| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#57 |
Drives: Subaru BRZ
I thought the Suzuki was always 4WD, low gear set when things got really tricky for the little thing..
#58 |
Rice King
As far as I know, most if not all 4WD vehicles have the ability to turn off the 4WD and go to 2WD, unlike an AWD system.
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#59 |
Famous Potatoes
Drives: '15 ultramarine
4wd and awd are two very different animals.
#60 | |
I believe that the 4WD/AWD split was sort of established back in the day when to switch over your 4WD vehicle you had to stop, get out, lock on the front hubs and then get back in and drive. That process of course went away with the automatic or electronic systems but the definition stayed.
#61 |
How so? Both have 4 wheels that propel the vehicle.
#62 |
Famous Potatoes
Traditional 4wd with transfer case, where front and rear axles are locked is only to be used on slick surfaces. There is no slip in the system and requires the slip of the ground. Driving them in 4wd on dry pavement will ruin them.
Awd systems have slip units between front and rear drives. Huge difference. And auto locking hubs suck. They stick all the time, and are weaker than manual locking hubs. First thing serious 4x4 people do is swap to manual locking hubs. |
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#63 | |
I've always found the Auto 4WD the best for the mess we get around Atlanta unless it's hop deep and I know I'm crawling.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | RToyo86 (12-16-2019) |
#64 |
Rice King
Well I'd assume the use of High and Low would be specific to when you happen to be in a bit of a pickle.. (stuck or something)
Glorious Honda.
#65 |
Drives: Subaru BRZ
^^^^^ Glad we're all sorted on different drives ^^^^^
| The Following 2 Users Say Thank You to JD001 For This Useful Post: | Dadhawk (12-16-2019), Jordanwolf (12-16-2019) |
#66 |
Drives: 17 Asphalt 86
My old 5spd AWD Suzuki sx4 had a clutch based center diff for the AWD. It had a 2wd/auto and 4WD lock for sticky situations that would disengage at 30kmh or so.
That thing was a tank for what it was when you had good winter rubber on it. I plowed through snow that was at license plate level just below the headlights and it took it like a champ. ![]() This car is no wear near as capable but beyond crazy snow storms of that caliber I managed just fine every day last season except for one. The car dragged it self out of this mess with out much fuss. Some revs in reverse and about 20-30 seconds. Compared to a coworker with a genesis which spent 40 minutes to do the same. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | JD001 (12-16-2019) |
#67 | |
Drives: Subaru BRZ
| The Following 2 Users Say Thank You to JD001 For This Useful Post: | soundman98 (12-16-2019), Tcoat (12-16-2019) |
#68 |
I think that most 4WD now have an auto setting.
#69 |
Yea, probably so. It wasn't when mine was built in '04. There are some trims that don't have the "auto" button.
#70 |
Drives: Red 2019 Subaru BRZ
LOL. My 87 Sammy is a beast. It goes anywhere I'm brave enough to take it. One advantage real 4WD has is that the axles run slightly different ratios. Effectively the vehicle is pulled apart when in 4 wheel. Smooths out the rough stuff.
As it is extremely short, light, and has massive tires, for its size, at low pressure it seldom actually needs 4 wheel. We had pretty god snow last winter and it never saw 4 wheel, for snow, at all.
| First Driving Experience in the SNOW!! | Lync | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 01-22-2016 11:19 AM |
| How much snow is too much? Guelph/London/ Barrie driving? | rpvnwnkl | CANADA | 26 | 10-31-2015 05:29 PM |
| Snow and Ice Driving | RedFRS4me | Northwest | 25 | 02-11-2014 10:35 PM |
| I Spent the Weekend Driving my FR-S in Snow - Insight | SkitterSkotter | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 11-16-2012 04:56 PM |
| Driving experiences in the snow | jmathew8130 | BRZ First-Gen (2012+) — General Topics | 8 | 11-15-2012 11:14 PM |
