Old 11-12-2019, 11:29 PM   #71
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm glad i could stop in to look finally!
Opie (11-15-2019)
Old 11-13-2019, 12:16 PM   #72
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Originally Posted by Opie View Post
New spark plugs & updated engine harness purchased, it will be helpful installing the 2015 engine into this 2013 and retaining the updated coil packs. Also, since the purchased motor is out of an A/T car we will need to transfer/remove a couple of parts; vacuum pump, water crossover pipe, etc.
Anybody got an A/C delete pulley for sale?
Just want to ask about the harness/coilpack issue. So you bought a harness of a 2015 to go in a 2013 car? was it plug n play? I have a 2014 and in the future for going more to track events, is it possible to use a 2015 coilpack? or the 2014 has an updated harness and coilpack?
Thank you in advance for your reply.
tintumz22 is offline   Reply With Quote
Old 11-14-2019, 01:30 AM   #73
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Subaru sells a newer engine harness with the right connectors. @Opie can provide the part number.
For a 2015 engine into a 2013 car we used the updated harness with the water temp and oil temp sensors from the 2013 engine as they are also different. Otherwise it is plug and play.
For your case you'd swap engine harnesses to the 2014 update harness or splice the new coil pack connectors into the original 2014 harness. Plus of course the 2015+ coil packs.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
tintumz22 (11-14-2019)
Old 11-15-2019, 10:40 PM   #74
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
As Dave-Ror said, Subaru makes updated harnesses to use the better coil packs in the older cars. These coil packs have a couple of advantages; better grounding, better shielding, updates to the solder joints and the new style coil packs.
In 2015 they went to a new style coil pack (P/N:22433AA730) and the harness connector is different compared to the older 2013-2014 style. If you have a 2013 or a 2014 there are updated engine harnesses available to use the updated (improved) coil packs. The harnesses also have the improved shielding and grounding the 2015 and newer models got.
For 2013 models the updated harness is P/N: 24020AG620
For 2014 models the updated harness is P/N: 24020AG080
NOTE: There is no interchange between the old and new parts. For example, the new part number engine harness and new part number ignition coils must be installed as a set. You cannot use the newer coil packs with the old harness and you cannot use the older coil packs with the new harness.
It is all part of TSB #07-120-17R to Address DTCs P0351, P0352, P0353 and / or P0354
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 5 Users Say Thank You to Opie For This Useful Post:
BRZyJ (11-20-2019), EndlessAzure (05-16-2023), Lonewolf (03-14-2020), mrg666 (02-08-2020), tintumz22 (11-18-2019)
Old 11-20-2019, 09:27 AM   #75
peaches
Drives: '14 BRZ Limited
wow, I didn't know it was this bad. I wonder what car my wheels will end up in.
Let me know if you guys need a hand, I can stop by and help out if I'm free.
peaches is offline   Reply With Quote
Old 11-20-2019, 10:07 AM   #76
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This one: https://www.ft86club.com/forums/showthread.php?t=137794
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
dowroa (11-20-2019)
Old 11-20-2019, 09:14 PM   #77
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Project 7 - Update #1:
Building this one for my wife. 2013 DGM Limited, 6MT, 39,000 miles.
Mods: Cusco Engine Mounts, Braided Brake Lines, Whiteline Sway Bar End Links, Whiteline Rear Diff Bushings, Whiteline Rear Subframe Bushings, SPC Rear Lower Control Arms, Slotted Rotors, Energy Suspension Sway Bar Bushings, SPT Oil Cap. Car was turbo'd before it's accident,
Needs: Drivers Airbag, Hood, Left Fender, Bumper Beam, Bumper, Fans, Radiator, Condenser, Headlights and misc trim.
After reading this specific post to Stacy, her reply was "Did Opie's wife want it?"
dowroa is offline   Reply With Quote
Old 11-20-2019, 11:21 PM   #78
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
haha she wanted it at first. Until she realized how impractical it was for her. My GF went through the same process with the Hot Lava FRS we rebuilt.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Opie (11-21-2019)
Old 11-21-2019, 02:05 PM   #79
Opie
Opie's Avatar
Truth...
Old 11-22-2019, 04:06 PM   #80
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Uhmmm #9 acquired.
Might need help to fix this mental condition haha
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
spike021 (11-22-2019)
Old 12-12-2019, 09:57 AM   #81
Opie
Opie's Avatar
Uhmmm #9 acquired.
Geez....at least this one looks fancy...
The Following 2 Users Say Thank You to Opie For This Useful Post:
Code Monkey (12-12-2019), dowroa (12-13-2019)
Old 12-12-2019, 10:05 AM   #82
jflogerzi
jflogerzi's Avatar
Oooo side skirts but seriously you guys have a problem.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Opie (12-12-2019)
Old 12-12-2019, 11:14 AM   #83
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
And that's #10 I think that @Opie just posted a pic of..
Unless I'm missing any..
1. Opie's track car (still around)
2. Some DGM FR-S Opie rebuilt (sold)
3. My silver BRZ (still around but will be sold when #8 is done)
4. Hot Lava FRS (was for my GF somewhat but she bought a new truck instead.. sold to a buddy for his daughter)
5. DGM BRZ for our buddy Aaron (still around)
6. White FR-S (sold)
7. DGM BRZ for Opie's wife (She was over it in 2 months.. sold)
8. Red FR-S that will be my future track car (Still around)
9. Red FR-S for parts (70% still around ha)
10. Red FR-S that's all sorts of fancy.. and has an engine that's locked solid. (Obviously still here...)
12 if you want to include my original 2013 BRZ that I bought in 2012 and Opie's 2013 BRZ that was also bought in 2012.......
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 5 Users Say Thank You to Dave-ROR For This Useful Post:
Code Monkey (12-12-2019), dowroa (12-12-2019), jflogerzi (12-12-2019), Opie (12-12-2019), soundman98 (12-13-2019)
Old 12-12-2019, 12:33 PM   #84
dowroa
Old Guy
We need more WRB BRZs!
RIP Dave Mirra STV3 Off-Topic Lounge [WARNING: NO POLITICS] 13 02-05-2016 02:00 PM
Dave-ROR: I know you want this rice_classic Tracking / Autocross / HPDE / Drifting 1 01-02-2014 10:15 PM
Sebring with Dave-ROR LDadrenaline Tracking / Autocross / HPDE / Drifting 9 11-13-2012 10:55 PM
Opie's BRZ thread Opie Member's Car Journals 6 09-25-2012 08:05 AM
