#15 |
Drives: 14 BSP Edelbrock BRZ
I second this. I'm running 245 and it doesn't feel light and quick like it did stock but I didn't want to run staggered and even with the 245's I can light up third gear (FI).
#16 |
Rust bucket enthusiast
Are you turbo or supercharged? What kind of tires? Even with 300WHP turbo I'm hooking 2nd and 3rd with Falken Azenis in 215s.
#17 |
Drives: 2016 Scion FRS
Like others said, the wider tire will make the car feel heavier and numb on the street.
However, when you push on the car a bit, it will pay dividends (if you've chosen your parts well). ...and all this is assuming everything is tight and aligned properly. |
| The Following User Says Thank You to steverife For This Useful Post: | strat61caster (11-25-2019) |
#18 |
Supercharged. I have Hankook V12s and if it is below 50 degrees second gear just spins. They may be a little harder than the Falkens, but I can't imagine second gear grip with 215s.
#19 | |
Drives: 17 BRZ Series.Yellow
Also, if the wheel is turned at all, it'll be much easier to light up the tires as well versus trying to go straight. |
| The Following User Says Thank You to i8ur911 For This Useful Post: | DarkPira7e (11-25-2019) |
#20 |
It's all in the compound and application. Once the Falkens get warm, they hold on like a bastard. You won't grip anything on cold pavement, so there's nothing you can do there. You'd also be surprised how big a difference tread block design and block size change grip behavior in tandem with the compound
#21 |
It is weird seeing someone praise the Falkens, especially for how they put down power.
#22 |
#24 | |
I'd appreciate if you didnt jump to conclusions on another topic we aren't talking about. Its boosted fyi
Running FI turbo 200kw+ i think it might have something to do with the suspension being soft as I made it stiffer by turning the knob at the top of the structs on the front and back clockwise to the stiffest setting and now it's a tiny bit better Quote:
| The Following User Says Thank You to csol For This Useful Post: | DarkPira7e (11-25-2019) |
#25 |
Drives: 2014 GT86
csol: in future i advise to whenever you do alignment, to ask for printout of it. Only knowing camber/toe numbers others may suggest with more certainty, if certain handling issue is from that or not. Also knowing what alignment before, simplifies doing planned changes to handling from different alignment. Printout also adds some extra QA to suspension shop work
| The Following 4 Users Say Thank You to churchx For This Useful Post: |
#26 |
Only happy when it rains.
Drives: series.blue
18's are boat anchors. That is what happens.
Grip is compound dependant, not size dependant. Unless you are racing, it's silly to use such large tires and wheels. |
| The Following User Says Thank You to why? For This Useful Post: | Tcoat (11-26-2019) |
#27 |
18s aren't always boat anchors. Some are reasonably light and it's not too hard to find an 18x8 lighter than stock. But I do think too many people go to 18x9.5s on this car (may not be the issue here).
Either way for this case, you've got to get your alignment numbers and should know your spring rates as well. Hard to help without that. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#28 |
Drives: '13 FRS - STX
OP did put 18x9.5's on
| 2013s less responsive than 2017s? | 370zBRZ | BRZ First-Gen (2012+) — General Topics | 25 | 07-28-2018 05:24 PM |
| Car feels a little less peppy | Riftur | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 04-15-2018 06:02 AM |
| Which entry level turbo kit is the most responsive? | Keenercarguy | Forced Induction | 54 | 04-18-2017 03:40 AM |
| Am I the only one that feels bothered by this (R.S 1.0) | 1GiantTurtle | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-11-2014 08:18 PM |
| 18's or 19's ... What looks and feels best on FR-S. | Jon1084 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 65 | 07-19-2013 06:42 PM |
