Old 07-17-2017, 03:10 PM   #799
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by malubawla View Post
Thanks man I have the funnel and bleed my system for 15 mins. Gonna bleed it now for another 30 mins and see what happens
Make sure you turn the heat on all the way and turn on the cabin fans while you do it! Open/Close the bleeder screw at the firewall entrance a couple times as well. Wear gloves when you do it.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Sleepless (07-17-2017)
Old 07-22-2017, 03:39 AM   #800
sw20kosh
Drives: 2013 Black FR-S
Make sure your slim fans aren't the super weak ones. Also upgrade your oil cooler core to a 20 or 25 row and/or mount it to the side. The idea is to not block the radiator too much and to dump the oil heat elsewhere than directly back into the coolant/engine bay.
Old 07-24-2017, 11:17 AM   #801
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
So I bleed my system for another 30 mins, had some bubbles but not much.
When i drove to work in the morning at 6am outdoor temp as 85F. After my 25 mins drive, coolant temps highest was 205Fand oil temp was 195F.
When i drove back home at 7pm outdoor temp was 96F. After the same 25 min drive home, coolant temps highest was 229F and oil temp was 224F.
I am going to cut my fender vents and relocate my oil cooler,then give an update then.
malubawla is offline   Reply With Quote
Old 12-21-2019, 12:03 PM   #802
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
@Evasive Motorsports
Their 2018-19 setup is rocking the 'smile' grilles as seem on Porsche's GT3-GT4 cars.
Rennline has a vent kit for a bit of $200USD for adding the vent to non-GT porsche cars. Wonder if it translates over for the twins...
http://www.rennline.com/Rennline-GT3...oductinfo/E9X/
[ame]http://www.youtube.com/watch?v=Y6IZTEkRrNc&t=2m55s[/ame]
Kind of an odd place for a vent as their upper V-mount setup would have to be pretty horizontal for get the extraction, to the point where it is almost out of the main opening's air stream. On an FA20 it would stock setup it would likely rob from your airflow and take from the OEM airbox's scoop.
The Following 2 Users Say Thank You to Kiske For This Useful Post:
jflogerzi (12-23-2019), ML (12-21-2019)
Old 12-21-2019, 12:26 PM   #803
ML
ML's Avatar
Drives: 13 White MT FR-S
That exactly my thoughts as well. Probably works well for their v-mount though.
Old 12-24-2019, 08:23 PM   #804
ML
ML's Avatar
I blocked(is that the right term) in my cooling stack this week. spirited driving with 50f ambient temps I was seeing about 202-204f oil temps. Today it was in the upper 60s, and oil temps sat around 192-195f. all .025 thick aluminum sheeting.
Old 12-24-2019, 08:46 PM   #805
Ashikabi
Ashikabi's Avatar
Attachment 183706
Odd choice for ducting
Old 12-24-2019, 09:00 PM   #806
ML
ML's Avatar
what are other people using? ABS? This is probably lighter or as light, and I enjoy working with aluminum.
Old 12-24-2019, 09:12 PM   #807
Ashikabi
Ashikabi's Avatar
The design more than material. I used aluminum myself. Usually a cone from the grill directly to the radiator blocking air from going anywhere except the radiator is how it's done. I'm not trying to shit on you, if it works, it works
Old 12-24-2019, 10:22 PM   #808
ML
ML's Avatar
Oh ok gotcha. Yeah it’s hard to see but that’s exactly what it’s doing. Everything is blocked except for the path to the intercooler and everything behind it. I just didn’t angle it towards the middle and instead just a 90 angle. This is my first time making a piece like this So it will probably change once I get it on a track.
Old 12-24-2019, 10:42 PM   #809
Ashikabi
Ashikabi's Avatar
I went back and inspected your picture further. I didn't realize it went back in towards the radiator. My mistake. If you want more air, you can delete your mustache and get a drift bar to replace the stock crash bar. The sides of the grill that you covered I filled with scoops for my brake ducts if you would prefer that space to be functional
Old 11-25-2020, 04:28 PM   #810
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bump for new members and for people to post new information about cooling modifications...
The Following User Says Thank You to Lonewolf For This Useful Post:
lamawithonel (11-25-2020)
Old 11-26-2020, 10:55 AM   #811
pallen
pallen's Avatar
Drives: 2017 Toyota 86
I have read the entire thread, but curious if anyone has tried venting heat out the fake side vents on the front fenders?
pallen is offline   Reply With Quote
Old 11-26-2020, 10:59 AM   #812
Gamace
Gamace's Avatar
Drives: 2012 Toyota 86
Well to combat the heat with my setup (HKS Super Manifold Boxer Spec) I just installed the Laile Beatrush Underpanel and that totally takes care of the Headers. I would like to vent heat though the fender garnishes but I don't see any garnish that's made with mesh anymore since the Prova one got discontinued.
Toyota 86 in the building!
Gamace is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
