Old 12-14-2019, 11:23 AM   #57
Ok, now them's fightin' words.
I kid. Helicopters are my first love. I've been enamored with them since a kid living near Ft. Bragg/Pope Air Force base.
p1l0t (12-14-2019), Ultramaroon (12-14-2019)
Old 12-14-2019, 11:28 AM   #58
do you put your gps within the view of the windshield??
All our vehicles have the GPS in the headunit, i don't use a portable GPS, and almost never use my phone for navigation. I feel I'm more "street aware" than most, but do find myself depending a little heavier on the GPS directions than I used to.
Used to be if I drove anywhere once using a map or written directions, I would never need them again. Not so much any more. I was never good at giving directions though because I have always navigated more by landmarks then by street names.
soundman98 (12-14-2019)
Old 12-14-2019, 11:30 AM   #59
I'll take a 10yr old certified normal airplane any day of the week.
Absolutely, that's basically "last year's model" in airplane years. In fact I don't think I've ever flown anything newer than about 10 years old. Even the one I just bought is 15 years old.
p1l0t (12-14-2019)
Old 12-14-2019, 11:32 AM   #60
p1l0t
p1l0t's Avatar
I always use Waze even if I know where I'm going. You can't see around corners and if the traffic is building up it's nice to get off the exit before and sit in stop and go. Then again I have long commute so it matters more.
Old 12-14-2019, 11:35 AM   #61
ls1ac
ls1ac's Avatar
Many of the newest cars do not have GPS and maps as they are out of date when delivered. Phones are directly linked to the head unit. Android auto and apple maps, and things like Waze will display on the head unit. They are current and will even give road conditions, police, wrecks and detours.
The Following User Says Thank You to ls1ac For This Useful Post:
p1l0t (12-14-2019)
Old 12-14-2019, 11:36 AM   #62
I've had zero luck trying to use Waze, although I know a lot of people who love it and swear by it. Every time we've tried to use it on a trip or whatever it lead us into situations worse than what we were in, or took us down very bad country roads.
I have a long commute as well (40 miles each way) but for the most part it's country roads with few accidents. When there is one, I know the alternate routes.
Old 12-14-2019, 11:39 AM   #63
p1l0t
p1l0t's Avatar
Oh yeah Waze will take you down back ass roads but it's only when the highway average speed gets down below about 30mph. At that point it's better to go direct than the long way.
Dadhawk (12-14-2019)
Old 12-14-2019, 01:01 PM   #64
Atmo
Drives: TBA
Since this thread is so far OT, I'll post this unrelated story:
Harbour Air successfully flies world’s first electric commercial aircraft (VIDEO)
https://www.victoriabuzz.com/2019/12...ircraft-video/
I'd miss the sights, sounds, smells and oil leaks of the standard 450-hp, nine-cylinder Pratt & Whitney R-985 Wasp Junior radial engine.
Atmo is offline   Reply With Quote
The Following User Says Thank You to Atmo For This Useful Post:
Old 12-14-2019, 02:14 PM   #65
soundman98
ProCrastinationConsultant
soundman98's Avatar
nothing says success like a total-loss oiling system!
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Dadhawk (12-14-2019), Ultramaroon (12-14-2019)
Old 12-14-2019, 07:28 PM   #66
[B]Harbour Air successfully flies world’s first electric commercial aircraft .
It makes some sense for the short haul flights that Harbour Air does, gets the technology into a bigger commercial arena. have to wonder about recharging times. Commercial air flight is all about turn-around time. I couldn't find anything saying how long it takes this to recharge.
Atmo (12-15-2019)
Old 12-14-2019, 10:50 PM   #67
I do too.
Choppers are the coolest.
Dadhawk (12-15-2019)
Old 12-15-2019, 12:37 PM   #68
Atmo
Drives: TBA
I wondered about that too, plus useful load, flight into known icing prevalent there, cold weather performance degradation and airworthiness in general with the battery weight presumably in the wings. Not to mention how an electric motor is affected in a marine environment. The CEO hints at new battery tech on the horizon suitable for this application.
He also said the e fleet will have 30' + 30' reserve endurance that will accommodate most of their 500,000 annual passengers but will be all certification testing at first before converting the entire fleet. He said it'll save operating expense by having a longer TBO than even the turbines.
The CEO bio is pretty cool. A visionary as passionate about flight as he is extreme mountain biking. And drove a Toyota truck.
https://www.bcbusiness.ca/greg-mcdougall-float-king
https://www.vancouverisawesome.com/v...-world-1942948
Old 12-15-2019, 07:12 PM   #69
Well, I figure in a conversion you could put weight in the wings equal to the landing fuel weight minus some fudge factor. Of course that means you are always carrying that weight around, so it's costing you to fly the weight, plus you can't use "fuel" to help with weight and balance on shorter flights.
For a conversion you are going to have to have a plane with a pretty steep fuel capacity to get anything useful out of the conversion. You certainly couldn't do it in a small plane. The reason it works in larger planes is because you can get enough batteries in there to be useful.
For example, mine is a two seater that will fly 4 hours with reserve on the 27 gallons on-board. Given that a Tesla Model S battery back weighs 1,200lbs, you aren't going to get much range out of converting mine to battery given the 162 pound weight of the fuel capacity. You might be able to taxi it to the end of the runway.
I'm not accounting for the lighter engine, etc you'd get with the conversion, but in the end its all marginal, and not even worth considering for any practical purpose.
Eviation says they'll get almost 600NM out of their 3,600kg battery pack in their 9+2 jet. Not sure a 2,500 lb useful load is really an 11 seat aircraft with 227lbs per passenger (including luggage, etc) particularly when you can't adjust fuel to accommodate but they are at least doing it right, designing the plane from the ground up.
(And yes I realize my conversion description is oversimplified, but I think its a starting point to show its probably not practical under a certain size)
Atmo (12-15-2019)
Old 12-15-2019, 09:13 PM   #70
Atmo
Drives: TBA
Your plane sounds amazingly efficient. Don't keep us guessing (Van's Aircraft)!?
Welcome Lighting/Departure Lighting for Headlights Akuma147 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-01-2016 12:46 AM
Lane splitting? Packofcrows Off-Topic Lounge [WARNING: NO POLITICS] 79 08-15-2016 07:31 PM
Two Lane Black Top twincamRob FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 11-08-2012 08:30 PM
The Fast Lane Car Review of the FR-S track_warrior BRZ Photos, Videos, Wallpapers, Gallery Forum 10 05-06-2012 05:21 PM
Why I drive in the left lane. 1660 Off-Topic Lounge [WARNING: NO POLITICS] 11 08-03-2011 02:31 PM
