Old 08-05-2019, 09:31 PM   #645
Contender
Drives: 2017 Toyota 86
Why is it the 2017 data isn't already on the tablet? Seems kind of stupid you have to email to get them.
Contender is offline   Reply With Quote
Old 08-06-2019, 04:12 AM   #646
elBarto
elBarto's Avatar
Drives: Toyota GT86
You have to use the search function and then "buy" the tunes for free.
As an example I've linked the K00C page
https://www.openflashtablet.com/shop...-us-6mt-v4-03/
If you want to look for an other calid use "za1j" and then your callId in the searchbar
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 08-30-2019, 09:45 PM   #647
InstaGib
Drives: 2015 Scion FR-S || Raven Black
Originally Posted by CSPTK View Post
For upshifts. Downshifts can still be
How can you expect a manual transmission car to have a rev limiter for downshifts? The only way would be to remove mechanical linkages.
InstaGib is offline   Reply With Quote
Old 08-31-2019, 12:31 AM   #648
CSPTK
Drives: 2014 FR-S
You cant, but if you read the previous replies, that's what's inferred. The rev limiter wont save your engine on a mechanical overrev....like grabbing 2nd when you wanted 4th.
Sent from my SM-G960U1 using Tapatalk
CSPTK is offline   Reply With Quote
Old 09-05-2019, 12:49 PM   #649
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
I'm sitting in the sonic drive thru line with the windows down. I think a fan in my engine just kicked on loud. Sounds like the same thing that happens when you are using AC I'm running stage 2+ 4.03. You guys ever have that happen?
oldlostcory is offline   Reply With Quote
Old 01-02-2020, 01:19 AM   #650
73TORANA!
Drives: Orange GTS
Hi all,
A little bit off topic here but to do with open flash tunes.
I have just flashed the stg 1 tune and noticed what appears to be quite loud injector noise around 4k rpm at mild to full throttle applications . I dont see any IAM or knock corrections or very little if at all. Has any one else noticed this? Is it in fact inject noise to do with the new maps?
Thanks for any help. Cheers
Geoff.
73TORANA! is offline   Reply With Quote
Old 01-02-2020, 02:51 AM   #651
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC many had reported of more noises in that area after flashing tune. Should have to do with more aggressive timings to reduce torque dip. Normal, ignore.
Old 01-02-2020, 04:05 AM   #652
steve99
Drives: FT86
Originally Posted by 73TORANA! View Post
Hi all,
Geoff.
Sods like the vvt induction resonace due to agressive vvt tikng to redice torque dip. Take 10 degrees out of the exhaust cam timing in the last ad rpm range should stop it but you might get some torque dip back
Old 01-09-2020, 03:59 PM   #653
73TORANA!
Drives: Orange GTS
Quote:IIRC many had reported of more noises in that area after flashing tune. Should have to do with more aggressive timings to reduce torque dip. Normal, ignore.
Thx guys. Along way off modify maps, just learning to crawl here. Have been trolling through dozens of post and rcall some saying UEL headers with stg2 tune will improve dip and eliminate noise ??? cheers
Old 01-09-2020, 10:36 PM   #654
73TORANA!
Drives: Orange GTS
I have read you use rom raider is it easy to use. what about tunerpro
Cheers
Old 01-18-2020, 07:38 AM   #655
LancePower
Drives: 2020 BRZ tS
Is there an estimated availability date for 2020 model year?
LancePower is offline   Reply With Quote
Old 01-18-2020, 08:20 AM   #656
tomm.brz
Drives: brz 2017 hksv2
it s not like they are officially released
ecutek already has them already
you can ask openflash email if they have them
Old 01-18-2020, 01:33 PM   #657
LancePower
Drives: 2020 BRZ tS
Will do, thanks, once I can pull my CAL ID.
Old 01-18-2020, 06:05 PM   #658
steve99
Drives: FT86
Cheers
Definitions supplied by oft guys are for romraider so easiest to use romraider
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 08:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 05:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 03:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 07:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
