#1373 |
Drives: 2013 Scion FRS
Hi! I'm in AR. My FRS is getting the work done now on the recall. I didn't realize before dropping it off what was happening with the recalls.. otherwise I never would have dropped it off. I am freaking out! What dealer did your recall and how long ago? I don't know if mine will have a problem or not, but I am freaking out.
#1374 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Hi, hello.
Some run fine after and some don't. Depends on the care taken to not peel the old goop into holes down the block. Don't panic until it's time
"I gotta rock." -- Charley Brown |
| The Following 2 Users Say Thank You to bcj For This Useful Post: | humfrz (01-10-2020), Ultramaroon (01-10-2020) |
#1375 | |
![]() Hopefully by now the tech at the dealership where your car is being worked on has received the latest cautionary information on this repair and will do a proper job. Not to worry, because now their is nothing that you can do about it. The worse case after the repair, is that your car stops running. humfrz |
#1376 | |
Drives: 2013 brz limited / galaxy blue
Pray and pray and pray to the car god she turns out well ![]() Sent from my iPhone using Tapatalk |
#1377 |
Drives:
I have 230K on my "bad" valve springs.
| The Following 4 Users Say Thank You to N234 For This Useful Post: |
#1378 | |
My suggestion to anyone on the fence about this recall. "DON'T DO IT" unless you have a spare $7-10G sitting around you want to get rid of at some point in the future. I guess they consider some sealant left over from a repair is "of no concern". That's a frightening comment coming from someone in the automotive repair business. What if my heart surgeon said we left a small amount of gauze inside you...but its of no concern. Last edited by DeadBRZ; 01-14-2020 at 03:54 PM. |
| The Following User Says Thank You to DeadBRZ For This Useful Post: | gravitylover (01-15-2020) |
#1379 | |
https://www.flickr.com/photos/310517...posted-public/ Last edited by DeadBRZ; 01-15-2020 at 10:35 AM. Reason: Changed img url |
#1380 | |
Drives:
The link must be seized. Sent from my SM-G930W8 using Tapatalk |
#1381 |
Drives: Spyder, MR2, FRS, Tundra
I would ask them where the documentation is that says what amount is acceptable. I wouldn't think there should be any acceptable amount.
#1382 | |
IMPORTANT: Always keep close watch for any loose pieces of sealer, large or small as components are disassembled and remove them right away. This will help prevent them from getting into oil passages, restricting oil flow and potentially causing damage as shown here. Pictures are in the bulletin. And another on page 14 VERY IMPORTANT: It is critical to make sure all the original sealer is removed and the affected sealing surfaces completely clean and dry before applying any new sealer. After cleaning, a thorough inspection of the inside surfaces of the cylinder head area around the valve springs, inside the front timing cover and inside all the cam caps for any small pieces / bits of removed sealant or any other contamination is essential to providing a quality repair. Any contamination left behind can cause the Check Engine light to illuminate and / or other issues to develop resulting in a comeback. I could not find any statement that suggests leaving "any amount" of sealant in the engine is acceptable. It does however state that a quality repair includes making sure there is nothing left behind. |
#1383 | |
You've printed that out and you have a screenshot right? Send an email and explain that they've released documents that state differently than what you were told and you'd appreciate it if they would review the "case" again. Add the picture and ask if it's possible that another piece is blocking a passage somewhere? I would think that if you had someone reasonable looking at it they might get it and do the right thing.
#1384 | |
This is so frustrating, I went through something similar with my 2013 Elantra GT. I bought it brand new. I knew how it sounded brand new. Changed my oil earlier than recommended. Used full synthetic from the start. Then I started hearing the dreaded ticking and knocking on cold starts (after 15k). Took it to the dealer and they tried to say it was the fuel injectors. Found out after I sold it that they are now providing extended warranty's on some models due to debris left in the casting during manufacturing causing abnormal wear of the motor. At least they are slowly admitting to the problem and are taking care of it. |
#1385 |
Drives: 2013 FR-S Series 10
It sounds like they want you to take them to small claims court.
And yeah those Hyundai engine problems were some real shit. Brother in law's Sonata was out of commission for like 6 months because engines were not available.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#1386 | |
Thank you for your email. Today I spoke to S*******t regarding the vehicle, S**** informed me that he has shown the images to Subaru Canada Tech Line, a senior technician in our shop and our service representative at Subaru Canada. All parties concur that the remnants of sealant did not create the problem Therefore our conclusion is the repair performed did not create the mechanical failure. My issue is "the remnants of sealant" comment. There should be NONE.....period. This sounds a lot like a judge and jury that are life long friends with the accused. |
| The Following User Says Thank You to DeadBRZ For This Useful Post: | gravitylover (01-17-2020) |
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
