Old 12-26-2019, 08:41 AM   #18033
Grady
Grady's Avatar
Originally Posted by dodj View Post
Hit a partridge.....
As long as you avoided the Pear Tree, you are good!
The Following 2 Users Say Thank You to Grady For This Useful Post:
dodj (12-26-2019), JD001 (12-26-2019)
Old 12-26-2019, 08:46 AM   #18034
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by HaXx View Post
did the fog light repin so i could get just boomerangs w/ fogs like this:
now im just dealing w/ the bumper gap problem lmao
The heat from the flames will soon help to close the bumper 'gap problem'.
Old 12-27-2019, 05:23 PM   #18035
edwardl
Drives: 2018 BRZ
Valenti 4th brake light. Had to open it up and move some wires around so the brake triangle is not tied to the running light. Dumb.
edwardl is offline   Reply With Quote
The Following 5 Users Say Thank You to edwardl For This Useful Post:
BA9092 (12-27-2019), beltax90 (12-27-2019), Busybee (01-01-2020), StraightOuttaCanadaEh (12-27-2019), Will BRZ (12-27-2019)
Old 12-27-2019, 05:53 PM   #18036
beltax90
beltax90's Avatar
Drives: 2010 corolla
^ nice
beltax90 is offline   Reply With Quote
Old 12-28-2019, 05:53 PM   #18037
edwardl
Drives: 2018 BRZ
APR carbon fiber mirrors
Old 12-28-2019, 07:55 PM   #18038
Brzn2
Drives: Subaru brz
Exhaust
Swap exhaust from Invidia n2 to stock
Brzn2 is offline   Reply With Quote
Old 01-01-2020, 08:03 PM   #18039
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Reason ?
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 01-01-2020, 08:06 PM   #18040
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Too noisy? lol
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 01-01-2020, 08:07 PM   #18041
Busybee
Busybee's Avatar
Installed interior lighting kit. Happy with the results!
Old 01-01-2020, 08:36 PM   #18042
Busybee
Busybee's Avatar
Originally Posted by weederr33 View Post
Too noisy? lol
To my knowledge the rank was n1 n2 r400 q300.
Just today I checked some videos for n2. I don’t want something loud but a little more than the stock. Do you consider anything whiter than the n2 such as the r400 or any other brand. Any experiences with the others ?
Thanks
Old 01-01-2020, 08:45 PM   #18043
HaXx
Drives: jrsc_brz
Thanks
i have the N1, lmk if you want to hear it in person. oem header and front pipe. idk who said the N1 is too aggressive, but if you keep the rest stock, theres not much a catback can do to make your car over the top loud.
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Old 01-01-2020, 09:14 PM   #18044
edwardl
Drives: 2018 BRZ
You should definitely hardwire it in. It's super simple, ground it to the bolt that's behind your hood release latch, and pop the fuse tap into the fuse box right above it. ft86speedfactory has a video if you want a visual. So much cleaner than taking up the lighter.
Old 01-01-2020, 09:26 PM   #18045
Busybee
Busybee's Avatar
That was the initial plan. The module has the - (ground) and + (fuse tap with 10A fuse includes- not sure which fuse to use, maybe the p/pin1 or 2 which are the cigarette lighters). But in addition to those two wires there is also an auxiliary wire which is for custom color door opening.
I tried to wire it to the door light trigger but it did not light up when opening the door. I was little scared to short the system so I decided not to wire it. What I want is that the auxiliary wiring gets activated like the dome light when you get closer to the car with the key fob.
The footwell illumination with the cigarette lighter turns on only when the engine is on. Ideally the whole system should be activated with the dome light and change the custom color when the door is opened.
Will definitely search and finalize a hardwire.
Thanks
Old 01-01-2020, 10:12 PM   #18046
weederr33
weederr33's Avatar
Thanks
I'm very particular about loud exhausts. I had a Q300 and over the course of a year it became too loud. So put on the HKS Legamax Sport and it was very quiet. So I'm not a good reference
