Old 04-26-2019, 09:21 AM   #2297
More than likely the issue with GPS will require a firmware fix. I didn't read all the way back through the thread but this is due to the GPS rollover event in early April.
Old 04-29-2019, 05:59 AM   #2298
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Originally Posted by born2lose View Post
I actually still enjoy mine - and hope someone will find a fix. I’ve been looking for alternatives, but I can’t find a single one that will fit in the same way - no brackets, etc. If you have any suggestions, please share.
now, time to go back to the parking lot and disconnect the gps antenna... although it’s not of much use without the gps. I really hope the fix works...
l.e. disconnected the gps, changed the date to 2018, I have music and no more resets. whenever I try to reconnect the gps antenna, the date resets to 1963 and it all goes to crap. which is unfortunate, because that counts for 80% of it’s usefulness to me.
still open to any suggestions...
I've been using an ownice c500 for a few years, it's OK and a lot better than the ca-fi and fits perfectly. See video link:
86•BRZ is offline   Reply With Quote
Old 05-08-2019, 06:36 PM   #2299
hthought
Drives: awesome
Yeah, this GPS issue has rendered the whole device unusable at the moment. It's a shame cause it has been great for many years. If anyone discovers any solution or if a new firmware comes out, please do let know.
hthought is offline   Reply With Quote
Old 05-12-2019, 05:05 PM   #2300
Moor
Drives: Toyota Sienna
I know the solution. Read (translate.google.com) my post here
You will find the file gps.default.so and firmware update_V3_dexp_logo in the same forum.
You need to turn off theGPS-antenna, install the firmware, replace the file gps.default.so, turn on the GPS-antenna. Good luck!
Moor is offline   Reply With Quote
The Following User Says Thank You to Moor For This Useful Post:
Impureclient (05-12-2019)
Old 05-15-2019, 08:59 AM   #2301
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I can confirm this works
Old 05-15-2019, 07:03 PM   #2302
hthought
Drives: awesome
Thanks ! It's a bit tough to understand, translation sucks. I am assuming that you used an sd card or so to upload new firmware to it after making some local file changes on your computer ?
Old 05-16-2019, 01:27 AM   #2303
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I used the existing rooted firmware I had then replaced the gps.default.so file with ROM toolbox file browser and adjusted the permissions of the file to match. Then reboot with the aerial now connected.
Old 05-16-2019, 02:08 PM   #2304
Moor
hthought Yes. On the computer, I replace the files \update\images\manufactorycfg\keymaps.xml (the assignment of device buttons) and \update\bin\set_partition (partitioning memory sections) with old ones from the native firmware. You can also replace the file \update\images\logo.bmp. Then write to the SD and flash. After the flashing and rebooting replace the file \system\lib\hw\gps.default.so.
86•BRZ I couldn’t replace this file on my native firmware (2015-03-18, rooted) because the Superuser does not allow access to it. But I did not try ROM ToolBox
Old 05-16-2019, 02:32 PM   #2305
Moor
You can replace the entire folder "manufactorycfg", it will not be worse
Old 05-24-2019, 02:20 PM   #2306
Moor
The GPS-antenna can not be turned off. You can flash firmware, then park for a short time in a place where gps is not available - a tunnel, underground parking, etc. When the device stops rebooting, replace the file gps.default.so.
According to unverified information, the file can be replaced in our native firmware using the ROM Toolbox.
Old 07-22-2019, 10:31 PM   #2307
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
This issue came up again for me. It went away when it happened a few months back. Just reflashed to rooted firmware and replaced the gps driver... Hope this works.
Pwolf is offline   Reply With Quote
Old 11-27-2019, 12:03 PM   #2308
born2lose
Drives: Toyota GT86
hi guys,
probably not a lot of activity on this thread anymore - but can anyone help me with the rooted firmware? I want to give it a try using the solution that 86•BRZ posted above, but I've searched the internet far and wide and cannot find the firmware.
thanks for any tips
born2lose is offline   Reply With Quote
Old 11-27-2019, 01:41 PM   #2309
Pwolf
Pwolf's Avatar
hi guys,
thanks for any tips
I'm uploading the firmware, I'll send you a DM when it's done. I have it named "root" but I don't recall if it was the correct firmware or not.
Old 11-27-2019, 04:15 PM   #2310
born2lose
Drives: Toyota GT86
appreciate the help I'll install it in the car and I'll try to replace the gps file, we'll know soon enough if it's the correct firmware
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
