Old 07-15-2012, 11:59 PM   #43
Lytheum
Drives: 2013 BRZ Premium 6MT
havent had much in the way of rattles. one crazy one that happened twice. i think it was either the glovebox door or my ipod and the door together. i also have a random squeak/squeal that happens on the freeway. no idea where its coming from...may even be something outside the car.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 07-17-2012, 08:24 AM   #44
Camotec
Large Member
Camotec's Avatar
Drives: Toyota GT86 - Silver
I think you've all got it wrong, its not the car its the squeals and squeaks from amazed and shocked onlookers
Sent from my iPad
Camotec is offline   Reply With Quote
Old 07-17-2012, 09:05 AM   #45
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Originally Posted by Oriental Life View Post
These white plastic clip holders are underneath the foam layer under the trunk liner. Get some sealant and fix it in place, so that they don't move. If you tap on those - you'll hear how much noise they are creating. Unbelievable! On the picture I show only 3 of them - the noisiest, but there are more under foam pieces that hold tools.
How were you able to remove the black plastic rivets (the ones that hold the foam down) from the plastic clip holders without destroying the foam? They seemed pretty solidly lodged in there.
NRGBalanced is offline   Reply With Quote
Old 07-20-2012, 09:25 PM   #46
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
Sorry, took me so long to answer - I pry it with hands, it comes off pretty easy. Don't use flat screw drivers - you'll leave markers.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
Old 07-22-2012, 02:29 AM   #47
sesmls
Drives: DGM BRZ Limited, 05 Baja Turbo
I was getting a pretty bad rattle, seemingly from around the center console on rough roads between 35-50 mph. In frustration, I opened the glove compartment door, and noticed the rattle got quieter. Then I took out the glove compartment contents one by one. When I took out the padded binder containing all the manuals and paperwork, the rattle completely disappeared, but it reappeared immediately when I put the binder back in the glove compartment and shut the glove box. Looks like the weight of of the binder changes the way the glove box makes contact with its surrounding parts, just enough to make the car sound like a rattle trap. Without the padded service manual binder in the glove box, there is no rattling, even going over bumps.
sesmls is offline   Reply With Quote
The Following User Says Thank You to sesmls For This Useful Post:
kgc (08-05-2012)
Old 07-22-2012, 08:34 PM   #48
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
It's been getting worse with every day, hopefully tomorrow I can take a look and try some of the tips.
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 07-24-2012, 02:04 PM   #49
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by taosracer View Post
a pop sound from the rear, especially noticeable when the rear seat is folded down. I believe it's coming from the trunk hardware (like the rods that spring it open) as the chassis flexes over bumps or around turns. I'll be torturing someone into riding back there to trace the source.
Have you or anyone else figured this out? I believe I have the same "pop/click" sound. It's not a "rattle" sound. It only started about a week ago. I have the car for 7 weeks.
Old 07-27-2012, 12:57 PM   #50
Jayde
Jayde's Avatar
Anyone notice a rattle on the shifter just below the collar? It's just behind the boot, and it seems to happen only at a higher rpm. It's really quite annoying.
Jayde is offline   Reply With Quote
Old 07-27-2012, 10:16 PM   #51
brzmass12
Drives: SWP BRZ Limited MT
For the last week or so I've heard a high-pitched squeak coming from the back of the car. Pretty annoying as it sounds like a smoke detector when the battery is running low!!!
Anyone else hearing something similar?
brzmass12 is offline   Reply With Quote
Old 07-28-2012, 03:16 AM   #52
Sigh-on-Rice
Is the noise a quick tick/click? Or is it more like squeak/beep(smoke detector) long? Does is sound different with the rear seats up vs down?
Old 07-28-2012, 12:25 PM   #53
Subie
Seρor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I'm hearing an occasional squeak driving down the road. I'm not sure, but I think it may be coming from the front suspension. Is anyone else experiencing the same thing?
Subie is offline   Reply With Quote
Old 07-28-2012, 06:21 PM   #54
brzmass12
Sounds like a squeak/beep (smoke detector). Haven't had the rear seats down so it's when they are up. To be honest it's really difficult to try and pinpoint exactly where the sound is coming from.
Old 07-28-2012, 06:37 PM   #55
Sigh-on-Rice
I see. We probably have different noise then. Mine is more like tick/click noise.
Old 07-28-2012, 06:51 PM   #56
brett_g
Drives: 13' BRZ
Def hearing this. Can def say its coming from the driver side rear, but I seem to hear it with windows up as well.
Damn you dead silent previous dd mercedes for spoiling me!
brett_g is offline   Reply With Quote
