Old 10-07-2015, 02:56 AM   #57
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
bite has a big difference compared to stock and the other brake pad i've tried, when braking at the track at my normal spots, i have a couple of meters left than usual.. only issue is that it tends to fade after 2-3 laps of hard braking
after 2 light trackdays, i gave up on them and sold it to a friend for a cheap price like less than $100 for a set (front and back) and he did feel also the brake fade and used a diff set
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
Old 10-07-2015, 02:57 AM   #58
CSG Mike
CSG Mike's Avatar
Originally Posted by KoolBRZ View Post
I have used these for the street only for the last 2 years. I just replaced the front pads because they were just about down to the metal, but the rear pads still had 2/3 left so I'll replace them next time. I've never bedded them in, and simply used them normally. They carved so much metal off the stock rotors, there was a 1/16" lip on them, front and rear. Mine don't squeak, but they do make a scrubbing noise of rotor being sanded off with every stop. I replaced my stock rotors with Stoptech Sportstop drilled rotors from Tire Rack because grooved rotors eat the pad quicker then drilled rotors and they allow cooling airflow through the rotor in addition to braking better than stock, plain, rotors. They also look much cooler than grooved or plain rotors. I probably have about 20% more braking power than the same pads on stock rotors. I have an AT, so I won't be seeing the track anytime soon, but these work as a great street pad for me. I can live with the dust since my wheels are mostly black anyway. It's worth it to have brakes that work so much better than stock. I don't know how you people can go back to stock pads after using racing pads. There's just no comparison.
This, so so much.
Old 10-07-2015, 06:39 AM   #59
DarkSunrise
DarkSunrise's Avatar
Originally Posted by DarkSunrise View Post
Did a track weekend with these pads and they were just ok. Initial bite felt soft. I think I was also getting pad fade a few laps in, as I'd have to press the brake pedal very hard to get adequate response. On the plus side, they never fell completely away, despite getting hot enough to smoke a bit after sessions. I was coming from Stoptech pads which had better hot bite, but faded noticeably and eventually smeared on the rotors.
It's not an issue tracking with these once I got used to them, but I was hoping they'd be more effective. I'll probably go a different direction once these pad are done.
Oddly I love them on the street. Great cold bite - they'll quickly engage ABS with minimal effort.
I should probably update my review of these pads. After just 4 track days, my pads were worn nearly to the backing plates. Because of this, I wouldn't recommend these pads to anyone who tracks regularly. As street pads though, they are solid.
I've since switched to a dedicated track pad and they are wearing much better. If you track frequently, I'd skip these pads and go with something designed for track use.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
CSG Mike (10-07-2015), drewbot (10-07-2015)
Old 10-07-2015, 03:12 PM   #60
CSG Mike
CSG Mike's Avatar
You're a little faster than the average bear
Old 10-07-2015, 03:48 PM   #61
DarkSunrise
Haha or I'm just slowing down more for corners than everyone else!
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
CSG Mike (10-08-2015)
Old 10-07-2015, 11:22 PM   #62
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
Originally Posted by troek View Post
nooooooo, i went full throttle to 120kph full brake(no abs) to 20kph and repeat with no delay. I did this until i get brake fade then did 1 or 2 more.
How do you turn OFF the ABS of BRZ/FRS? Doing the pedal dance will turn off the ABS of this car?
RL_BRZ is offline   Reply With Quote
Old 10-07-2015, 11:50 PM   #63
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I hope he means threshold braking. Disabling ABS can mean locked wheels if you're over-zealous. You'll have some nice, new flat spots on your tires to go with your bedded brakes.
EDIT: To clarify, I don't mean that turning off your ABS is always a bad idea. I just don't think it's necessary for brake bedding. Good threshold braking has been sufficient on every car that I've bedded brakes on. There's sometimes a thin margin before lock-up, past where the ABS would usually engage, but it's a very small margin, if at all, so I don't ever bother to disable the ABS to bed brakes.
jawn is offline   Reply With Quote
Old 10-08-2015, 01:37 AM   #64
CSG Mike
CSG Mike's Avatar
You have to pull the fuse to disable ABS.
The Pedal Dance does not turn off ABS.
RL_BRZ (10-08-2015)
Old 10-11-2015, 09:49 PM   #65
troek
troek's Avatar
Drives: 2012 Toyota 86
yes, i meant not braking hard enough to engage abs. haha sorry for the confusion
troek is offline   Reply With Quote
Old 11-30-2019, 01:58 PM   #66
curtdragon
Drives: Acura TSX
Sorry to bump an old thread but what is the proper breaking in process for these? Bought a set someone had BNIB. Also are you guys running them without a backing plate?
I have almost the same setup as the OP except running the DBA T2 on all 4 corners
curtdragon is offline   Reply With Quote
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Project Mu HC+800 Pads Anthonytpt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-08-2013 02:48 PM
Street/Clubsport brake pads for your BRZ and FR-S HP Autowerks Brakes, Suspension, Chassis 4 02-20-2013 01:34 PM
Street/Clubsport brake pads for your BRZ and FR-S HP Autowerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-15-2012 07:03 PM
Different pads for street and track Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-01-2012 02:55 PM
