Old 12-31-2019, 08:53 AM   #71
StraightOuttaCanadaEh
Wes
I just softened my coilovers by 3 clicks all around and the thing understeers like a pig on the on ramps. Will try to get better winter tires next year
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
NoHaveMSG (12-31-2019)
Old 12-31-2019, 09:33 AM   #72
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Do you swap out the summer air that accumulated in them while they sat, or did you put fresh winter air in them?
Old 12-31-2019, 09:41 AM   #73
Wes
fresh crisp winter air! 35 psi all around. They're just shit blocky gummy tires. I'll spend money next year and get those... what are they called...LM32
Instagram: @gt86ws
Old 12-31-2019, 10:58 AM   #74
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Just to clarify for a lot of folks, this is ***COMPLETELY*** track and driver dependent. It 1. depends on the driver to maximize the grip of a lesser tire, and 2. it strives to find the balance between cornering speed and straight line speed. To a lesser degree, it is vehicle setup dependent.
The average driver will usually find more value in a larger tire giving them more thermal capacity, rather than seeking the theoretical "fastest" setup that they may not be able to fully exploit.
Do you have a link to a thread for this? I've always been lead to believe that you should run as much tire as you can (read a lot of Vorshlag's build threads). I'm certainly open to learning new/better things though.
I'd also guess that it's heavily track dependent if you're balancing straight line vs cornering. I don't get a lot of long straights at the nearby tracks I run.
CrowsFeast is offline   Reply With Quote
Old 12-31-2019, 11:54 AM   #75
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Try stabbing the brakes before engaging the corner to transfer weight onto the front tires if the corner isn't too long!
Old 12-31-2019, 11:59 AM   #76
Wes
Oh I've done that, but that would be quite scary on an on-ramp lol. This was almost the end of the on-ramp and I suddenly felt the nose push wide. It was a strange experience as I've never felt the car do that before. If anything, it always is super keen to turn in, granted that's when it's on sticky wide summer tires and with the coilovers firmed up. But with the softer setting and crappy snow/ice tires, that's hard. I need better coilovers and better tires.
Instagram: @gt86ws
Old 12-31-2019, 04:17 PM   #77
CSG Mike
CSG Mike's Avatar
There's no specific thread holding the data. Everyone's finding's are different because it's dependent on many factors.
Old 12-31-2019, 05:16 PM   #78
churchx
churchx's Avatar
Drives: 2014 GT86
@StraightOuttaCanadaEh btw, have you checked state of bushings? I had noticeable handling change mid turn when leaning more on side, when my front LCA whiteline front bushing's metal core separated from poly surround.
Old 12-31-2019, 07:53 PM   #79
Wes
I haven’t recently, no. I don’t think there’s a problem, I’m gonna go with Occam’s razor here and just assume it’s cold weather + slick pavement + shitty driver + even shittier tires + crap coilovers with horrible valving.
Instagram: @gt86ws
2013s less responsive than 2017s? 370zBRZ BRZ First-Gen (2012+) — General Topics 25 07-28-2018 05:24 PM
Car feels a little less peppy Riftur Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 04-15-2018 06:02 AM
Which entry level turbo kit is the most responsive? Keenercarguy Forced Induction 54 04-18-2017 03:40 AM
Am I the only one that feels bothered by this (R.S 1.0) 1GiantTurtle Scion FR-S / Toyota 86 GT86 General Forum 22 12-11-2014 08:18 PM
18's or 19's ... What looks and feels best on FR-S. Jon1084 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 65 07-19-2013 06:42 PM
