Old 12-28-2019, 11:16 PM   #8821
kev0
Drives: '14
https://streamable.com/ukhn3
Anyways, this is the sound of air escaping when I turn my car off. Can definitely hear it coming from the air intake, but I'm a bit concerned because I don't think anybody else's car does this.
kev0 is offline   Reply With Quote
Old 12-28-2019, 11:35 PM   #8822
86TOYO2k17
Drives: 2017 toyota 86
Yeah, dont think thats normal. Never turned car off while standing outside though.
Old 12-28-2019, 11:53 PM   #8823
kev0
Drives: '14
Hmm, ok. It might be because mine is more prominent because I have the Moto-East warm air intake.
Old 12-29-2019, 08:04 AM   #8824
LOJOKO
LOJOKO's Avatar
Drives: Subaru BRZ 2013 6AT& Honda Odyssey
Hi all. Just today I found some gear oil between throttle and SC body(the elbow) .
So I removed the "rotor box" and check. see the gear oil (75w90) flows from the SC gearbox into the rotorbox And then continue to the intake pipe behind the throttle.. Even through the cooler into the intake manifold.
until I remembered an engine error code few days ago. It is "higher absolute pressure in the intake manifold"
Lowest temperature here is about 21.2℉ at night. This is the first winter I installed this supercharger kit, I used to question the tightness of gear bearings.. But everything is normal in this summer.
Engine error code lighted twice during a cold start in the past month. Did not appear again in the past week.
Leaks like this situation, Have you met on your side? Do you have any suggestions on this?
2013 Subaru BRZ 6AT; Rays 57XTREME STD SPEC 18' 9.5J Wheels; TEIN FLEX Z Coilovers; Brembo OE Gold Front Brake Kit(STI); Sprintex 210 SC;GReddy GT ver.2 Exhaust; CUSCO strut bar F/R...
LOJOKO is offline   Reply With Quote
Old 12-29-2019, 11:17 AM   #8825
86TOYO2k17
Just for sh*ts and giggles i did a log with ecutek logging time and vehicle speed. So who knows how accurate this really is.
I do have larger rear tire (255/40r17) but i always felt speedo read 1-2% low on stock 215/45R17 tire. So it is probably more accurate now otherwise increase MPH about 2%. This is with a 2017 AUTO IC Sprintex 69mm pulley WMI+92octane on 255/40r17 all season tires.
Curious what other people are logging.
Old 12-29-2019, 11:41 AM   #8826
LOJOKO
LOJOKO's Avatar
My 2013 automatic 0 to 100 km/h acceleration takes about more than 6 seconds
Old 12-29-2019, 11:51 AM   #8827
jflogerzi
jflogerzi's Avatar
Once I get my car buttoned back up I will do a run as well
2013 Series 10 FRS #553
Old 12-29-2019, 11:57 AM   #8828
tomm.brz
Drives: brz 2017 hksv2
i feel retarded, i do not understand what the column Individual is
Old 12-29-2019, 12:03 PM   #8829
LOJOKO
LOJOKO's Avatar
40MPH-2.9S +2S=60MPH-4.9S...like One speed to the next speed
Old 12-29-2019, 12:31 PM   #8830
86TOYO2k17
Basically what LOJOKO said.
Total is the total accumulated time up to that point IE 0-60 in 4.9sec.
Individual is the time from one mph to the next IE 60-80 in 2.4sec or 80-100 in 3.6sec
I just like having multiple data points to compare.
Old 12-29-2019, 12:32 PM   #8831
86TOYO2k17
What pulley and gas you on?
I also have several other minor supporting mods that contribute. But i listed the main ones.
Old 12-29-2019, 12:56 PM   #8832
jflogerzi
jflogerzi's Avatar
Used LC? What rpm if so or did you just dump the clutch.. what was your ambient temps as well
Old 12-29-2019, 01:50 PM   #8833
kev0
Drives: '14
Yes! @sroby and I have the same leak. We both spoke to Jon Bond Performance (person who rebuilds our SC's) and he said it's common with the early models. Sprintex put bearings with seals on them, apparently.
I will send out my elbow to JBP for him to bore and install new seals soon.
Old 12-29-2019, 01:53 PM   #8834
86TOYO2k17
AUTO trans. So no LC. This is taking off from Idle. Not even brake stall launch as i just sit still spinning in place if i do. Haven’t tested with the 255 tires if i can brake stall at even like 1200rpm and not spin, but with my old 225s even 1200rpm stall launch would spin too much. but i know the 255s still cant handle a 2400rpm stall launch.
Ambient around 45F
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
