Old 06-27-2019, 04:39 AM   #1
Acuario
Drives: BRZ MY2017
Joying 7" head unit in MY2017 BRZ
I just finished fitting a Joying head unit in my MY2017 BRZ. The head unit is their model JY-UO128N4G.
The cable harness I used it the Hilux one, this connected with everything and did not need any modification Hilux harness
The Starlink in this model BRZ has a trapeze shape which makes life a little more difficult
There is an adaptor available but it turns out it is for a 'different' universal size hole - how many universal sizes are there???
My solution was to print my own with a 3d printer. The result is more than satisfactory and it fits both the head unit and dashboard hole perfectly. The hole dimensions are 100.5 * 179 and it also fits nicely on other Chinese head units. You can download the design here:
BRZ Audio
At the same time I installed a rear view camera which I obtained here:
Rear view camera
Acuario is offline   Reply With Quote
Old 12-13-2019, 06:26 AM   #2
Acuario
Drives: BRZ MY2017
It turns out the Hilux harness is almost correct, I hadn't noticed (but mrjj did) that the rear speakers are reversed.
It's actually not too difficult to extract the pins from the Joying harness (it's the 6 pin connector) and swap them over - I did it in a few minutes. You need a very thin screwdriver or a strong pin or needle, from the pin side, at the bottom of the pin, there is a small plastic tag you need to move down, then the pin will pull out from the cable side. Nothing breaks so no need to worry, just a bit fiddly.
The Following User Says Thank You to Acuario For This Useful Post:
mrjj (12-13-2019)
FS: Joying Head Unit Cole Canada Classifieds 6 12-11-2018 11:57 PM
Joying Head Unit in the Toyota 86 GT FRS2017 Electronics | Audio | NAV | Infotainment 1 09-05-2017 08:59 AM
2014 FRS Joying Head Unit ImDatSlaya Electronics | Audio | NAV | Infotainment 0 06-30-2017 11:17 AM
Joying Head Unit - Which model randomthoughts Electronics | Audio | NAV | Infotainment 4 05-29-2017 05:56 PM
Joying head unit with 2014 a frs ImDatSlaya Electronics | Audio | NAV | Infotainment 0 01-28-2017 06:32 PM
