Old 12-26-2019, 10:58 AM   #5251
peaches
Drives: '14 BRZ Limited
Originally Posted by tomm.brz View Post
boost can change also depending on exh headers and cam timing
when a friend changed to skunk2 header from a UEL header with a hks supercharger, boost went down in higher rom.. but power in dyno went up
more efficient header = less resistance = less boost but more torque produced
even hks says that their bigger injector are REQUIRED for a hks v2 supercharger with 43mm restrictor
i run stock injectors without restrictor, in winter without problems
they are playing safe, doesn t necessarily mean you are obliged to follow what they say if it s not entirely true
of course you are right in saying it is adviced and a good move, totally agree.. but i hope you understand what I meant
I understand what you're saying, I just think that if there was such a magical header\exhaust setup then everyone with a supercharger would gravitate to it. I still have a Nameless header from when I was NA, I would like to change to an ACE to optimize\maximize the flow but as it is I'm not getting everything out of the car on track so at this point more power is useless to me.
Initially, my car put down 345 whp but CSG Mike looked at the logs and said it wasn't good a good tune, at the point I had not taken it to the track because of driveability issues. After I switched to Delicious I lost 19 whp but the logs look much better. 4 track days later it's still running. Just because the dyno reads higher doesn't mean the car is running better.
We're both giving advice based on experience, I lean towards safety.
peaches is offline   Reply With Quote
Old 12-26-2019, 01:50 PM   #5252
tomm.brz
Drives: brz 2017 hksv2
good!
anyway thanks for proving my theory
that more boost doesnt necessarily means more power
Old 12-26-2019, 03:46 PM   #5253
CSG Mike
CSG Mike's Avatar
Originally Posted by ML View Post
I have an Omni 4bar map sensor. Tune...it’s a custom shiv tune, but who knows the status of that really.
uh... in that case, I don't really have any answer for you.
Old 12-27-2019, 12:32 PM   #5254
ML
ML's Avatar
Drives: 13 White MT FR-S
When JR says that pulley makes 12psi, is that measured at the MAP, or before the inter-cooler at the recirculator?
Old 12-27-2019, 12:49 PM   #5255
tomm.brz
it s kinda the same
Old 12-27-2019, 05:46 PM   #5256
CSG Mike
CSG Mike's Avatar
At the MAP.
Old 12-28-2019, 11:41 AM   #5257
ML
ML's Avatar
Ate my first belt this morning, happened about the same time I saw 10 psi haha. looks like the blower might be sitting to far forward just a hair and caused the belt to rub on the back and then fail....thoughts?
Old 12-30-2019, 05:57 PM   #5258
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Switch to Ecutek.
JDMChris is offline   Reply With Quote
Old 12-30-2019, 05:58 PM   #5259
JDMChris
Drives: 2016
Attachment 183756
Put the all of the OEM pulleys back on.
Also you have the wrong idler on the alternator.
Old 12-30-2019, 09:24 PM   #5260
ML
ML's Avatar
Are lightweight crank pulleys no good with it? I’ve ran this Perrin one for like 7 years, I don’t even have the original anymore. And the idler pulley was the one the previous owner gave me. It’s exactly the same dimensions as the other one you are referring to.
Old 12-30-2019, 10:37 PM   #5261
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Buy a File!
Old 12-31-2019, 10:27 AM   #5262
peaches
Nope, I had a similar issue. My belt was shifting, had to buy stock pulleys except for the crank since I have a fluid dampr. Go back to stock components and it should fix it.
Old 01-01-2020, 09:42 AM   #5263
ML
ML's Avatar
Happy new year! Sorry I know I have been asking a lot questions but I have one more: in the JRSC manual it mentions to put a one way valve on the PCV line which I do not have. But I do have a catch can on the PCV line. Do I still need he one way valve?
Old 01-01-2020, 04:47 PM   #5264
mrg666
pessimistic skeptic
mrg666's Avatar
JRSC requires (and provides) a one-way valve right at the intake manifold, I have it before the catch can. If you don't have it, you can use a Boomba check valve
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
