Old 12-01-2019, 04:12 PM   #63589
I think my son does a similar "sit in darkened rooms and watch things on screens that may or may not involve the military operations out at sea" at Travis AFB.
@Clutch Dog , I also have a son that may do something similar, he is stationed at JBPHH with the Joint Intelligence Operations Center, - for sure.
humfrz is offline
Clutch Dog (12-01-2019), p1l0t (12-01-2019)
Old 12-01-2019, 04:23 PM   #63590
The collars we used for them were the smaller ones that use watch type batteries. I upgraded to the ones that used a 9 volt battery.
Being curious, I had tested the collar myself, ………..
For a moment, I thought you were going here with that story -
humfrz is offline
Dadhawk (12-01-2019), p1l0t (12-01-2019)
Old 12-01-2019, 05:09 PM   #63591
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
We had two black lab-boxer mix pups (brothers) that we kept in our yard with an invisible fence. They were easy to train and obedient dogs (the type that if you put them on their mat and said stay, they would stay there all day) and took to the fence fine with training. They rarely set the beeps off never mind get shocked.
One day an interloper (a raccoon) got into the yard and one of them chased it. They were so focused on the catch that they ran through the fence, and being smart figured out that would work anytime they wanted with minimal pain.
Next time the dog decided to chase pry outside the yard, he took off, the beep went off, he continued running. When the shock hit he literally did a back flip like he had run into a solid wall, and resumed his never setting off the beep routine.
Being curious, I had tested the collar myself, in my hand. It felt about like a contact with a standard US outlet, where the smaller one felt more like an electric fence. I never actually measured them though, not sure what the real output is.
We found once they were trained on the fence, to disable the beeper out of the collar. Then they weren't so sure where the edge was. It kept them from just running across. We also used the bigger collars with the 9v and would replace the strap with a metal choke collar since they would chew the collars off each other.
NoHaveMSG is offline
Old 12-01-2019, 07:56 PM   #63592
Ultramaroon is offline
Spuds (12-02-2019)
Old 12-01-2019, 08:35 PM   #63593
Tcoat is offline
p1l0t (12-01-2019)
Old 12-01-2019, 08:47 PM   #63594
Old 12-01-2019, 09:04 PM   #63595
Not nearly as much fun
Tcoat is offline
Ultramaroon (12-01-2019)
Old 12-01-2019, 09:08 PM   #63596
I can neither confirm nor deny that I'm sorry.
Spuds (12-02-2019)
Old 12-01-2019, 10:30 PM   #63597
How about Sensitive Compartmented Information Facility"?
humfrz is offline
Old 12-01-2019, 11:30 PM   #63598
I don't know if I remembered it wrong or if they changed the word in the acronym. I could swear that I can neither confirm nor deny the existence of either sensitive compartmentalized information facilities, or secure compartmentalized information facilities.
Where did you store the classified clay tablets when you were in?
humfrz (12-02-2019)
Old 12-02-2019, 12:07 AM   #63599
Where else -
humfrz is offline
Spuds (12-02-2019), Ultramaroon (12-02-2019)
Old 12-02-2019, 12:24 AM   #63600
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I wonder any company make Toyota 2000GT replica kit. It’ll be cool project to do
ichitaka05 is offline
soundman98 (12-02-2019)
Old 12-02-2019, 12:37 AM   #63601
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Because they would sell ones of them.
Sapphireho is offline
echo419 (12-02-2019), Ultramaroon (12-02-2019)
Old 12-02-2019, 01:32 AM   #63602
Where else -
I concede. Looked up some documents from the mid-eighties. Sensitive Compartmented Information Facility.
humfrz (12-02-2019)
