Old 12-15-2019, 02:50 AM   #1
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Help! Re:clutch install!
Hello. So i did my own clutch install. After all is done. Car turned over and it runs. Tested while car in jack. Transmission is all working and going in all gear when car is off and even when engine is running while clutch is in but the problem is that in neutral wheels are running 1-2mph and when I put it in first gear the car stumbles when I take off clutch and sounds terrible. I had trouble putting the transmission but eventually in my last try and aligning it, it went in smoothly. Did all proper steps with torque specs and alignment. What could it be? Did not change flywheel but the flywheel moved a little bit when I removed the pressure plate. Could that be a culprit?
FYI: Just to think about it I did do my clutch pedal adjustment before all this and that was from the old clutch. Should I raise it back? I did read from the manual that during break in there is a part of the break in period regarding adjusting clutch grab in between certain miles. Clutch is Exedy OEM replacment. Just clutch and pressure plate.
Thank you and will appreciate the help.
tintumz22 is offline   Reply With Quote
Old 12-15-2019, 11:08 AM   #2
toast
Drives: 14 BSP Edelbrock BRZ
When on jacks, engine running, in neutral and clutch engaged it is normal for the wheels to move, there is drag within the transmission.
I don't follow your words totally - when you have the clutch pedal pressed in and you engage first gear you get a bad sound? That sounds like your clutch isn't fully disengaged and you need to raise your pedal.
What you you mean the flywheel moved a little? It rotated? That is fine. If you mean you had side to side motion on the flywheel that is very much not ok.
toast is offline   Reply With Quote
Old 12-15-2019, 11:33 AM   #3
tintumz22
tintumz22's Avatar
I apologize. It was very late in the evening when I got done and was tired.
Yes i get a bad sound, like grinding sound. So i had to pressed the clutch pedal back in. That is my suspect too after remembering I did my clutch pedal mod.
When I was removing the bolts from the pressure plate it did rotated a little bit but rotated it back to where I marked it. It was solid and not moving side to side.
Old 12-15-2019, 12:07 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Yes i get a bad sound, like grinding sound. So i have to pressed the clutch pedal back in. That is my suspect to after remembering I did my clutch pedal mod.
When I was removing the bolts from the flywheel it did rotated a little bit but rotated it back to where I marked it. It was solid and not moving side to side.
I'm confused by these statements. You removed the flywheel, but you didn't replace it with an aftermarket flywheel; is that what you are saying? Did you resurface the flywheel at least? And how could the flywheel move when removing the pressure plate? Do you mean rotate because that is fine?
If your clutch pedal was partially depressing the clutch then you wouldn't hear grinding sounds. If that was the case then we would all hear grinding sounds when we depressed the clutch. At worse, you would fee as if the car's clutch was slipping or unable to grab.
Metal on metal grinding sounds are not good. I don't know if the crank position sensor plate behind the flywheel got moved or put on backwards. I don't know if you didn't use the alignment tool correctly. I don't know if you failed to use proper lubricant on the TOB, but I would suggest removing everything and looking.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
tintumz22 (12-16-2019)
Old 12-15-2019, 12:27 PM   #5
toast
He removed the pressure plate bolts, which are in the flywheel.
The flywheel rotating a bit is just the engine rotating a bit, not a problem.
I don't think your pedal is partially pressing the clutch in, I think you have the pedal adjusted too low and when you think the clutch is totally disengaged because the pedal is on the floor it is still dragging. Raise the height of the pedal several turns of the rod.
The Following User Says Thank You to toast For This Useful Post:
Old 12-15-2019, 12:29 PM   #6
toast
After rereading your last post I think maybe I still didn't get what you were saying.
1: Clutch in
2: Push gear lever into first
3: Clutch out and drive away
During which number are you getting the crunching sound?
Old 12-15-2019, 12:59 PM   #7
tintumz22
tintumz22's Avatar
1: Clutch in
Number 3.
Good news!!
Problem solved! It is the pedal being too low. I raised it just few moments ago and no grinding sound now. Car is still in stands. I will test drive later to see how is it on the road. I check back and will update.
The Following User Says Thank You to tintumz22 For This Useful Post:
Irace86.2.0 (12-16-2019)
Old 12-16-2019, 12:42 PM   #8
Irace86.2.0
Number 3.
Good news!!
What you are calling grinding is probably just the two surfaces sliding across each other because they are barely touching/slipping. The sound of a clutch slipping across each other is much different (like sand paper) than a metal on metal sound, which is more what I associate with grinding.
Old 12-16-2019, 01:33 PM   #9
tintumz22
tintumz22's Avatar
Most likely you are right. It was one time that I did it and I got scared so I pressed in the clutch pedal right away and turned the car off. Refilled the trans fluid and made sure it is level, test drove the car for the first time last night and drove the car to work this morning. Everything is smooth and no more scattered marbles sound from the old TOB! Changed shift springs and fluid for both diff and transmission too. My 2014 car feels like a new car again! Thank you for y'all replies!
Old 12-16-2019, 01:40 PM   #10
toast
My guess is that one time you didn't have the clutch fully disengaged (because of the pedal adjustment) so it didn't fully slip into gear and when you let the clutch out you had gear mesh noise.
Glad it worked out and was something simple.
Old 12-16-2019, 02:45 PM   #11
tintumz22
tintumz22's Avatar
I'm glad too that it was something simple and did not have to take off the transmission again.
Thank you again for all the help!
Shop to a new clutch install jflogerzi Southern California 1 05-20-2019 12:00 PM
No-start after clutch install chargedup Engine, Exhaust, Transmission 11 03-27-2017 05:22 PM
Shops for Clutch Install Wyattkb Arizona 10 12-20-2016 07:57 PM
Clutch install questions wootwoot Engine, Exhaust, Transmission 25 12-29-2014 04:18 PM
DIY CLUTCH INSTALL .. charged86 DIY (Do-It-Yourself) Guides 3 09-13-2013 12:10 PM
