Old 12-02-2019, 01:34 AM   #63603
Cole
Not a troll
Cole's Avatar
Recently reconnected with my childhood best friend. He has three kids.
My fiancée doesn’t even trust me to do laundry.
Cole is offline
The Following User Says Thank You to Cole For This Useful Post:
humfrz (12-02-2019)
Old 12-02-2019, 04:44 AM   #63604
Sounds like she knows you all too well -
humfrz is offline
Old 12-02-2019, 06:37 AM   #63605
JD001
JD001's Avatar
Drives: Subaru BRZ
I wonder any company make Toyota 2000GT replica kit. It’ll be cool project to do
Well, there is the version that Rocky Auto produce.. looks very nice too... Not quite a kit.... But nice..
JD001 is offline
The Following 4 Users Say Thank You to JD001 For This Useful Post:
ichitaka05 (12-02-2019), korhun (12-02-2019), Nevermore (12-02-2019), soundman98 (12-02-2019)
Old 12-02-2019, 06:56 AM   #63606
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
back from vacation. what'd I miss?
echo419 is offline
Old 12-02-2019, 07:27 AM   #63607
JD001
JD001's Avatar
Drives: Subaru BRZ
Ole @humfrz hasn't reported any reversing incidents.. but is thinking about changing his attire.
JD001 is offline
The Following User Says Thank You to JD001 For This Useful Post:
echo419 (12-02-2019)
Old 12-02-2019, 07:48 AM   #63608
Hey, I raised 3 kids and they turned out fine, despite MomHawk not letting me help with laundry in 30+ years.
The secret is to turn her things pink the first time you help with no visible means of having made it happen. No idea how I managed to do it, I credit divine intervention.
Dadhawk is offline
humfrz (12-02-2019), soundman98 (12-02-2019), spike021 (12-03-2019)
Old 12-02-2019, 08:18 AM   #63609
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Not much. Where did you go?
Sapphireho is offline
Old 12-02-2019, 08:25 AM   #63610
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I don't even know how to use our new washer and dryer. Mrs. Ho tells me they work great.
Dadhawk (12-02-2019)
Old 12-02-2019, 09:36 AM   #63611
Figured out my parasitic power drain on our Suburban, it is a bad instrument cluster.
It's not going to sleep after the car is turned off. The reason the problem disappeared for a while is if you pull the fuse or unplug the battery the cluster shuts off until you start the car. The last time I charged the battery I hooked it directly back up and didn't drive the car for a week, so everything was good. As soon as I drove it again, the battery drained in 3 days.
Charged the battery, drove the car a while, then let it sit for 4 hours with the hood unlatched so I didn't have to open the car door. Sure enough, all circuits were zero power draw except the instrument cluster circuit. Pulled the fuse, put it back, zero power draw.
Apparently this is a common issue with GM trucks from 2002-2006.
Reconditioned cluster on order, should take less than 15 minutes to replace (pull off a trim piece, 4 bolts, one cable bundle).
Dadhawk is offline
The Following 6 Users Say Thank You to Dadhawk For This Useful Post:
humfrz (12-02-2019), Lantanafrs2 (12-02-2019), soundman98 (12-02-2019), spike021 (12-03-2019), Spuds (12-02-2019), Tcoat (12-02-2019)
Old 12-02-2019, 09:45 AM   #63612
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Good job! How much was the cluster?
Old 12-02-2019, 09:51 AM   #63613
A rebuilt one is $170 with a $300 core charge. That includes programming the VIN and the Odometer which, while digital, is stored in the cluster.
Dadhawk is offline
Sapphireho (12-02-2019), soundman98 (12-02-2019), Tcoat (12-02-2019)
Old 12-02-2019, 10:03 AM   #63614
echo419
echo419's Avatar
Disney and Universal from Thursday until Tuesday and then took the rest of the week through Thanksgiving off. it was great.
highlight of the trip was a semi-private(2 other people) tour through the animal preserve at Animal Kingdom. we got super close to the animals, got to talk with one of the keepers and had all we could eat tapas with booze. it was fantastic! I'll upload pics later. 2 looked so good that I might frame them.
echo419 is offline
The Following 3 Users Say Thank You to echo419 For This Useful Post:
Dadhawk (12-02-2019), Sapphireho (12-02-2019), soundman98 (12-02-2019), Tcoat (12-02-2019)
Old 12-02-2019, 10:22 AM   #63615
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Florida?
Old 12-02-2019, 10:24 AM   #63616
echo419
echo419's Avatar
Florida?
Yes. I'm in Ga so it's just an hour long flight. iirc total transit time is like 3hrs max.
echo419 is offline
