Old 12-02-2019, 03:31 AM   #127
tomm.brz
Drives: brz 2017 hksv2
It does go landscape, you just have to set up a new dash from scratch
It works pretty everywhere, it s just a tad annoying to set up
Old 12-02-2019, 04:09 AM   #128
kev0
Drives: '14
Ahh. gonna re-do my whole dashboard then. Thanks
kev0 is offline   Reply With Quote
Old 12-02-2019, 02:37 PM   #129
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by kev0 View Post
Unless you're jailbroken with iPhone, or have a way to mirror your phone to your headunit, no.
Even if you are jailbroken or can mirror your phone, the app doesn't support landscape mode so the gauges look funky on the headunit. I'm doing that at the moment, and even though it works, it's so clunky and everything looks weird.
The iphone app doesn't do landscape? That might be the first time I've ever seen an android app do something that the iphone one doesn't. Dashboards in landscape are great.
toast is offline   Reply With Quote
Old 12-02-2019, 04:33 PM   #130
Rezi
Drives: GT86
Originally Posted by toast View Post
Necro revival - if you use the ECU Connect app for the bluetooth dongle DO NOT update the app to 3.9.3 on android. It no longer connects to the bluetooth dongle except as a generic device. If you completely remove the app, forget the bluetooth connection and when the app first launches say Forgot Code you can go through the full pairing again and it will work UNTIL you try to start a datalog, at which point it will crash.
it works for me as usual
Rezi is offline   Reply With Quote
Old 12-02-2019, 10:25 PM   #131
toast
After updating to 3.9.3 version everything still behaves the same? The ECUTek guys are in Europe, maybe there is something different about the ECMs and how they talk to the bluetooth module.
Old 12-03-2019, 04:14 PM   #132
Rezi
Drives: GT86
Yup, worked without problems on 3.9.3, at least for me.
They just updated to 3.9.4.1
Old 12-03-2019, 04:46 PM   #133
toast
Yeah, I saw the update this morning. Haven't been back in the car yet to try it out.
Old 12-04-2019, 11:35 AM   #134
toast
That update got is working again, but it wiped out all of my dashboard setups. Argh!
Old 02-23-2020, 11:41 PM   #135
thinkV
Drives: BRZ Turbo
Anyone have trouble with the dongle disconnecting? Mine doesn't maintain a constant connection anymore
thinkV is offline   Reply With Quote
Old 02-23-2020, 11:44 PM   #136
86TOYO2k17
Drives: 2017 toyota 86
Mine did. I got an OBDII extension cable. Works fine now. Just doesn’t like being directly connected
Old 02-23-2020, 11:54 PM   #137
thinkV
Drives: BRZ Turbo
Thought that might be the case, which one did you get?
Old 02-24-2020, 12:31 AM   #138
86TOYO2k17
bbfly-B4 OBD II OBD2 16 Pin Splitter Extension 1 x Male and 2 x Female Extension Cable Adapter (1FT/30CM) https://www.amazon.com/dp/B071HP9JFJ..._k41uEbGKA83BD
I have one going to my scangauge connected just under the normal OBD port only a little lower so much easier to get to but still out of the way. And i have the other one running to the right side tucked behind the side panel plastic trim piece close to my knee with just the connection sticking out super easy to get to, and still out of the way though. i use that one for ecutek or any time i need to connect something to OBD. Connections are really easy to plug into but also very sturdy strong connection. Much better then oem connector in every way.
Old 02-24-2020, 08:42 PM   #139
CSG Mike
CSG Mike's Avatar
OBD2 extension cable.
The 2013 and some 2014 OBD2 ports are finicky.
Old 02-24-2020, 09:07 PM   #140
ROGUEI4IHIRE
ROGUEI4IHIRE's Avatar
Drives: 2017 Toyota 86 860 W
So is there a head unit that can run EcuConnect app or not? I’ve seen a lot about jail breaking and Bluetooth naming convention issues. I’d really like to throw an android head unit in download the app on it and be able to do everything without my phone.
ROGUEI4IHIRE is offline   Reply With Quote
Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM DeliciousTuning Software Tuning 331 06-17-2025 02:36 PM
My Bluetooth in my 2014 FRS so stay connect Case1010 Electronics | Audio | NAV | Infotainment 3 02-24-2016 06:57 PM
Header/overpipe interface misooscar Engine, Exhaust, Transmission 4 11-22-2014 11:21 PM
Garmin GPS Bluetooth Won't Connect frssfo Electronics | Audio | NAV | Infotainment 0 08-20-2014 10:55 PM
Bluetooth connect mutes android NAV Rob_g Electronics | Audio | NAV | Infotainment 6 07-04-2012 04:38 PM
