Old 07-31-2019, 04:06 PM   #71
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by CoolHandMoss View Post
Interesting. Now I'm left wondering why solo storm shows me maxing out at 60 on 245s in my 2015. I think the limiter is around 7600. I do need to bump it up.
That does seem a tad lower than it should be.
My 2013 FRS had OFT on it and now looking back at some of my videos, it was doing 61mph with a 7550 limiter. Been a few years since that car...I'll update my original reply.
Keep in mind the 7800 limiter with 255's was on my 2017 BRZ, so shorter final drive gearing that your 2015 or my 2013 of course.
justinco is offline   Reply With Quote
Old 08-11-2019, 07:32 PM   #72
KevBRZ
Drives: 15BRZ
tire wheel fitment
reposted in wheel fitment thread
KevBRZ is offline   Reply With Quote
Old 10-02-2019, 10:48 PM   #73
KevBRZ
Drives: 15BRZ
stx setup
2015 BRZ Limited Car is More of a Street STX setup for a daily driver,
Suspension:
SS1 coilovers with 340 spring rates front and rear
fronts set at 80% stiff and rear at 50%
Front psi 32 rear 30
Camber: -3.2* front, 0 toe / -2.2* rear, little bit of toe in
Perrin 22m front bar on soft
RacerX end-links in front
Velox rear arms with poly bushings
Engine:
Stock intake with K&N filter
Perrin inlet tube
Perrin 2.5 inch non resonated exhaust
(Looking to do header and tune and maybe intake next year)
Wheels, Tires, Other:
Enkei 17x9 rpf1s gunmetal with 245/40/17 Rivals
(Ferodos pads purchased for next year)
Only have one event so far and i am very rusty, Took 6 event runs and 3 fun runs to get the car to a time with not much left on the table i think anyhow(dropped like 4 seconds ), codriver and myself feel the car was mostly neutral with bias towards understeer when pushed. At this point the gas can be mashed in a turn with very min to no oversteer which may change with header and tune down the road. The negative is car is a bit hard to rotate, it was easier with higher rear pressure, with lower pressure car really sticks. FWIW
The Following User Says Thank You to KevBRZ For This Useful Post:
smg1138 (10-03-2019)
Old 12-02-2019, 11:44 AM   #74
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Question for those of you with RacerX front end links. Are they shorter than stock length? My Whitelines seized up and I'm looking to replace them.
Also, any noise issues with them?
smg1138 is offline   Reply With Quote
Old 12-02-2019, 06:24 PM   #75
cueball89
Drives: 15 Impreza
They are shorter than stock. At the absolute shortest setting they were contacting the body of the car on large bumps. I can't speak to noise or durability, I've only had them on for a few hundred miles which they have been quite.
cueball89 is offline   Reply With Quote
The Following User Says Thank You to cueball89 For This Useful Post:
smg1138 (12-02-2019)
Old 12-02-2019, 08:41 PM   #76
smg1138
smg1138's Avatar
@cueball89 Did you set them to remove pre-load? I think my Whiteline KLC 180-195's are about the same size, but I haven't had any problems with rubbing.
Old 12-03-2019, 11:45 AM   #77
M0nk3y
Rubbing is very dependent on the type of coilover/shock you're running.
As I've found out, the whiteline endlinks I had initially contacted the inside fender. Further investigation with Karwan/Karcepts we've discovered the MCS location on the shock body for endlink was more severely pitched/lower than say KW.
I bought my own from McMaster Carr and built (similar to what RacerX now carries) and resolved the issue. Now I use Karwans provided on the Karcept bar
Kyle H. - #89 STX
The Following 3 Users Say Thank You to M0nk3y For This Useful Post:
justint5387 (12-06-2019), smg1138 (12-03-2019), strat61caster (12-03-2019)
Old 12-03-2019, 12:30 PM   #78
KevBRZ
Drives: 15BRZ
Yes they are shorter than stock, if i remember correctly when they were fully extended maybe about an 1 inch shorter i think it was, and i have had mine on for a few thousand miles with Racecomp engineering SS1 coilovers and Perrin FSB set on soft setting with no issues and no noise etc.
Old 12-03-2019, 06:16 PM   #79
cueball89
Drives: 15 Impreza
There's no preload. The stock endlinks and the racerx endlinks bolted right up with no undue tension with the front wheels under load. RCE SS1 coilovers lowered ~25-30mm with a 19mm perrin front bar.
Old 12-04-2019, 07:48 PM   #80
Molez93
Scott M
Molez93's Avatar
Drives: '13 BRZ (DocWalt's old car)
Speaking of front end links and understanding how there are variations based on each car's specific set-up...
Anyone found an effective end link to pair with the "original" Ohlins Road &Track coilovers and a Whiteline 20mm FSB which does not make contact with the coilover? I think the Whitline ones make contact under full lock or something similar, but couldn't say exactly when it hits. I just know for sure I've sheared the driver link bracket (since replaced) from the forces and the pass side looks bad.
Thanks!
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240
06 BMW Z4M Roadster, 20 M850
Molez93 is offline   Reply With Quote
Old 12-05-2019, 07:20 AM   #81
steverife
Thanks!
If I were you, I'd look at piecing something together.
steverife is offline   Reply With Quote
Old 12-05-2019, 09:46 AM   #82
Molez93
Scott M
Molez93's Avatar
If "piecing something" together means mixing manufacturers across parts, that's exactly what I was asking about. If no one has an 'end link only' suggestion, I'm very open to switching out the FSB too.
If the piecing together is a suggestion for a trail and error approach, I guess that's more like plan C.
13 BRZ (DSTprep)
Old 12-05-2019, 09:57 AM   #83
steverife
I meant making your own from parts (rod ends/rod/spacers/fasteners/etc) from McMaster-Carr or your hardware store of choice.
I'm not sure if Kyle ever posted his parts list or still has it, but I'm sure there is info for a good starting point out there.
The Following User Says Thank You to steverife For This Useful Post:
strat61caster (12-05-2019)
Old 12-05-2019, 10:53 AM   #84
Molez93
Scott M
Molez93's Avatar
^ Thanks for the clarification, sounds pretty reasonable.
13 BRZ (DSTprep)
2019 CDC & SCCA Autocross Thread JakeRogue Mid-Atlantic 15 05-17-2019 09:58 AM
Would you prefer 2019 Toyota TRD or 2019 Subaru BRZ limited Busybee Scion FR-S / Toyota 86 GT86 General Forum 64 02-24-2019 12:05 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
