Old 12-12-2019, 03:00 AM   #1
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Suggestions for sticky window
Hi guys,
Does anyone have any suggestions to prevent the window to stick to the door rubber seal in the cold mornings?
Should I apply some WD40 or anything else?
Thanks
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following User Says Thank You to Busybee For This Useful Post:
korhun (12-12-2019)
Old 12-12-2019, 10:58 AM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by Busybee View Post
Hi guys,
Thanks
We don't have snow here but I use grease on my window seals every few months. I have a "first gen" so there is window indexing issues where the windows keep rubbing the door seal and eventually it destroys them. Also messed up my tint.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
Busybee (12-12-2019)
Old 12-12-2019, 01:00 PM   #3
WNDSRFR
Drives: FR-S,GTI
No snow here either. But I also have the window indexing issues. I use ArmorAll. Use it once a month or so and all is good.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
Busybee (12-12-2019), humfrz (12-12-2019)
Old 12-12-2019, 02:03 PM   #4
Grady
Grady's Avatar
Baby powder.
The Following User Says Thank You to Grady For This Useful Post:
WNDSRFR (12-13-2019)
Old 12-12-2019, 02:18 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
3m window channel lube
https://www.amazon.in/3M-Window-Chan...language=en_IN
WD40 would work short term in a pinch (don't use it), but for long term the 3M product will be better for the rubber seal's life.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Busybee (12-12-2019), RToyo86 (12-13-2019)
Old 12-12-2019, 07:01 PM   #6
Busybee
Busybee's Avatar
Would really appreciate if you share which product you use from armorall
Thanks
Old 12-13-2019, 09:33 AM   #7
WNDSRFR
Drives: FR-S,GTI
I tried to post a picture of it but failed. But it's the original protectant. It's been around forever. Keeps your rubber new and makes the interior shiny. Just don't use it on the dashboard unless you like to see dashboard in your windshield.
Old 12-13-2019, 09:36 AM   #8
WNDSRFR
Drives: FR-S,GTI
The baby powder seems like a good idea.
Old 12-13-2019, 11:18 AM   #9
HaXx
Drives: jrsc_brz
the winter prep ftspeed video suggests wd40
[ame="https://www.youtube.com/watch?v=mFR0pFeLoCg"]https://www.youtube.com/watch?v=mFR0pFeLoCg[/ame]
HaXx is offline   Reply With Quote
Old 12-13-2019, 12:42 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
While I do appreciate them trying to give advice, I would not put faith in them having done any research in the long term effects of an evaporating lubricant on the window seal material.
Old 12-13-2019, 01:02 PM   #11
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
That 3m stuff is a good call. I am wary of Using anything that would damage window tint.
I got some cheap window seal treatment off Amazon a whole ago and never noticed the door seals freezing.
I do however have issues with the window freezing and not dropping until the car warms up. Not sure how to fix that.
The Following User Says Thank You to RToyo86 For This Useful Post:
Busybee (12-13-2019)
Old 12-18-2019, 02:33 AM   #12
Stomachbuzz
Drives: 2013 FRS
Honestly, my main concern with using a sort of grease or lubricant on the window seal is that it doesn't make my window look greasy.
Stomachbuzz is offline   Reply With Quote
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 03:14 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 02:08 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 08:25 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 06:34 AM
