smaller Wilwood
Yes I really want to do that BBD so bad. Im having trouble finding any real documentation on deleting the ABS.
I know you could just rip it all out and have a bunch of lights/possible limp mode.
Im talking about keeping the black box to trick the computer/ remove everything else. Anything Ive found is vague information
I saw a pic from one guy who rerouted all the ABS back into itself. It looked like a convoluted mess. I want all the ABS piping gone/ Just keeping the black box.
Simple and Light is the goal with this build
The Following User Says Thank You to SuperTom For This Useful Post:
scottman (01-22-2020)
Old 01-25-2020, 05:57 PM   #206
SuperTom
SuperTom's Avatar
Whats your favorite type of cheese?
Mine is Swiss Cheese!
A lot of work to save .5 lbs but it was free
Found it easier to drill smaller holes than bigger holes through the Steel it also keep material around each hole
Original is 3lbs 1oz, got it down to 2lbs 9oz
new2subaru (01-25-2020), q335r49 (03-03-2020)
Old 01-25-2020, 08:43 PM   #207
new2subaru
Weight Weenie
Drives: 15 FR-S
Nice!
The Following User Says Thank You to new2subaru For This Useful Post:
SuperTom (01-25-2020)
Old 01-26-2020, 06:37 PM   #208
SuperTom
SuperTom's Avatar
Seibon Hood
just installed my Seibon Dry Carbon Vented hood today!
I know you may be saying why didn't I go with the MPH hood which is lighter and I know functional
- I really don't like the square box design of his vent looks, Looks better on BRZ's with the boxy front bumper
- Since everything else is Seibon on my build I didn't want different CF's so close to each other.
- These parts are now closeout so I didn't want to miss my chance and the prices are dropped.
- If and when I do the roof I will go with MPH's since its way lighter than the Seibon if Im going to go through all that trouble. It wont be close to the other parts if there is a diffrence
So on to it looks like this saves 2.5lbs over stock and that includes the hood pins
Seibon Hood = 13.5lbs
Hood Pins = .5lbs
Stock hood with insulation = 16.5
Stock hood
Some installed shots. It was cloudy out so you cant see the weave too well. Fitment was great
New Vehicle weight 2338.5 LBS
Iceman (01-27-2020), new2subaru (01-27-2020)
Old 02-06-2020, 02:16 PM   #209
SuperTom
SuperTom's Avatar
Been working on a front weight reduction project the past few days. Unfortunately not a lot of weight lost for a lot of work done.
Took off all the Non structural metal upfront (Headlight bucket, Radiator T, Fender brackets). Had previously swiss cheesed the Radatiator T but for some reason I didn't record the weight, but I did clean up the holes and added some more
Bought this to do some clean holes. Still needed to drill out 1/2" to use it
All the pieces weighted come to 11.5 lbs
After a lot of drilling and hole punching was only able to save 1lb
But this mission wasn't a complete waste I was able to save some weight removing some unnecessary brackets.
One on each side brackets holds up some thing for the headlights (mini Balast??), easily screwed in without the brackets.
Bracket for outside temp sensor I believe removed, plugs right into radiator spot
went from 2 horns down to one, and removed windshield washer hose.
Brackets,Horn,Hose =Got a 1.25lbs loss!
Also saved a 1lb from replacing bolts with titanium ones and some unused from the brackets
In conclusion easier to find things to remove, or get lighter pieces than drilling holes which hasn't given me good results. Not sure how the Opera S2000 got 700lbs out from doing it!
Total Savings:
Speed Holes = -1lb
Useless Brackets= -1.25lbs
Titanium Bolts= -1lb
NEW WEIGHT 2337.25 LBS
new2subaru (02-06-2020)
Old 02-06-2020, 03:30 PM   #210
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Pretty sure that is a crash sensor. Most of the time airbag/crash sensor stuff is denoted by the yellow plugs. I could be wrong. But I made sure to keep the bracket it was attached to as I didn't want to mess with how the sensor read or anything.
edit: Just confirmed those are airbag sensors.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
new2subaru (02-06-2020), SuperTom (02-06-2020)
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 05:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 02:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 01:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 07:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-01-2013 11:45 PM
