Old 12-03-2019, 09:03 PM   #5209
ReDestructDead
Drives: White 2018 BRZ
It depends on the impulse.
In the FA20's case, the E85 is easier, because the amount of **time** spent pushing the piston down during combustion is greater, rather than the amount of **force** against the piston. This is courtesy of the ignition timing advance, rather than exploding more gas with more air to get a bigger boom.
Another persoective: more timing advance allowed by ethanol allows you to harness more of the energy in the fuel used. You have the same energy density, because stoich hasn't changed, and your air intake hasnt changed. You are able to use more of it because you can advance timing without knocking. More boost = more fuel = bigger kaboom = more torque. However, because it's MORE boost, you (long story short) get LESS ignition timing, so while the boom is bigger, you are able to harness less of it.
Remember, engines don't deliver a constant level of torque like an electric motor, but rather, deliver pulses. These pulses are smoothed out by things like heavy pulleys, flywheels, clutches, transmissions, etc. E85 = longer pulse. More boost = stronger pulse. Net torque output = sum of the pulse, whether longer and/or stronger.
Hopefully that made sense. I can elaborate more. There's many other factors as well, but this is just a very surface level version.
Makes perfect sense, thanks sensei. I think I'll be upgrading to a flex fuel setup next spring.
ReDestructDead is offline   Reply With Quote
Old 12-16-2019, 03:56 PM   #5210
mrg666
pessimistic skeptic
mrg666's Avatar
Passed 30K miles with JRSC. Anybody else with more miles?
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
HaXx (12-18-2019), marco1ca (12-17-2019)
Old 12-17-2019, 12:34 PM   #5211
marco1ca
Drives: Toyota Celica
Good post, how 'bout if you and others also list their set-up and octane being used, thanks
marco1ca is offline   Reply With Quote
The Following User Says Thank You to marco1ca For This Useful Post:
mrg666 (12-17-2019)
Old 12-17-2019, 05:12 PM   #5212
mrg666
pessimistic skeptic
mrg666's Avatar
Basically stock JRSC install but since you asked these are all the changes related to engine. I use 93 octane gas.
Jackson Racing C30 Supercharger + JR factory tune
STI OEM oil cooler
PCV and crankcase oil catch can
STI PCV Valve
RKX recirculation valve (stiffer springs)
AEM Dryflow air filter
Fluidampr Crank Pulley
Braille 21 battery
2017+ improved header
HKS dual resonated front pipe
HKS Hi-Power Spec-L catback
The Following 3 Users Say Thank You to mrg666 For This Useful Post:
HaXx (12-18-2019), marco1ca (12-19-2019), sroby (12-18-2019)
Old 12-17-2019, 11:45 PM   #5213
CSG Mike
CSG Mike's Avatar
CSG BRZ 2.0 saw nearly 60k miles on the JRSC, in various trims. I believe the kit went on when the car had like 900ish miles on it?
marco1ca (12-19-2019), mrg666 (12-18-2019)
Old 12-18-2019, 08:52 AM   #5214
peaches
Drives: '14 BRZ Limited
C38
HBP
1,000 cc injectors
Nameless headerback
JRDROC
fluid dampr
E-85 as much as I can, sometimes have to go back to 93
Delicious flexfuel tune
I've put 10k miles on it since June, bought it used with alleged 5k miles. Tracked @ Sebring, PittRace, and Road Atlanta.
BTW, the vibration issue I posted a while back was due to the cf driveshaft. I replaced it with a stock one and had no issues reaching 140 at Road Atlanta. The manufacturer is checking it to see if it's out of balance or if my drivetrain is too stiff for it.
peaches is offline   Reply With Quote
The Following 4 Users Say Thank You to peaches For This Useful Post:
CSG Mike (12-18-2019), marco1ca (12-19-2019), mrg666 (12-18-2019), Stonehorsw (12-08-2020)
Old 12-18-2019, 09:20 AM   #5215
amcp1
Drives: frs
JR C30 kit, 91 octane standard tune, JR oil cooler and Rotrex cooler. No other engine/exhaust mods.
