Drives: 16' BRZ
WedsSport's vs Titan 7's 18x9.5?
I'm looking to buy a couple sets of wheels to clear larger brakes. Titan 7 wheels are forged which I like but they are also somehow 1LB per corner heavier than the WedsSport's in the same 18x9.5 size. Surprisingly the non-forged WedSport's are more expensive. Although the price difference is negligible. Titan 7's have a +40 offset instead of the +45 on the WedsSport's. I would think the +40 would provide better fitment, is that correct?
Anyone have experience with one or both of these wheels at the track? Buttonwillow seems to really like to bend wheels. I'm starting to learn how much of a consumable wheels really are. So cost and easily available are definitley important to me. I have also heard that forged wheels are not necessarily more resistant to bending than quality flow form wheels, not sure if this is true? I am open to other wheels of similar cost and quality if people have other suggestions? Leaning towards the WedsSports but I would prefer the +40 offset. Maybe I will buy a set of each and report back which holds up better... |
#2 |
Forged =/= Lighter.
Forged = denser metal, with better crystalline structure, which is stronger. This allows a forged wheel to potentially be lighter. Also, it gives the forged wheel a superior mode of failure. Buy based on strength and rigidity, not weight. I bet those forged, heavier wheels are harder to bend than the lighter, cast wheels. I use a lot of 57CR for a nice balance of cost and strength. Weight is the least of my concerns for the most part. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#3 |
Drives: JRSC BRZ SOLD
Forging doesn't make a subpar raw material better and all forging techniques aren't created equal. Just something to keep in mind. You have a flow formed wheel costing the same a forged wheel. I'd be specious of the cheap forged wheel, this is after working in the alloy industry for a bit.
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | GrabTheWheel (12-20-2019) |
#4 | |
Drives: 2018 BRZ tS
If you are really looking at wheels as a consumables, this may be the way for you to go. If you are also concerned about wheels as a consumables, then tires are obviously on your radar, and that cost, as pointed out, is also significantly cheaper than the 18's. I haven't mounted and/or used the Apex wheels yet (yay winter!), so I can't say how I like running a 17 just yet, but just figured I'd share. Currently, I run the Mach V Crucial (18x9.5) Flow-Formed, and weighs in at 19.5lbs. No issues about a year in, with multiple days at VIR, Dominion Raceway, and Summit Point. Price point is about $1300/set. Some pictures can be found here: http://www.ft86club.com/forums/showt...hlight=crucial |
#5 | |
Drives: 16' BRZ
#6 |
Drives: '23 BRZ
I ran 17x9 fronts with 328mm brakes on my tracked 550hp FD fwiw...
Regarding forged vs. cast, I'd just go with a reputable manufacturer and whichever wheel you prefer for looks and can afford. The weight difference isn't that big a deal. Material is one thing, but design is really more important. Very strong material with a too-tight radius at the wrong place can fail. Weaker material with fewer and less intense stress concentrations can be strong and durable and reasonably lightweight. |
#7 | |
Drives: 16' BRZ
#8 |
Drives: 17 BRZ Series.Yellow
Do you have any brake cooling?
What pads are you using currently? I don't think the simple answer is larger rotors/BBK. Sent from my Pixel 3 using Tapatalk |
| Titan 7 T-R10 Black 18X9.5 +40 On RS 1.0 | Karfield | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 05-10-2019 07:49 PM |
| Wedssport SA-72r 18x9.5 +45 | Kendallkab | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 12-13-2018 12:18 AM |
| WTB: Single Wedssport TC105N 17x9+35 Titan | Muppy | Want-To-Buy Requests | 1 | 01-05-2016 10:48 PM |
| FS: WedsSport TC-105N 17x9 +35, titan silver | tigermack | Wheels and Tires | 20 | 08-06-2015 12:01 AM |
