Old 12-23-2019, 05:18 PM   #64485
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Was it less? I thought it was bout same was stock (maybe fraction stiffer than stock). Either way, next yr, I gotta replace my struts, so looking into different options.
Also annoying part of Koni Yellow is, you gotta drill bigger hole for the rear top hat.
its annoying but it really isnt that big of a deal. its an easy way to get some camber outta the car haha
and yeah its about the same as the stock shocks, but the stock shocks are so oversprung anyways
Clutch Dog is offline
Old 12-23-2019, 05:24 PM   #64486
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
ATM Koni Yellow or Cusco Touring-A. Of course, if I wanna run in SSC class in Autox, I should be running Koni Yellow... but it's not like local members care that much (& I'll prob be only one running in SSC lol).
ichitaka05 is offline
Old 12-23-2019, 05:31 PM   #64487
p1l0t
p1l0t's Avatar
So after 4 years my battery is basically DED. 8.5v after 24hrs in sub zero temps. After reading the battery thread on here I'm leaning towards a Lithium Ion...
p1l0t is offline
Spuds (12-24-2019)
Old 12-23-2019, 05:36 PM   #64488
ichitaka05
Site Moderator
ichitaka05's Avatar
Haha I had to replace mine this yr too. Mine lasted me over 5 yrs, so that's good run imo
p1l0t (12-23-2019)
Old 12-23-2019, 05:45 PM   #64489
p1l0t
p1l0t's Avatar
Yeah I'm on 4yrs which is typical I guess. 5yrs is great. You must be from Southern Japan where it's warm. Or you have a heated garage?
p1l0t is offline
Old 12-23-2019, 05:52 PM   #64490
ichitaka05
Site Moderator
ichitaka05's Avatar
No, I live in middle of nowhere... aka Utah. Hot and cold is extreme here. Within that 5 yrs, I had a shop repair (car wreck) and they recharged my battery too, so that might helped too.
p1l0t (12-23-2019)
Old 12-23-2019, 05:58 PM   #64491
p1l0t
p1l0t's Avatar
Yeah must be. My battery was acting up last winter even but then Spring came and it was magically fine again so I forgot about it. This winter my car becomes a pumpkin in no time. It was so bad this morning my jumper wouldn't even recognize that it was a battery. Took the wagon to work. I have it on a trickle charger now and it might start again after that but I'm definitely replacing it ASAP. I just haven't totally decided if I want to go Lithium Ion or not but I like the idea of light weight and easy start even if you only get 2k of them or whatever.
p1l0t is offline
ichitaka05 (12-23-2019)
Old 12-23-2019, 06:47 PM   #64492
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I thought Koni started selling full replacements for the twins?
finch1750 is offline
Old 12-23-2019, 06:57 PM   #64493
ichitaka05
Site Moderator
ichitaka05's Avatar
They did? I didn't know bout that
Old 12-23-2019, 07:26 PM   #64494
finch1750
finch1750's Avatar
https://www.tirerack.com/suspension/...ort&cat=Shocks
Old 12-23-2019, 07:43 PM   #64495
ichitaka05
Site Moderator
ichitaka05's Avatar
Oh~ that, yeah I knew bout that one. I thought you were talking bout full replacement including top hats that doesn't need to drill and so forth.
Old 12-23-2019, 09:04 PM   #64496
finch1750
finch1750's Avatar
Oh, I didnt realize the top hats had to be drilled. I thought you were talking about how to deal with the inserts and cutting/drilling the bottom.
Old 12-23-2019, 09:07 PM   #64497
ichitaka05
Site Moderator
ichitaka05's Avatar
nah. Rear Koni Yellow struts require lil bit of drilling on stock top hats for struts to fit. it's not much... just extra hassle.
Old 12-24-2019, 09:59 AM   #64498
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
That is the debate I am currently having with myself...
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
p1l0t (12-24-2019)
