Old 11-16-2019, 10:38 AM   #29
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by RToyo86 View Post
Reviving this to see what blades users are running.
Recommendations and things to avoid.
Ever since I aquapel'd the windshield my driver blade is leaving a streak in my field of view on the return stroke.
i went with the rainx silicone beam style wiper blades. it seems that was the main issue, though i only used them 3 times since, so not what i would consider an adequate test.
stock never worked for me, the independent parts freeze up in cold weather, and then i can't see at all!
if the wiper is bouncing on the return stroke, my solution was to tweak the wiper arm with an adjustable wrench.
RToyo86 (11-16-2019)
Old 11-16-2019, 01:11 PM   #30
Decep
Drives: 2013 FR-S Series 10
every once in a while i clay bar my windshield and wipe it down with rubbing alcohol and get it nice and clean. makes a big difference in how well your wipers work.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
humfrz (11-16-2019)
Old 11-16-2019, 02:51 PM   #31
Originally Posted by GrantedTaken View Post
Rubber is brittle.
You need new blades.
Solved
NOW, you tell me! -
Old 11-16-2019, 03:02 PM   #32
JD001
JD001's Avatar
Drives: Subaru BRZ
Bubba says to take some alcohol and clean all that crap off the windshield, then, go buy new wipers (arms and all).
(this is one of Bubba's better suggestions - )
humfrz for Bubba
The OP can also check brake pads, bearings and bushes as you never know.. unusual vibration through components may lead to clattering wipers.
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (11-16-2019)
Old 11-16-2019, 03:04 PM   #33
soundman98
soundman98's Avatar
I CAN'T SEE THE BRAKE PADS BECAUSE IT'S THE WORST DESIGN EVER
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
G-awesome (11-19-2019), RToyo86 (11-16-2019)
Old 11-16-2019, 03:09 PM   #34
JD001
JD001's Avatar
Drives: Subaru BRZ
If your wipers didn't clatter, worked as they should you would see your brake pads!!
The Following 2 Users Say Thank You to JD001 For This Useful Post:
soundman98 (11-16-2019), Ultramaroon (11-16-2019)
Old 11-16-2019, 03:35 PM   #35
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I noticed the same freezing issue with the stock blades. Winter car washes didn't help the issue either.
I decided to try out the bosch icon as they're well reviewed. I didn't see any rain-x at crappytire.
I didn't even think about inserts for the OEM blade. I forgot that was a thing. Where do you get them
Old 11-16-2019, 03:41 PM   #36
RToyo86
RToyo86's Avatar
I've probably Clayed my windshield more than others have Clayed their car .
Probably a big reason my OE blades lasted 18 months.
Old 11-16-2019, 04:23 PM   #37
Worst wiper design ever.
Sapphireho (11-19-2019), soundman98 (11-16-2019), Tcoat (11-18-2019)
Old 11-18-2019, 08:23 AM   #38
Just look at any other car in a parking lot...
soundman98 (11-19-2019)
Old 11-18-2019, 09:32 AM   #39
JD001
JD001's Avatar
Drives: Subaru BRZ
Only 18months? 18months of constant rain? Mileage over the 18months? I have the OEM wipers from 2014 still on my car...
Old 11-18-2019, 11:24 AM   #40
RToyo86
RToyo86's Avatar
43,000km on the car. Our weather the last two years locally has been shit. They worked perfectly with rain-x. As soon as I switched to aquapel, they started to streak. The rubber is still supple and does not chatter. But the 2-3"streak in front of my eyeline drives me crazy.
Temperature fluctuations between +40c summers and -40c winters don't help.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
humfrz (11-19-2019), JD001 (11-18-2019)
Old 11-19-2019, 11:17 AM   #41
Bubba tells you the same thing he told soundman98, take some alcohol and clean all that crap off the windshield, then, go buy new wipers (arms and all).
humfrz for Bubba
Old 11-19-2019, 12:30 PM   #42
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I just use cheap ANCO blades. They usually last me 2-3 years on whatever car I put them on before they either come apart or the rubber loses its flex. I think the key is keeping the blades clean, and not blasting them over an icy windshield ( if that's a thing where you live).
Why do some folks wipe/delete their sold classified ads? bfrank1972 Off-Topic Lounge [WARNING: NO POLITICS] 8 04-09-2016 07:47 PM
Wipe body before installing mudguards, too much to ask?!?! Namuna Scion FR-S / Toyota 86 GT86 General Forum 21 01-26-2014 10:17 AM
What product do you use to wipe the BRZ top dash? synister808 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 46 06-06-2013 02:33 PM
Wipe Out.......... almost Trog BRZ First-Gen (2012+) — General Topics 19 03-18-2013 04:10 PM
What do you use to wipe off dash? Memphis Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 08-22-2012 10:40 AM