Its been on the car for 20k miles. Its my daily and occasional DE car. Only issue I've had with the kit was the supplied diverter valve which I replaced with the RK valve after the 2nd one failed. Its been exactly what I hoped for. Reliable and gave the car some ass.
amcp1 is offline   Reply With Quote
The Following 3 Users Say Thank You to amcp1 For This Useful Post:
Old 12-18-2019, 10:47 AM   #5216
HaXx
Drives: jrsc_brz
jr c30, no oil cooler, invidia n1--- installed 3/22/2016~15k-20k miles on the kit
262wheel /198ftlb
car is dd, did one track day
no problems, just changed the s/c air and fluid filters last year
HaXx is offline   Reply With Quote
The Following 3 Users Say Thank You to HaXx For This Useful Post:
Old 12-18-2019, 11:02 AM   #5217
stlgrym3
my '17 BRZ is back to bone stock. i'm still waiting on the JR comes out with CARB legal tune for the '17+ models. until then i will be on the sideline looking in LOL
stlgrym3 is offline   Reply With Quote
Old 12-18-2019, 11:39 PM   #5218
ML
ML's Avatar
Drives: 13 White MT FR-S
Hey guys, just got a kit used. I was wondering if one of you long term jrsc guys could give us the high points of this 373 page thread? TL;DR of sorts for the c30/c38 kits?
Old 12-19-2019, 01:27 PM   #5219
HaXx
Drives: jrsc_brz
tl dr= forced induction does not make your car a time bomb. replace the kits air filter and inline oil filter every two years or 50k miles. oil cooler is A MUST if you track if you track more than once a year.
CSG Mike (12-19-2019), ML (12-19-2019), mrg666 (12-19-2019)
Old 12-19-2019, 04:36 PM   #5220
CSG Mike
CSG Mike's Avatar
There is no TL;DR. What information are you looking for? Perhaps I can help.
mrg666 (12-19-2019)
Old 12-19-2019, 05:33 PM   #5221
mrg666
pessimistic skeptic
mrg666's Avatar
I checked your "Garage" link. Your car is basically stock under the hood if your configuration is up to date.
Perrin Pulley
Unichip
Injen Intake
Stabilus hood Props
Your injane intake will be replaced. Perrin pullley does not do much more than looking good. A damper pulley would help better with FI. I don't know what is unichip.
You will need either factory tune from JR or CSGMike can also help you with etune.
Like HaXx wrote, getting an oil cooler is a very good idea if you will ever track the car, even once.
If you install yourself or get it installed at a shop, pay attention to pipe/hose joints for boost and vacuum leaks. Also, the EVAP purge solenoid under the intake manifold is known to leak, clamp both ends of the hoses connected to that solenoid
Since your kit is used, you will probably need the followings which are available from JR or CSG.
- Rotrex sx150 traction fluid and filter
- Accessory belt specific for JRSC
- Air filter
- Plastic Check valve connected to vacuum hose on the intake manifold (good idea to get a new one)
- Recirculation valve (if too old)
Also, I would replace the MAF sensor with a brand new one since your car is 2013.
HaXx (12-19-2019), Milhouse86 (12-19-2019)
Old 12-19-2019, 06:27 PM   #5222
ML
ML's Avatar
Perrin Pulley
Unichip
Injen Intake
Stabilus hood Props
- Air filter
Wow, umm thanks for the responses! I bought the car new over 7 years ago, and I don't think I have updated that "garage" in like 6 years.
I already have the kit installed, and the car is dedicated track car
My Build thread
I guess just looking for anything in the thread that needs to be pointed out after so many people have ran the kit for years now, like "tips and tricks" kinda info. I have a catch can, and everything is running great right now.
The Following User Says Thank You to ML For This Useful Post:
HaXx (12-19-2019)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
