Old 12-10-2019, 11:17 PM   #99
M0nk3y
Originally Posted by KevBRZ View Post
Hence, how nice the Karcepts one would be!
It doesn’t suck...
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
KevBRZ (12-11-2019)
Old 12-12-2019, 10:58 AM   #100
KevBRZ
Drives: 15BRZ
re: header /tuning
Looks like i am gonna start looking for a header and getting a tune, any of you guys have items you absolutely don't recommend? Was looking at Ace 350 (pricey but seems worth it) JDL 421 and Tomei, I don't want UEL, actually don't like the sound etc. and not sure with the tuning tool yet. Then plan on trying to learn how to drive it this coming year and not be beat by a DS BRZ again. At least on my 2nd event i was alot closer to beating him.
KevBRZ is offline   Reply With Quote
Old 12-12-2019, 01:31 PM   #101
M0nk3y
Can't go wrong with any of those options.
I've had the Tomei and now run JDL 4-2-1. Both make good power in different ways
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
KevBRZ (12-12-2019), smg1138 (12-12-2019)
Old 12-12-2019, 02:08 PM   #102
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
@M0nk3y What tune are you running for the JDL 4-2-1?
smg1138 is offline   Reply With Quote
Old 12-12-2019, 04:27 PM   #103
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Same here. I had the tomei EL using OFT standard tune files. It came on Hard around 5k and pulled good to the top. Still had a noticeable torque dip but much improved.
The JDL 4-2-1 was a clear improvement all around. I got a customized tune from OFT which I believe provides some benefit.
This all purely by way of butt dyno.
So the JDL is of course a good bit more cash than the tomei, and the Ace is way beyond that.
So depends on what you're willing to spend and at what point the bang-for-the-buck doesn't work. I'm very happy with the cost and performance ratio the JDL provides.
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
The Following 3 Users Say Thank You to bmacfrs For This Useful Post:
KevBRZ (12-12-2019), smg1138 (12-12-2019), strat61caster (12-12-2019)
Old 12-12-2019, 04:57 PM   #104
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Same experience as bmac on the Tomei
Tomei short tube EL + OFT is a fine budget solution (used parts means <$1k) that leaves low end torque on the table vs the Tomei/JDL UEL+OFT.
If I was going long tube either ACE or JDL I'd spend the extra money on an ECUTek tune from someone reputable.
ineedyourdiddly
KevBRZ (12-18-2019)
Old 01-01-2020, 08:26 PM   #105
Autoxer62
Time for a 2020 thread? I'm looking to collect parts for a build later this year, curious about what to watch for in the classifieds.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 01-02-2020, 03:11 PM   #106
CoolHandMoss
Drives: 2013 FRS
Do it up.
CoolHandMoss is offline   Reply With Quote
Old 01-05-2020, 12:58 AM   #107
KevBRZ
Drives: 15BRZ
racer x links
Originally Posted by smg1138 View Post
Question for those of you with RacerX front end links. Are they shorter than stock length? My Whitelines seized up and I'm looking to replace them.
Also, any noise issues with them?
Dude, u jinxed me..... i was having no issues with my racer x links for about 2000miles, and boom starting have noise in front end, checked to see if something was loose etc and the bottom bushing on passenger was seized. i mean not at an extreme angle either, it was immovable, ie put it into a vice and had to smack the hell out of it with a rubber mallet to get it to move a 1/4 inch. It was removed with the car on ramps so it was easy to remove being they weren't loaded due to installed with preload. After 15minutes of trying to pack grease into it and pounding away i got it to move but its far from freely moving lol i messaged racer x and hoping for a replacement being only purchased a few months ago. Oddly enough the rest of the bushings are perfect, i do remember at installation one was a bit stiffer, i bet it ended up it was this one.
Old 01-05-2020, 01:41 AM   #108
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
ive Only had issues with whiteline endlinks ive stripped the threads after two events a friend of mine killed the ball joints within 6 months. another guy snapped his (granted im not sure it was autox or track related but more..... extracirricular pleasures?)
And so far havent had issues with the racerx endlinks but i would hazard to guess they arent coated for antisieze or rust so they might need some copper shit
Clutch Dog is offline   Reply With Quote
The Following 2 Users Say Thank You to Clutch Dog For This Useful Post:
KevBRZ (01-05-2020), smg1138 (02-17-2020)
Old 01-05-2020, 03:51 PM   #109
KevBRZ
Drives: 15BRZ
re:links
Thankfully greasing and cleaning i finally got it moving fairly decently, no noise now! Def change in handling also which maybe is in my head not sure but feels more planted.
The Following User Says Thank You to KevBRZ For This Useful Post:
Clutch Dog (01-05-2020)
Old 02-17-2020, 11:27 AM   #110
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
Any whiteline parts NOT STX legal?
Is the IRP grey area, or is it not STX legal?
Say you want to run the TS wing, can you run it because it was a factory option or you need to"convert" your car to a TS package?
If you have to convert, what does that entail in its entirety?
SON1C is offline   Reply With Quote
2019 CDC & SCCA Autocross Thread JakeRogue Mid-Atlantic 15 05-17-2019 09:58 AM
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited Busybee Scion FR-S / Toyota 86 GT86 General Forum 64 02-24-2019 12:05 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
