, dpfarr
Old 12-01-2019, 05:28 PM   #3305
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
just got the heads off, with the exception of two bent exhaust valves, they're all good!
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
tomm.brz (12-02-2019)
Old 12-01-2019, 08:44 PM   #3306
Colin86
Drives: 86
Originally Posted by B T View Post
Kiske, close, but I think it was cylinder #2, LH side front from driver seat.
FWIW I met the team at Dynosty in KY and they seem like a strong group. If I were building a motor I'd consider them. Keep us posted if you could, I'll be curious what you go with and your experience in case my stock motor ever lets go.
Colin86 is offline   Reply With Quote
Old 12-01-2019, 11:33 PM   #3307
B T
I guess I forgot to mention the build.
IAG Stage 2.5 Block,
Compression dropped to 12.4 with slightly thicker gasket
Ferrea +1 mm over intake/exhaust Comp Plus valves
Ferrea single valve spring kit
GSC guides and seals
Perrin motor mounts (I found the passenger side frame rail rubbed by the engine)
They had the block to me within a week of ordering. It's really hard to get them on the phone though.
Old 12-02-2019, 03:41 PM   #3308
itsaBRZ
Drives: 2015 Subaru BRZ Aozora
Originally Posted by kev0 View Post
How many miles since replacing the front o2 sensor? Did you check header for exhaust leak? The codes may come back after 20 or so miles. If you pressure/smoke tested and found absolutely no leaks, it could be in the tune.
Yes, no leaks at the header and you sir are correct... the P1170 and P117B (Port & Direction Injection failed codes) have since come back even with the new O2 sensor.
I'm running the stock Edelbrock carb tune, is there a possibility for some reason it doesn't work on my car?
itsaBRZ is offline   Reply With Quote
Old 12-02-2019, 03:44 PM   #3309
itsaBRZ
Originally Posted by toast View Post
Are your fuel trims still through the roof?
Thinking about everything that gets removed/reinstalled for this we should be able to narrow this down. High fuel trims are generally a vacuum leak but all these other weird things showing up make me wonder if your ECU is connected and grounded. Check the four plugs on the ECU and make sure they are fully seated. I would actually pull all four off and check to make sure none of the pins are damaged before reconnecting everything. The ECU grounds to the block via the bottom bolt of the three that hold it on. I actually added an 8 gauge wire going right from the ECU to a bolt in an open hole on the block just to make sure.
I'll double check all of those 4 plugs are fully seated to the ECU and yes all 3 bolts are connected to the ECU. The bottom bolt was a paint in the ass to get in because of the waterpump hoses. When you have a spare moment, would you please take a picture of where you grounded the wire from the ECU bolt? I'd appreciate it and thanks.
Old 12-03-2019, 04:39 PM   #3310
B T
Has anyone had experience with the Koyorad or CF Racing radiators with the edelbrock?
Old 12-06-2019, 02:54 PM   #3311
shr133
shr133's Avatar
Drives: 2013 FRS
I don't know why I can't find this? What is the boost for the 3" pulley.
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 12-07-2019, 06:11 PM   #3312
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
3" = 15psi
2.6" = 20psi
https://www.ft86club.com/forums/show...&postcount=329
The Following User Says Thank You to Kiske For This Useful Post:
shr133 (12-12-2019)
Old 12-09-2019, 06:33 PM   #3313
B T
Anyone know what temperature the heads get upto? Was looking into a high temp Teflon gasket between the heads and supercharger. It's only good upto 250 deg F
Old 12-12-2019, 09:25 PM   #3314
shr133
shr133's Avatar
Drives: 2013 FRS
Originally Posted by Kiske View Post
Guess I won't be using the 3" pulley with stock rods.........
Old 12-17-2019, 06:17 PM   #3315
djenousis
Drives: 2015
Do you have any updates? You are one of the few people I've found that is having an almost identical experience.
2015 Subaru BRZ
djenousis is offline   Reply With Quote
Old 12-19-2019, 03:50 PM   #3316
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
I've been keeping up with the posts for a few months now, but haven't read EVERY single one of them.
I'm about to start the install this weekend. I have the instructions from Edelbrock and keeping this video (
) handy as well.
Any tips, tricks or cautions regarding the 2017+ model years?
BA9092 is offline   Reply With Quote
Old 12-25-2019, 04:30 AM   #3317
kev0
Drives: '14
For those who have had a faulty bypass actuator, what were some symptoms? I suspect mine to be failing. P0171, P1170 and P117B codes.
@djenousis @itsaBRZ did you guys ever find a fix to your problem?
kev0 is offline   Reply With Quote
Old 12-26-2019, 12:58 AM   #3318
Smaay
Drives: 2013 FRS
Sorry for making a double post but the answers I got really have me worried about experience in FI
Something is wrong S/C
I have the Edelbrock S/C and the car has been running fine for almost a year. Well last week I got on it and it shuttered and the CEL flashed but no code was set.
Then the other day I had the same issue and then got a 0300 and 0301. I have 92k miles on the odometer so i finally installed the HKS sparkplugs. everything in the install was fine, but now the car run like absolute shit.
There is no power, its misfiring, and according to my gauges, it seems like the AF is not getting richer going into boost.
one thing that did happen is while turning a ratchet, I touched the positive battery terminal and fried the right side fuse link. The ECU was disconnected when this happened. I didnt realize I killed it until i went in and had no power. I moved that cable to the left side fuse link and got all my power back.
the spark plugs are gapped at .025
Nothing else was really touched in the install process.
Smaay is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
