Old 12-25-2019, 03:55 PM   #1
jhalagian
Drives: 2015 brz
DD Brake Pad
Was interested in getting a recommendation or two for a brake pad. I primarily DD the car, but do spirited driving where I have found the oem pads to start failing. I ride on a 255 RE71 tire. Looking for something that has improved cold bite, less brake fad, and minimal dusting. I believe a fan favorite is the DS2500.
Thanks!
jhalagian is offline   Reply With Quote
Old 12-25-2019, 04:32 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
DS2500 dusts. Not the most dusty, but certainly more so then OE. Otherwise i liked it for DD/OEM+ role, it was on OE brakes and 225 PSS grip level though.
jhalagian (12-27-2019)
Old 12-25-2019, 04:35 PM   #3
Nuts & Bolts Performance
Nuts & Bolts Performance's Avatar
Drives: 17 BRZ Series.Yellow
Thanks!
I'd recommend the Hawk HPS 5.0. It's a good street+ pad.
You'll be hard pressed to find a good pad that handles a good amount of heat, had good cold bite and doesn't dust.
It's kind of like the thought of GOOD, CHEAP & FAST. Pick 2 because you can't have all 3 in 1.
Sent from my Pixel 3 using Tapatalk
Nuts & Bolts Performance is offline   Reply With Quote
The Following 3 Users Say Thank You to Nuts & Bolts Performance For This Useful Post:
Clutch Dog (12-27-2019), norcalpb (12-25-2019), Pat (12-25-2019)
Old 12-25-2019, 05:14 PM   #4
LancePower
Drives: 2020 BRZ tS
TRD Pads
LancePower is offline   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
strat61caster (12-25-2019)
Old 12-25-2019, 06:11 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
+1 TRD or Stoptech, sounds like ds2500 might be a little more aggressive than you need. I like dding my ferodos but the do squeal a touch around town.
ineedyourdiddly
Old 12-27-2019, 10:23 AM   #6
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I changed to Stoptech Sport pads for an uncoming HPDE and Lapping sessions.
These pads were bedded in and work well for both DD and Lapping but have less cold bite than the OEM pads I removed. A real eye opener the first time out in "stop & go" GTA rush hour traffic.
Muskoka800 is offline   Reply With Quote
Old 12-27-2019, 01:21 PM   #7
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Thanks!
winmax W2-W3 for "spirited" driving and DD
winmax W4 is for Spirited and for track use in case you want to go to the track, but if not, W2 or W3
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
The Following 3 Users Say Thank You to pinoy_dorifto For This Useful Post:
Clutch Dog (12-27-2019), jhalagian (12-28-2019), smg1138 (12-27-2019)
Old 12-27-2019, 04:11 PM   #8
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Ive used the W4 sole for track use (im nub and not heavy on the brakes yet) but Ive used ebc yellow stuff for street shenanigantry and autox.
the Hawk 5.0 seems to be the speed acedemy favorite for street tuned cars with light tracking.
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
Old 12-27-2019, 04:32 PM   #9
DarkSunrise
DarkSunrise's Avatar
I had a good experience using stoptech pads on this car. Quiet, decent cold bite, better heat capacity than stock, solid pedal feel. For a street pad, that's what I would be using on this car (and actually I am using them as a street pad on my wife's GTI).
2022 BRZ Build
2013 FR-S Build
Old 12-27-2019, 07:32 PM   #10
radroach
Drives: car
My stoptechs are only OK for me, though at this time they are probably getting worn. I test them hard braking from 70 sometimes and am not impressed since they barely ever even trip the ABS system. Not sure what it's lacking in order to do its job. I liked the OEM pads feel better.
The Following User Says Thank You to radroach For This Useful Post:
Old 12-27-2019, 08:07 PM   #11
DarkSunrise
That's interesting to hear. I know stoptech split their lineup into "Street" and "Performance" pads. I was using their old 309 series SP pads (which I assume had become their Performance line), but your review makes me wonder if they reformulated the pads in the process and somehow made them worse
2022 BRZ Build
2013 FR-S Build
Old 12-27-2019, 09:02 PM   #12
Contender
Drives: 2017 Toyota 86
I know you asked about pads but you said you do spirited driving where I have found the oem pads to start failing. What brake fluid you running dot 3 or 4 can make a difference in feeling.
Contender is offline   Reply With Quote
Old 12-27-2019, 10:22 PM   #13
Minimum requirement for the 86 (and most newer cars) is DOT4 fluid.
Old 12-27-2019, 10:29 PM   #14
Vital
Drives: 2015 BRZ
Do these squeal at all?
CSG Brake Thread - Expert Tuner/Motorsport Brake Advice & Experience CounterSpace Garage Brakes, Suspension, Chassis 14 10-23-2019 12:54 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
